Dune Part 2 Dump Submitted
Dune 2 won't rip "The volume key is unknown for this disc - video can't be decrypted"
Re: Dune Part 2 Dump Submitted
A note that including the file name submitted would be helpful for others. Each potential key needed is based on a calculated value, which is identified at the end of the file name.
Yesterday, I submitted the file "MKB20_v77_Dune-_Part_Two_13B6". Hope it helps !
That's good to know! This is the file name: MKB20_v77_Dune-_Part_Two_1B3E
Submitted today "MKB20_v77_Dune-_Part_Two_1B3E.tgz"
Mine's coming tomorrow. Such a good movie. I think at least one variant is in the keydb for those who are waiting.
Mine appears to be the variant that's already in the keydb. Sweet!
Mine wouldn't open either.
This is my file: MKB20_v77_Dune-_Part_Two_1B3E
The public KEYDB.cfg file contains six entries for this title:
So if you download and copy this KEYDB.cfg into your .MakeMKV/ directory (where MakeMKV also writes its .tgz dump files) then there's a good chance that MakeMKV will then be able to read your disk.
0xDDCBF0DAE2BFA9C8338A24C2B677D8DE71B2D459 = DUNE_PART_TWO (Dune: Part Two) | D | 2024-03-23
0xD99300A2502F04EE36A876F335D5D517AA21868A = DUNE_PART_TWO (Dune: Part Two) | D | 2024-02-24
0x23E4860F58959E278C06A1ED15D4426CB886CBF7 = DUNE_PART_TWO (Dune: Part Two) | D | 2024-03-27
0xCF8A6E13143C29E83F1D4F1CD1AB3B3BF38F9618 = DUNE_PART_TWO (Dune: Part Two) | D | 2024-02-24
0xF4A9C83C2A9672F74F812CADFA326E292FD0F57B = DUNE_PART_TWO (Dune: Part Two) | D | 2024-02-24
0x18849105F0B2C537A31C77E100DEC1C4CEB3D920 = DUNE_PART_TWO (Blu-ray) | D | 2024-04-09
So lets say I've downloaded that file and found the directory with my .tgz dumps... What do I do to make this work. I tried extracting the file into the directory but all I got was a notepad file with a bunch of names and digits.
And did you try opening the disc again after extracting the KEYDB.cfg file into your MakeMKV data directory? That's all the file is...a dump of discIDs and their respective keys.
I just submitted
(Probably the german release)
MKB20_v77_DUNE_PART_TWO_4C56.tgz
My UK version showed up this morning. Submitted MKB20_v77_Dune-_Part_Two_B748.tgz
I just submitted MKB20_v77_Dune-_Part_Two_BBAA.tgz (Australian 4K steelbook limited edition)
I downloaded the latest KEYDB file, but it still gave a "volume key unknown" error.
Hopefully the key will be added soon.
