watching a blu-ray disc
hiacedrifter
#1 Post by hiacedrifter » Mon May 06, 2024 5:37 am
Is there a way to use makemkv/vlc to watch a blu-ray, from the disc rather than ripping it? I have a few discs with numerous extras etc which I would like to watch as they are, without ripping.
Re: watching a blu-ray disc
#2 Post by Billycar11 » Mon May 06, 2024 8:07 am
yeah enable vlc integration in makemkv settings
hiacedrifter
#3 Post by hiacedrifter » Sat May 11, 2024 2:41 pm
Thanks, I've checked and it was already enabled.
When i try to play a blu-ray in vlc I get an error:
Blu-ray error:
This Blu-ray Disc needs a library for AACS decoding, and your system does not have it.
Your input can't be opened:
VLC is unable to open the MRL 'bluray:///E:\'. Check the log for details.
Any ideas? I did try a solution online ages ago which involved downloading a file and placing in a certain folder, but that didn't work.
jinx100
#4 Post by jinx100 » Sat May 11, 2024 10:39 pm
In the Windows version of VLC be sure to select "Open Disc" and that the Blu-Ray (not DVD) button is selected. Then just select the optical drive. You may need to have JAVA installed to view the disc extras.
hiacedrifter
#5 Post by hiacedrifter » Mon May 13, 2024 7:23 pm
Still getting the same error:
Blu-ray error:
VLC is unable to open the MRL 'bluray:///E:/'. Check the log for details.
MrPenguin
#6 Post by MrPenguin » Mon May 13, 2024 7:46 pm
Blu-ray error:
I may be reaching here, but.... does your VLC installation include libaacs.dll?
I don't use Windows myself, but I suspect these people do.
hiacedrifter
#7 Post by hiacedrifter » Mon May 13, 2024 8:04 pm
Blu-ray error:
That library (and those instructions) ring a bell ... that must be what i tried previously. i will persevere! At the mo i have a sony blu-ray player on my desk, next to my PC which has a blu-ray drive!
