Queen Rock Montreal
randysolares
Queen Rock Montreal
Queen Rock Montreal 4K
Wide and Full Screen
Re: Queen Rock Montreal
What is the name of the dump files you submitted? Posting that info helps other people know if they should submit their dumps as well.
Just submitted mine
Queen - Rock Montreal + Live Aid
Disc 1:
Disc 2:
Disc 1:
MKB20_v77_00602458843149_DAB0.tgzCode: Select all
MKB20_v77_00602458843156_11FE.tgz-
randysolares
Thanks @bman7bman7 wrote: ↑Sat May 11, 2024 12:18 amJust submitted mine
Disc 1:Disc 2:Code: Select all
I thought I attached the files don't know where they went.
Attaching files doesn't work. Putting the file name in the message does, after you email the file to svq@makemkv.com for submission. It's actually the file name that us "normal people" need; Mike's the one that needs the .TGZ file.
randysolares
Thank you sir for the info.Woodstock wrote: ↑Sat May 11, 2024 4:32 pmAttaching files doesn't work. Putting the file name in the message does, after you email the file to svq@makemkv.com for submission. It's actually the file name that us "normal people" need; Mike's the one that needs the .TGZ file.
Mine is ripping now--thanks to the MakeMKV team!
Struggling with this one which comes up as 'The volume key is unknown for this disc - video can't be decrypted' - AACS file attached.
Can anyone help with this please?
Did you see:
after submitting the dump, wait patiently. When the dump has been processed, MakeMKV will automagically download the key.Woodstock wrote:
Thanks, have submitted the file
In my case, after sent email to svq@makemkv.com for my dump files, I got only 2 HashCheck Error.
Before sending TGZ dump files, I got 347 HashCheck Errors.. Almost 345 errors were reduced.
But Queen 4k uhd won't rip from now due to the 2 hashcheck error.
Is there any solution for this issue??
My ODD is BP60NB10(FW 1.02)
Makemkv 1.17.7
Makemkv 1.17.7
clean the discb1ue21 wrote: ↑Mon May 20, 2024 12:30 amIn my case, after sent email to svq@makemkv for my dump files I got 2 HashCheck Error.
Before sending TGZ file, I got 347 HashCheck Error..
Anyway.. Queen 4k uhd won't rip from now due to 2 hashcheck error.![]()
Makemkv 1.17.7
replace the disc
clean the drive laser
replace drive with a pioneer with old FW
Thank you for your reply.Billycar11 wrote: ↑Mon May 20, 2024 2:22 amclean the discb1ue21 wrote: ↑Mon May 20, 2024 12:30 amIn my case, after sent email to svq@makemkv for my dump files I got 2 HashCheck Error.
Makemkv 1.17.7
replace the disc
I have already cleaned and replaced disc and other UHD discs have been ripping without error
Can I get pioneer ODD model name for Queen 4K ripping?
This is the error I am getting for this disc - have cleaned it etc. and submitted the file. This is the only disc I have had an error with for years!
This just means that MakeMKV doesn't have the Volume Unique Key (VUK) for this disk yet. What are the file names for the .tgz dump files that MakeMKV has generated for you? Do they match the names of any of those dump files that other people in this thread have already emailed to svq@makemkv.com?
The only way to generate the VUKs you need is to analyse those dump files.
