Dune Part 2 Dump Submitted
xsoldier
Post by xsoldier »
Dune 2 won't rip "The volume key is unknown for this disc - video can't be decrypted"
Re: Dune Part 2 Dump Submitted
A note that including the file name submitted would be helpful for others. Each potential key needed is based on a calculated value, which is identified at the end of the file name.
amitre2
Post by amitre2 »
Yesterday, I submitted the file "MKB20_v77_Dune-_Part_Two_13B6". Hope it helps ! :D
xsoldier
Post by xsoldier »
That's good to know! This is the file name: MKB20_v77_Dune-_Part_Two_1B3E
Commander Shepard
Post by Commander Shepard »
Submitted today "MKB20_v77_Dune-_Part_Two_1B3E.tgz"
Post by SamuriHL »
Mine's coming tomorrow. Such a good movie. I think at least one variant is in the keydb for those who are waiting.
Post by SamuriHL »
Mine appears to be the variant that's already in the keydb. Sweet!
philb1701
Post by philb1701 »
Mine wouldn't open either.
This is my file: MKB20_v77_Dune-_Part_Two_1B3E
MrPenguin
Post by MrPenguin »
The public KEYDB.cfg file contains six entries for this title:
0xDDCBF0DAE2BFA9C8338A24C2B677D8DE71B2D459 = DUNE_PART_TWO (Dune: Part Two) | D | 2024-03-23
0xD99300A2502F04EE36A876F335D5D517AA21868A = DUNE_PART_TWO (Dune: Part Two) | D | 2024-02-24
0x23E4860F58959E278C06A1ED15D4426CB886CBF7 = DUNE_PART_TWO (Dune: Part Two) | D | 2024-03-27
0xCF8A6E13143C29E83F1D4F1CD1AB3B3BF38F9618 = DUNE_PART_TWO (Dune: Part Two) | D | 2024-02-24
0xF4A9C83C2A9672F74F812CADFA326E292FD0F57B = DUNE_PART_TWO (Dune: Part Two) | D | 2024-02-24
0x18849105F0B2C537A31C77E100DEC1C4CEB3D920 = DUNE_PART_TWO (Blu-ray) | D | 2024-04-09
So if you download and copy this KEYDB.cfg into your .MakeMKV/ directory (where MakeMKV also writes its .tgz dump files) then there's a good chance that MakeMKV will then be able to read your disk.
georgemooney7
Post by georgemooney7 »
So lets say I've downloaded that file and found the directory with my .tgz dumps... What do I do to make this work. I tried extracting the file into the directory but all I got was a notepad file with a bunch of names and digits.
Post by SamuriHL »
And did you try opening the disc again after extracting the KEYDB.cfg file into your MakeMKV data directory? That's all the file is...a dump of discIDs and their respective keys.
GFly91
Post by GFly91 »
Key submitted to svq@makemkv.com
MKB20_v77_Dune-_Part_Two_CE02.tgz
LLukas22
Post by LLukas22 »
I just submitted
MKB20_v77_DUNE_PART_TWO_4C56.tgz
(Probably the german release)
KingBoo
Post by KingBoo »
My UK version showed up this morning. Submitted MKB20_v77_Dune-_Part_Two_B748.tgz
ivarh
Post by ivarh »
I just submitted MKB20_v77_Dune-_Part_Two_BBAA.tgz (Australian 4K steelbook limited edition)
I downloaded the latest KEYDB file, but it still gave a "volume key unknown" error.
Hopefully the key will be added soon.
