Queen Rock Montreal
randysolares
Queen Rock Montreal
#1 Post by randysolares » Fri May 10, 2024 8:37 pm
Queen Rock Montreal 4K
Wide and Full Screen
Re: Queen Rock Montreal
#2 Post by dcoke22 » Sat May 11, 2024 12:10 am
randysolares wrote: Fri May 10, 2024 8:37 pm Queen Rock Montreal 4K
What is the name of the dump files you submitted? Posting that info helps other people know if they should submit their dumps as well.
bman7
#3 Post by bman7 » Sat May 11, 2024 12:18 am
Just submitted mine
Queen - Rock Montreal + Live Aid
Disc 1:
MKB20_v77_00602458843149_DAB0.tgz
Disc 2:
MKB20_v77_00602458843156_11FE.tgz
randysolares
#4 Post by randysolares » Sat May 11, 2024 4:21 pm
bman7 wrote: Sat May 11, 2024 12:18 am Just submitted mine
Disc 1:
Disc 2:
Thanks @bman7
I thought I attached the files don't know where they went.
#5 Post by Woodstock » Sat May 11, 2024 4:32 pm
Attaching files doesn't work. Putting the file name in the message does, after you email the file to svq@makemkv.com for submission. It's actually the file name that us "normal people" need; Mike's the one that needs the .TGZ file.
randysolares
#6 Post by randysolares » Sat May 11, 2024 4:39 pm
Woodstock wrote: Sat May 11, 2024 4:32 pm Attaching files doesn't work. Putting the file name in the message does, after you email the file to svq@makemkv.com for submission. It's actually the file name that us "normal people" need; Mike's the one that needs the .TGZ file.
Thank you sir for the info.
vcolfari
#7 Post by vcolfari » Sun May 12, 2024 9:08 pm
Mine is ripping now--thanks to the MakeMKV team!
westhamm
#8 Post by westhamm » Sun May 19, 2024 11:33 am
Struggling with this one which comes up as 'The volume key is unknown for this disc - video can't be decrypted' - AACS file attached.
Can anyone help with this please?
#9 Post by d00zah » Sun May 19, 2024 12:33 pm
westhamm wrote: Sun May 19, 2024 11:33 am Struggling with this one which comes up as 'The volume key is unknown for this disc - video can't be decrypted' - AACS file attached.
Did you see:
after submitting the dump, wait patiently. When the dump has been processed, MakeMKV will automagically download the key.
westhamm
#10 Post by westhamm » Sun May 19, 2024 11:11 pm
Thanks, have submitted the file
b1ue21
#11 Post by b1ue21 » Mon May 20, 2024 12:30 am
In my case, after sent email to svq@makemkv.com for my dump files, I got only 2 HashCheck Error.
Before sending TGZ dump files, I got 347 HashCheck Errors.. Almost 345 errors were reduced.
But Queen 4k uhd won't rip from now due to the 2 hashcheck error. :(
Is there any solution for this issue??
My ODD is BP60NB10(FW 1.02)
Makemkv 1.17.7
#12 Post by Billycar11 » Mon May 20, 2024 2:22 am
b1ue21 wrote: Mon May 20, 2024 12:30 am In my case, after sent email to svq@makemkv for my dump files I got 2 HashCheck Error.
Before sending TGZ file, I got 347 HashCheck Error..
Anyway.. Queen 4k uhd won't rip from now due to 2 hashcheck error. :(
Makemkv 1.17.7
clean the disc
replace the disc
clean the drive laser
replace drive with a pioneer with old FW
b1ue21
#13 Post by b1ue21 » Mon May 20, 2024 3:13 am
Billycar11 wrote: Mon May 20, 2024 2:22 am
Makemkv 1.17.7
clean the disc
replace the disc
Thank you for your reply.
I have already cleaned and replaced disc and other UHD discs have been ripping without error
Can I get pioneer ODD model name for Queen 4K ripping?
westhamm
#14 Post by westhamm » Mon May 20, 2024 10:31 am
This is the error I am getting for this disc - have cleaned it etc. and submitted the file. This is the only disc I have had an error with for years!
MrPenguin
#15 Post by MrPenguin » Mon May 20, 2024 11:13 am
westhamm wrote: Mon May 20, 2024 10:31 am The volume key is unknown for this disc - video can't be decrypted
This just means that MakeMKV doesn't have the Volume Unique Key (VUK) for this disk yet. What are the file names for the .tgz dump files that MakeMKV has generated for you? Do they match the names of any of those dump files that other people in this thread have already emailed to svq@makemkv.com?
The only way to generate the VUKs you need is to analyse those dump files.
