The Fugitive 4K
G.P.L.
The Fugitive 4K
Post by G.P.L. »
Has no one else had trouble ripping The Fugitive from the 4K disc?
I get the following response from MakeMKV:
MakeMKV v1.17.6 win(x64-release) started
Debug logging enabled, log will be saved as C:\Users\Gary/MakeMKV_log.txt
Using LibreDrive mode (v06.3 id=0FA242DD4D0B)
Saved AACS dump file as C:/Users/Gary/.MakeMKV/MKB20_v77_The_Fugitive_1B34.tgz
DEBUG: Code 0 at g1G,9/u[_c:!rg}]:213132721
DEBUG: Code 0 at g1G,9/u[_c:!rg}]:213131341
This disc is from Amazon Canada, and has an ID of: AF785AAEB6E21E9E [THE_FUGITIVE], but I believe it's the same disc as the one from the U.S. Just the packaging is different.
I've attached the AACS dump file. Hopefully it won't appear twice.
The same message occurs with both of my ASUS BW-16D1HT drives, one internal and one in a USB enclosure.
Any help would be much appreciated.
Thanks.
Gary
Re: The Fugitive 4K
You've got to email that dump into svq@makemkv.com.
UHD FAQ
G.P.L.
Re: The Fugitive 4K
Post by G.P.L. »
dcoke22 wrote: Thu Apr 11, 2024 4:45 pm You've got to email that dump into svq@makemkv.com.
UHD FAQ
Thanks for the reply.
Yes, I did that, and tried ripping again several times since then with no luck.
I confirmed that the disc is not faulty by using AnyDVD to copy the entire contents to a hard drive.
At least I don't have to return it to Amazon.
MrPenguin
Re: The Fugitive 4K
Post by MrPenguin »
How did you compute the disk's "ID" of 0xAF785AAEB6E21E9E? It's too short to be what KEYDB.cfg would consider to be a disk ID value, which is computed as:
SHA1(AACS/Unit_Key_RO.inf)
Is that actually its "Volume ID"?
If you become desperate, there may be a way of getting MakeMKV to decrypt using the public KEYDB.cfg file. But you will need to compute the SHA1 value of its AACS/Unit_Key_RO.inf file at the very least.
Re: The Fugitive 4K
G.P.L. wrote: Thu Apr 11, 2024 10:32 pm I confirmed that the disc is not faulty by using AnyDVD to copy the entire contents to a hard drive.
You can use MakeMKV's backup option to create an encrypted backup before a decryption key is available to make sure the disc is readable.
G.P.L.
Re: The Fugitive 4K
Post by G.P.L. »
MrPenguin wrote: Thu Apr 11, 2024 11:02 pm How did you compute the disk's "ID" of 0xAF785AAEB6E21E9E? It's too short to be what KEYDB.cfg would consider to be a disk ID value, which is computed as:
The disc ID is what was reported in DVD Profiler when it read the disc.
When I right-click the AACS/Unit_Key_RO.inf file, I get the following:
Size: 65536 bytes (64 KiB)
SHA1: E8AF137E72078A64A64A68BAAD1493BE1E5DEBF2
But I have no idea how to enter that into the KEYDB.cfg file.
When I open the KEYDB.cfg file, nothing seems very obvious to me in terms of the format it uses.
Any idea how I enter the SHA1: E8AF137E72078A64A64A68BAAD1493BE1E5DEBF2 information, and anything else required, in the KEYDB.cfg file?
If I knew that, I assume I could decrypt discs myself using MakeMKV (I have a lifetime license), which could turn out to be very convenient.
Is there maybe a page on the forum somewhere about doing this?
I'm willing to give it a shot, after backing up the current copy of KEYDB.cfg, of course.
MrPenguin
Re: The Fugitive 4K
Post by MrPenguin »
Unfortunately, it's never that easy.
Check PM
taylorwmj
Re: The Fugitive 4K
Post by taylorwmj »
Having the same issue essentially 3 months later on my US copy of "The Fugitive" UPC 883929813889. Submitted the dump over a week ago and still the disk can't open. Using paid/registered v1.17.6 on Linux.
Is there some other process I can use to submit or get this to work?
MrPenguin
Re: The Fugitive 4K
Post by MrPenguin »
taylorwmj wrote: Sun Jul 14, 2024 2:28 pm Having the same issue essentially 3 months later on my US copy of "The Fugitive" UPC 883929813889. Submitted the dump over a week ago and still the disk can't open. Using paid/registered v1.17.6 on Linux.
Can you post the name of the dump file here please?
You could also try downloading the latest KEYDB.cfg file, copying it into MakeMKV's data directory (which is the same directory where MakeMKV wrote the .tgz dump file), and then restarting MakeMKV. (See these instructions for details.)
lfoust
Re: The Fugitive 4K
Post by lfoust »
I was able to rip this release successfully - here is how it mapped out: https://thediscdb.com/movie/the-fugitiv ... es/2024-4k
