Heh, svq@makemkv.com isn't my email address. It's MakeMKV's "UHD processing queue"
The Abyss 4K
robert.gregory
Re: The Abyss 4K
Successfully ripped "The Abyss" 4k, FINALLY!
Purchased copy from Amazon, used an LG WH16NS60 fw 1.03 on MakeMKV version 1.17.6 (latest)
CalicoSkies
Re: The Abyss 4K
Did that copy of The Abyss have the stacked discs or the additional "page" inside the blu-ray case with each disc attached individually?robert.gregory wrote: Mon Apr 29, 2024 6:24 pm Successfully ripped "The Abyss" 4k, FINALLY!
robert.gregory
Re: The Abyss 4K
Actually, the 4k disc was in fact stacked on top of the extra feature disc, no different from other copies I tried. No additional "3rd" page in the case.CalicoSkies wrote: Mon Apr 29, 2024 6:30 pmDid that copy of The Abyss have the stacked discs or the additional "page" inside the blu-ray case with each disc attached individually?robert.gregory wrote: Mon Apr 29, 2024 6:24 pm Successfully ripped "The Abyss" 4k, FINALLY!
CalicoSkies
Re: The Abyss 4K
Interesting.. My 3rd copy, which finally ripped successfully, had a 3rd page in the case with each disc attached individually, with no stacking.robert.gregory wrote: Mon Apr 29, 2024 6:43 pmActually, the 4k disc was in fact stacked on top of the extra feature disc, no different from other copies I tried. No additional "3rd" page in the case.CalicoSkies wrote: Mon Apr 29, 2024 6:30 pmDid that copy of The Abyss have the stacked discs or the additional "page" inside the blu-ray case with each disc attached individually?robert.gregory wrote: Mon Apr 29, 2024 6:24 pm Successfully ripped "The Abyss" 4k, FINALLY!
Re: The Abyss 4K
So what "did it" for you in the end? Replacement disks? A new drive? Sacrificing a ripe mango to Cthulhu...?
robert.gregory
Re: The Abyss 4K
So, in the beginning ( days after release ), I purchased two copies. the first copy, from target, failed to rip, went through return process and it ended up being refunded... not only that, they told me to keep the movie "on them" no need to send it back... hmmm. Basically, they could not replace it, as per policy, so they just refunded the money. nice!MrPenguin wrote: Mon Apr 29, 2024 6:49 pmSo what "did it" for you in the end? Replacement disks? A new drive? Sacrificing a ripe mango to Cthulhu...?
then I purchased the second copy from walmart, same thing happened, same response. refunded money, keep the movie.
so, I sat with two copies of the abyss, with only the ability to rip the HD/2k, which btw worked for me, as I was happy to have that... especially "for free", waiting all these years, really did not give a hoot about the 4k, the HD/2k was resolute enough. win win, right?
I ended up giving one of my friends the 2nd copy so he could enjoy at least the HD/2k.
btw, he said his 4k player could not play the 4k disc. hmmm. someone messed up somewhere.
out of pocket at this point was $0.00, due to refunds.
at any rate, watching this thread, seeing all the responses of success with newer discs, I thought I'd try again.
last night, ordered the movie. it came today. I also updated MakeMKV, and tried again.
Success!
out of pocket total $34 and change.
not bad. I'll take it
robert.gregory
Re: The Abyss 4K
Update:
Successfully ripped extended version (4k). Using latest MakeMKV, on an LG WH16NS60. Three disc set with 4k edition still over special features. Purchased at Amazon yesterday.
JediSamReye
Re: The Abyss 4K
I have also been having issues with ripping this disc. 650+ 4k titles no issues, I have pretty good luck I am sure. But this one is a no go at the moment. Ordered it on amazon on 4/29 arrived last night. I watched the entire movie on my panasonic player last night no issues.
Came here to see if anyone had the issue, found 9 pages here.
I have a Asus BW-16D1HT with libre drive, still errors.
My set has the 4k disc stacked ontop of the special features disc.
I am attempting the full disc backup at the moment, if this fails then I am going to try the big index of keys mentioned before.
Re: The Abyss 4K
Success! Also Asus BW-16D1HT
Firmware 3.10
Re: The Abyss 4K
I just bought the Abyss 4k dvd and I am getting DEBUG: Code 0 at b,bam4B6}%_-3IRp:121263153
This is the information about my drive:
HL-DT-ST
Product: BD-RE WH16NS40
Revision: 1.02
Serial number: [redacted]
Firmware date: 2115-12-11 14:59
Highest AACS version: 77
Any help would be greatly appreciated. I have used this blu ray player for years without any issue, and this is the first disc it is failing to open for me.
HL-DT-ST
Revision: 1.02
Re: The Abyss 4K
Try gently cleaning the disc. Sometimes brand new discs seem to have a nearly invisible film on them left over from the manufacturing process.jruiz58 wrote: Tue Aug 13, 2024 10:49 pm I just bought the Abyss 4k dvd and I am getting DEBUG: Code 0 at b,bam4B6}%_-3IRp:121263153
briansemerick
Re: The Abyss 4K
getting this from The Abyss:
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..00200740100720..0AEFC5F059BA6CEAEB2F12EF2306CA3BC6E to device 'SPTI:\Device\CdRom0'
ddeconin@gmail.com
Re: The Abyss 4K
I had multiple failed attempts at making a backup.
Finally I was able to get it done by:
- Use backup functionality without decrypting
- Keep makemkv as foreground app whilst keeping my PC active by moving the app around every few minutes..
Perhaps this helps someone..
Re: The Abyss 4K
I know this is an old thread, but I am having the same issue. Finally backup up my stuff and so far this is the only problem I am having. May have to pick up another copy. I only want to backup the Extended Edition.
