King Kong (1976) 4K UHD
quequeg
#1 Post by quequeg » Wed Apr 10, 2024 9:15 pm
Unable to decrypt newly released 4K UHD of King Kong (1976).
Sent MKB20_v77_King_Kong_3DC8.tgz file to SVQ.
Cheers,
Queequeg
stevez167
Re: King Kong (1976) 4K UHD
#2 Post by stevez167 » Sat Apr 13, 2024 5:24 pm
Waiting for this one too.
kyrunner
#3 Post by kyrunner » Mon Apr 15, 2024 11:19 am
Is this working for anyone yet
bbraskey67
#4 Post by bbraskey67 » Tue Apr 16, 2024 5:49 pm
Just got my copy. Not working yet.
MrPenguin
#5 Post by MrPenguin » Tue Apr 16, 2024 7:29 pm
FWIW the latest KEYDB.cfg contains an entry for this MKBv77 disk:
0x32EC72B9A3999996A17CB7EF938E1AEFF96CEAA3 = King Kong (King Kong) | D | 2024-01-03
so if SHA1(AACS/Unit_Key_RO.inf) for your disk is 0x32EC72B9A3999996A17CB7EF938E1AEFF96CEAA3 then copying this KEYDB.cfg file into your .MakeMKV directory should allow MakeMKV to rip it.
Edit: If your disk's SHA1(AACS/Unit_Key_RO.inf) isn't 0x32EC72B9A3999996A17CB7EF938E1AEFF96CEAA3, MakeMKV still cannot rip it and you're desperate, then there's a slim chance that I might be able to help if you PM me.
quequeg
#6 Post by quequeg » Wed Apr 17, 2024 12:47 pm
Not working for me, as yet.
Didn't try the KEYDB.cfg manual update business (actually not even sure where that file is on my Mac). Not sure I want to get into that. I think I'll just wait until the update happens as it normally does. Has always worked in the past.
Cheers,
Queequeg
MrPenguin
#7 Post by MrPenguin » Wed Apr 17, 2024 2:25 pm
The idea is that you'd download a brand new KEYDB.cfg file from http://fvonline-db.bplaced.net and then copy it into your .MakeMKV directory. No need to edit any existing file, although I think the MacOS filesystem is case-sensitive and so you might need to ensure that the new file is literally named KEYDB.cfg.
fivestarplus
#8 Post by fivestarplus » Wed Apr 17, 2024 6:13 pm
I just tried the keydb.cfg file and it didn't work. I copied it in the "Programs Files (x86)/MakeMKV" directory. MakeMKV is listing the protection as "AACS2.0/C v77". Below is the MakeMKV output.
MakeMKV v1.17.6 win(x64-release) started
Debug logging enabled, log will be saved as C:\Users\UM790/MakeMKV_log.txt
Using LibreDrive mode (v01.0 id=E9BA8ECC61EF)
Saved AACS dump file as C:\Users\UM790/.MakeMKV/MKB20_v77_King_Kong_3DC8.tgz
DEBUG: Code 0 at g1G,9/u[_c:!rg}]:213132721
DEBUG: Code 0 at g1G,9/u[_c:!rg}]:213131341
MrPenguin
#9 Post by MrPenguin » Wed Apr 17, 2024 6:24 pm
Thanks for trying, but you need to copy KEYDB.cfg into the C:\Users\UM790/.MakeMKV directory, i.e. the same directory where MakeMKV wrote MKB20_v77_King_Kong_3DC8.tgz.
#10 Post by d00zah » Wed Apr 17, 2024 6:25 pm
Default path (Windows) for the MakeMKV data directory is:
%UserProfile%\.MakeMKV
unless changed in Preferences. Drop keydb.cfg there.
fivestarplus
#11 Post by fivestarplus » Wed Apr 17, 2024 6:44 pm
Since I am using the 64-bit version, I also copied keydb.cfg to the "Program Files/MakeMKV" directory and restarted MakeMKV. Still the same results. The blu-ray disc works ok. It's only the UHD 4K disc that is having an issue.
MrPenguin
#12 Post by MrPenguin » Wed Apr 17, 2024 6:53 pm
Yes, MakeMKV cannot find the key for this particular disk. There may still be something I can do though - check PM.
fivestarplus
#13 Post by fivestarplus » Wed Apr 17, 2024 6:56 pm
Thanks, I didn't see your response previously. I copied the keydb.cfg file to the directory you said and restarted MakeMKV. MakeMKV is in the process of ripping this UHD 4K disc now. Will be done in about an hour.
MrPenguin
#14 Post by MrPenguin » Wed Apr 17, 2024 7:02 pm
If the current KEYDB.cfg works for you then I guess my job here is done :mrgreen:.
EventDriven
#15 Post by EventDriven » Thu Apr 18, 2024 3:09 am
Using the instructions here I installed FindVUK, ran synchronize (twice, once after setting PreferredLanguages = eng in the FindVUK.ini file), copied the keydb.cfg file from C:\Users\[YOUR USER NAME]\AppData\Roaming\aacs over as KEYDB.cfg to C:/Users/[YOUR USER NAME]/.MakeMKV, and it ripped no problem.
