Dumps Submitted - The Crow, Mean Girls 2004
FootFungus07
#1 Post by FootFungus07 » Sat Apr 27, 2024 12:39 pm
The Crow 4K TGZ
MKB20_v77_The_Crow_(Remastered)_5F0C.tgz
Mean Girls 2004 TGZ
MKB20_v77_Mean_Girls_-_Remastered_7972.tgz
scorp508
Re: Dumps Submitted - The Crow, Mean Girls 2004
#2 Post by scorp508 » Mon May 06, 2024 1:51 pm
I'm jealous you have your copy of The Crow early, but hopefully this means I don't have to wait to rip mine once it arrives. :D
#3 Post by SamuriHL » Mon May 06, 2024 2:12 pm
I'm waiting for my Crow disc, as well. There's an entry for a variant of it in the keydb already so it might work on this version possibly. Worth a try. I pray mine comes tomorrow.
#4 Post by SamuriHL » Tue May 07, 2024 5:59 pm
MakeMKV supported my Crow variant out of the box which was nice. I don't have the MakeMKV dump filename, obviously but I would imagine the one posted above probably works now, as well.
scorp508
#5 Post by scorp508 » Tue May 07, 2024 6:20 pm
Mine copied fine a few moments after Amazon dropped it off today. :) Thank you!
PunisherNC
#6 Post by PunisherNC » Tue May 07, 2024 10:11 pm
my copy of The Crow will not rip
The volume key is unknown for this disc - video can't be decrypted.
Bregur7
#7 Post by Bregur7 » Thu May 09, 2024 6:06 am
My copy won't rip either. I am getting this type of error until it gives up:
The source file '/BDMV/STREAM/00294.m2ts' is corrupt or invalid at offset 10689878016, attempting to work around
#8 Post by Billycar11 » Thu May 09, 2024 1:59 pm
That from the disc or drive not a key issue
Clean the disc with a damp lint free cloth and dry with another
And give the drive a full power off LG and Asus drives greatly benefit from reboots after a read errors some times it's even required
Bregur7
#9 Post by Bregur7 » Thu May 09, 2024 3:27 pm
Thank you for your reply and advice. Bummer on my hands in this case. Tried cleaning and doing a cold boot and run into the same problem. My drive is an LG WH16NS40. VLC plays it, but it's blocky, not sure if that's possibly a related issue; I never really try playing discs directly, just rip em. I've had discs fail to rip before and tried again after some weeks or even months and they ended up working, maybe that will happen here too. Steelbook edition appears to be sold out at Amazon so I'm more or less stuck with the disc unless I trade down. We'll see--thank you again.
PunisherNC
#10 Post by PunisherNC » Wed May 15, 2024 7:42 pm
still no luck with "The Crow"...anyone else?
MrPenguin
#11 Post by MrPenguin » Wed May 15, 2024 10:19 pm
The public KEYDB.cfg file already contains these two entries:
0xB27D1723653632E0A9E87AF5EFC44A14E9694175 = CROW_REMASTERED (The Crow (Remastered)) | D | 2024-03-19
0xF012F06EF456229B9E7ED6D22CB3E1CEE67F2DCF = CROW_REMASTERED (The Crow (Remastered)) | D | 2024-02-15
No guarantees, but you could try downloading the latest KEYDB.cfg file and copying it into your .MakeMKV/ directory (where MakeMKV also writes the .tgz dump files), to see if either entry works for you.
PunisherNC
#12 Post by PunisherNC » Thu May 16, 2024 1:08 am
you are AWESOME!!! That worked like a charm!!!
GasmaskAvenger
#13 Post by GasmaskAvenger » Sun May 19, 2024 3:19 pm
Wow, that really did work for me too. Thank you so much!
