REBIRTH - Die Apokalypse beginnt - UHD
murx75
Post by murx75 »
Have sent a download link to the dump file to svq@makemkv.com on June 04, 2024:
MKB20_v77_Rebirth_-_Die_Apokalypse_beginnt_3A80.tgz
Cheers!
murx75
Re: REBIRTH - Die Apokalypse beginnt - UHD
Post by murx75 »
what are the usual turnaround times for uploaded dump files?
I sent a link to the afore mentioned dump file 11 days ago, but MakeMKV still does not open the disk.
I also saw no download on the linked dump file.
Or is it already working for anybody out there, i.e., could it be that I have a local problem?
murx75
Post by murx75 »
Just tried the keydb.cfg download method, but despite a key for a disk version being present, MakeMKV would not open the disk:
0x9C43AE134146F571F8611B1A2627A282BE6A9D5F = Rebirth (Rebirth - Die Apokalypse beginnt) | D | 2024-02-15 | U | 1-0x81CC518165C39BEF9FFB1E63C5B3B142 ; MKBv77/BEE/FindVUK 1.72 - VolumeSize: 59156201472 (UHD) (LEGACY) (NOTVALIDATED) (BD)
Still not sure if this key is meant to open my disk, though. :roll:
I usually just attach the dump to the email I send, unless the dump is too big to email.
In any case, it can sometimes take a couple weeks for a key. It doesn't hurt to send the dump again.
Does MakeMKV have a message about HK download failed or disabled?
murx75 wrote: Sat Jun 15, 2024 3:38 pm Just tried the keydb.cfg download method, but despite a key for a disk version being present, MakeMKV would not open the disk:
Makemkv needs a Volume key. There is none for this disc in KEYDB.cfg. You would need other software to make use of the entry in KEYDB.cfg.
murx75
Post by murx75 »
dcoke22 wrote: Sat Jun 15, 2024 5:31 pm I usually just attach the dump to the email I send, unless the dump is too big to email.
No, there is no such message. 8)
murx75
Post by murx75 »
Coopervid wrote: Sat Jun 15, 2024 5:45 pm
O.k., thought that downloading the file for another disk had helped back then… ;-)
murx75 wrote: Mon Jun 17, 2024 2:44 pm
SamuriHL just suggested in another thread to use the free version of the Xreveal program that also works with unit keys. Install Xreveal, load the disc and then start Makemkv and it should work since Xreveal decrypts the disc.
viewtopic.php?f=12&t=34081&start=15
Post by SamuriHL »
Correct. It'll show you in its status window if there's an applicable key in the keydb for your particular disc. It shows the disc ID for the disc either way which is quite helpful. It's a real time decrypter like the RedFox product was and uses the keydb for its source of keys. MakeMKV will of course complain that a third party tool decrypted the disc but if it doesn't have its own key or a VUK in the keydb, then too bad. LOL (The warning was added years ago for blu-ray issues caused by other decryption software and doesn't really cause problems on UHD's so it can be ignored).
MrPenguin
Post by MrPenguin »
murx75 wrote: Mon Jun 17, 2024 2:44 pm O.k., thought that downloading the file for another disk had helped back then… ;-)
And it can, under certain specific circumstances. Check PM?
