Take it or leave it.
Recommendation for best (most reliable and versatile) LibreDrive for 2024?
Re: Recommendation for best (most reliable and versatile) LibreDrive for 2024?
Hi Coopervid,
thank you for your fast answer.
I need a few moments to decide.
Germans would not survive in countries where they shoot from the hip.
I'm in the U.S. and I'd like to know the best DVD/BluRay reader (I don't burn them). I don't care if it is internal or external.
If you are still sending out PMs I appreciate that very much. Thank you.
Hello. I'm in the same boat as everybody else here. Looking for the most reliable UHD capable slim 9.5mm internal optical drive to install in the small form factor PC that I'm building. It doesn't have to be the newest model because I can find just about anything on eBay. I just want a high quality reliable one, if they exist.
For reference, I live in the USA. The PC I'm building will have a Linux OS. Nobara specifically. My current PC is running Windows, but it's older than windows 10. I'm not going to 'upgrade' it just to flash an optical drive.
BU40NWandering_Smoke wrote: ↑Fri Apr 26, 2024 9:29 pmHello. I'm in the same boat as everybody else here. Looking for the most reliable UHD capable slim 9.5mm internal optical drive to install in the small form factor PC that I'm building. It doesn't have to be the newest model because I can find just about anything on eBay. I just want a high quality reliable one, if they exist.
Hey there,
I´m new to the Forum, but not to the Software. Have bought an Asus BW-16D1HT, but that doesn´t seem to be very good from what I have read here. Are there other drives that you could recommend to a german Blu-Ray enthusiast? 4K Ripping capabilities would be much appreciated, but long lasting is definitly my priority. Had an older LG just crap out in the middle of a rip, that was annoying... And this Asus drive seems pretty picky with my Blu-Rays, even after a downgrade to version 3.10.
Best regards
Jonny
Best regards
Jonny
If your in the USA the pioneer s13ubk is very good. I have them with old fw see below for detailsTheJonny272 wrote: ↑Sat Apr 27, 2024 11:24 amHey there,
Best regards
Jonny
Well, I´m a german guy from germany xD Any recommendations for drives, that are common in my country? 2016+ would be nice for the downgrade-options + I could look for a used one as they tend to cost anywhere from half to a third as much as new drives
Thank you.MartyMcNuts wrote: ↑Sat Apr 27, 2024 6:08 amBU40NWandering_Smoke wrote: ↑Fri Apr 26, 2024 9:29 pmHello. I'm in the same boat as everybody else here. Looking for the most reliable UHD capable slim 9.5mm internal optical drive to install in the small form factor PC that I'm building. It doesn't have to be the newest model because I can find just about anything on eBay. I just want a high quality reliable one, if they exist.
Pioneer drives are the best. Any customer we have sold to will verify this. Please see the link below.
viewtopic.php?f=20&t=19387
The UHD Friendly Drive Team
Asmcom
Asmcom
Click Here! viewtopic.php?f=20&t=19387
Thanks for the direction, I will look into Pioneers then Forgot to specifiy, that I´m a bit oldschool and still have, use and love PC cases with 5 1/4 Bays. Therefor, I´m on the lookout for a 5 1/4 Driveasmcom wrote: ↑Sun Apr 28, 2024 8:35 amPioneer drives are the best. Any customer we have sold to will verify this. Please see the link below.
Asmcom
