Any of the pioneers I sell I recommend the UBK the mostb1ue21 wrote: Mon May 20, 2024 3:13 amThank you for your reply.Billycar11 wrote: Mon May 20, 2024 2:22 amclean the discb1ue21 wrote: Mon May 20, 2024 12:30 am In my case, after sent email to svq@makemkv for my dump files I got 2 HashCheck Error.
Before sending TGZ file, I got 347 HashCheck Error..
Anyway.. Queen 4k uhd won't rip from now due to 2 hashcheck error.![]()
Is there any solution for this issue??
My ODD is BP60NB10(FW 1.02)
Makemkv 1.17.7
replace the disc
clean the drive laser
replace drive with a pioneer with old FW
I have already cleaned and replaced disc and other UHD discs have been ripping without error
Can I get pioneer ODD model name for Queen 4K ripping?
Queen Rock Montreal
Re: Queen Rock Montreal
MakeMKV is reading the disc now (disk 2) but still getting errors as follows:
Error 'Scsi error - HARDWARE ERROR:TIMEOUT ON LOGICAL UNIT' occurred while reading '/BDMV/STREAM/00000.m2ts' at offset '38331095040'
Error 'Posix error - Input/output error' occurred while reading '/dev/rdisk2' at offset '38331095040'
Any options for this or is this going to be one of those troublesome titles?!
Those are read errors so the usual advice applies. Clean the disc, get a better drive, replace the disc, etc.
Is there anyone who get ripping mkv file completely for Queen 4K UHD?
I'm always getting error message after about 90% of ripping process(hashcheck error...) until now.
Not here, disc 1 (full screen) is fine but I can get to various points for disc 2 but it always fails.
I was able to back up both discs using my Pioneer XD08 drive, although disc2 did stutter once to complain that one of the UDF "nodes" didn't have any data to read. (Cannot remember the exact error.)
Interestingly, my BU40N drive struggles even to mount disc2 in the first place
Chris01992
Managed to backup both discs at the first attempt (Pioneer BDR-213EBK), but disc 2 backed up at more than half the normal speed (took nearly 3 hours)
I have realised that both of these discs contain a mastering error, specifically their BDMV/META/DL/bdmt_eng.xml files contain invalid XML. I have modified both of my back-ups manually by replacing the "&" character with "&" like this:
The point is that the "&" character is a special character which needs to be encoded in XML values.
<?xml version="1.0" encoding="utf-8"?>
<disclib xmlns="urn:BDA:bdmv;disclib" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:schemaLocation="urn:BDA:bdmv;disclib disclib.xsd">
<di:discinfo xmlns:di="urn:BDA:bdmv;discinfo">
<di:title>
<di:name>Queen - Rock Montreal & Live Aid Wide Screen Version</di:name>
</di:title>
<di:description>
<di:thumbnail href="./Queen_640X360.jpg" size="640x360" />
<di:thumbnail href="./Queen_416X240.jpg" size="416x240" />
</di:description>
</di:discinfo>
</disclib>Re: Queen Rock Montreal
How the hell does (I'm assuming) Scenarist author that??? God the studios really are lazy when it comes to this stuff.
The packaging is utter crap for this set. The post on the bluray.com forum is filled with complaints of discs that can't play properly.
I couldn't rip my original copy without errors. I have 2 different drives, and both failed. Returned that copy, got a replacement, and same thing all over again.
Is there anyone who get ripping files for these disc from now?
I'd like to know what kinds of ODD for ripping successfully
I' m using LG ODD BP60NB10 and I have always gotten errors at the end of ripping processing (99%) for DISC 2(wide screen)
I ripped these disks successfully using my Pioneer, but it still seemed to rip Disk 2 more slowly than Disk 1. I also have a BU40N, but that drive struggled even to mount Disk 2.b1ue21 wrote: Wed Jul 03, 2024 12:12 pm Is there anyone who get ripping files for these disc from now?
I' m using LG ODD BP60NB10 and I have always gotten errors at the end of ripping processing (99%) for DISC 2(wide screen)![]()
Can I get pioneer drive model name and FW version in detail??MrPenguin wrote: Wed Jul 03, 2024 12:32 pmI ripped these disks successfully using my Pioneer, but it still seemed to rip Disk 2 more slowly than Disk 1. I also have a BU40N, but that drive struggled even to mount Disk 2.b1ue21 wrote: Wed Jul 03, 2024 12:12 pm Is there anyone who get ripping files for these disc from now?
BDR-XD08EMB-S, with firmware 1.01.b1ue21 wrote: Mon Jul 15, 2024 9:00 am Can I get pioneer drive model name and FW version in detail??
FYI that drive is just about impossible to get with old FW now i have 5.25 s13 pioneers with old fw for now if you want one.b1ue21 wrote: Mon Jul 15, 2024 9:00 am
