What software to fully read UHD Blu-ray?
HarryKleins
Post by HarryKleins » Thu Jun 06, 2024 11:34 pm
Thank you for the work you do.
My question would be to know what is the best software on Windows to read 4K UHD blu-rays while benefiting from the menus (chapter, audio, bonus).
Thank you
Re: What software to fully read UHD Blu-ray?
Post by SamuriHL » Thu Jun 06, 2024 11:48 pm
Not read. You mean play. And the terminology may seem trivial but it's not. MakeMKV can read UHD's just fine. To copy them. It can't, however, play them. With that out of the way:
Free: VLC
My preferred: JRiver Media Center
There are other solutions, as well but both of these will give you full menu playback if you so desire. And MakeMKV can integrate with both of them for realtime decryption of discs during playback.
MrPenguin
Post by MrPenguin » Fri Jun 07, 2024 12:05 am
Free: VLC
In my experience, while VLC 3.x can handle BluRay menus correctly, it cannot handle HDR. (I believe HDR support is scheduled for VLC 4.x.) This results in VLC displaying "washed out" colours when playing UHD disks. Personally, I use mpv to play UHDs, which displays colours correctly but doesn't support menus.
Post by SamuriHL » Fri Jun 07, 2024 12:52 am
This is why I use JRiver. It handles everything properly.
HarryKleins
Post by HarryKleins » Sat Jun 08, 2024 6:30 pm
Thanks for JRiver I didn't know.
However, we insert the UHD blu-ray, it takes a lot of time to load, is this normal?
Also, the film starts directly, I don't come across the menus. I have to right click to choose the menu afterwards. Is there a way to directly launch the menu when launching the blu-ray?
THANKS
Post by SamuriHL » Sat Jun 08, 2024 6:55 pm
Go into options, Video, look under Blu-ray Playback. Set menus to either ask or on.
