Re: Pioneer firmware update February 2023
#196 Post by Billycar11 » Sun Apr 07, 2024 6:14 am
Krawk wrote: Sat Apr 06, 2024 9:10 pm So does it look like Pioneer won the battle?
No pioneer lost...
wyzxvnv
#197 Post by wyzxvnv » Sun Apr 07, 2024 8:41 pm
Billycar11 wrote: Sun Apr 07, 2024 6:14 am
No pioneer lost...
Unforunately, everybody lost.
Because entertainment industry is full of idiots who are thinking that everybody is a pirate we have to deal with stupid restrictions in form of DRM...
Pioneer lost because they cannibalized their sales and movies are just continued to be riped anyway with other drives.
We, as movie lovers lost because we have to use junk drives from LG instead of high quality Pioneer drives.
Nobody won.
Toscaclarinet
#198 Post by Toscaclarinet » Mon Apr 08, 2024 6:44 am
It's an even sillier decision on Pioneer's part given that the "official" UHD watching method is now pretty much dead in the water, since Cyberlink PowerDVD stopped supporting watching 4k discs as of September 2023 (itself a consequence of intel no longer supporting sgx). If they can no longer be used at all for 4k discs either officially or unofficially, there's basically no point buying pioneer drives and I have a feeling that we won't see any new drive models going forward.
rgkrgk
#199 Post by rgkrgk » Fri Apr 12, 2024 4:15 pm
I had my working S13-UBK die after 11 months and the Pioneer service was fantastic -- I had a new drive in <1 month. But it has 1.04...
Am I reading this all correctly that for 4k ripping, this is now dead and I need to get a new drive (i.e., not worth waiting)? Really unfortunate since this was an excellent drive.
ZachBird
#200 Post by ZachBird » Sat Apr 20, 2024 8:03 pm
Just built an AMD PC and wanted a nice UHD BluRay drive, so I bought an BDR-S13U-X. When I initially looked it up, what I read was that it should be good out of the box. Unfortunately mine came with FW rev 1.04. :P All that to say I'm cheering for you Mike! You're doing the lords work helping people enjoy their media in spite of the DRM dumpster fire. Thank you for the effort you put in to this. I hope you are successful in making the S13U-X viable again!
jd1337
#201 Post by jd1337 » Fri May 03, 2024 3:23 am
edit - Getting
Error Sorry, the board attachment quota has been reached.
So uploading elsewhere and will link below
https://file.io/lzXNvsZ4Xaoh
Just Adding the Dump from my Pioneer BD-RW BDR-XS07U that came with v1.03 firmware :(
And the firmwares I've found that I think contain the older firmware but throw an error when trying to update to them.
Everyone probably already has all these, but I'm taking the same approach as the UHD dumps when they dont work yet and adding it in case no1 else does somehow.
Maxpower
#202 Post by Maxpower » Thu May 23, 2024 4:21 am
rgkrgk wrote: Fri Apr 12, 2024 4:15 pm I had my working S13-UBK die after 11 months and the Pioneer service was fantastic -- I had a new drive in <1 month. But it has 1.04...
Mmmmh . . . (in hindsight) I wonder if swapping the printed circuit board (electronics) from the dead drive into a new drive might have given you back a functional unit?
Good chance the fault would be electro/mechanical rather than electronic. Posting this in case others have this experience.
Lehmeier
#203 Post by Lehmeier » Tue Jun 11, 2024 3:09 pm
Hello!
I bought a Pioneer BDR-S13U and would like to flash it so I can back up my UHD's.
But as I learnt, this is unfortunately not possible at the moment.
But I think it is good that you are taking care of this problem. I therefore wish you every success and that you manage to make it possible to back up the Bluray's / UHD's again as quickly as possible.
If you need the data, my Pioneer is a :
Drive information
OS device name: /dev/sr0
Producer: PIONEER
Product: BD-RW BDR-S13U
Revision: 1.04
Serial number: [redacted]
Firmware date: 2022-12-12
Bus encryption markings: 1B
Highest AACS version: 77
Firmware version: ID43
Disc information
Label: BLACK_ADAM
Timestamp: 2022-11-11 11:00:40
Protection: AACS2.0/C v77
Data capacity: 60.32 Gb
Disc type: BD-ROM UHD
Number of layers: 2
Bus encryption markings: 80
Thank you in advance.
Yours sincerely, R.Lehmeier
Translated with DeepL.com (free version)
#204 Post by Coopervid » Fri Jun 14, 2024 10:11 pm
No chance currently to flash this drive. Return it if you can.
CSManiac33
#205 Post by CSManiac33 » Sun Jun 16, 2024 11:03 pm
Okay so I noticed that my drive now has a 1.05 firmware update dated Sep 20, 2023 (BDR-S13U-X). I assume this did not fix the the LibreDrive issue? Also I currently have a drive with 1.02 firmware, I found the installer with for 1.03 firmware. I know 1.04 firmware does not work with LibreDrive but am wondering if I could update to 1.03 and still use it. Figured I would ask before actually doing it.
MrPenguin
#206 Post by MrPenguin » Sun Jun 16, 2024 11:29 pm
CSManiac33 wrote: Sun Jun 16, 2024 11:03 pm Okay so I noticed that my drive now has a 1.05 firmware update dated Sep 20, 2023 (BDR-S13U-X). I assume this did not fix the the LibreDrive issue? Also I currently have a drive with 1.02 firmware, I found the installer with for 1.03 firmware. I know 1.04 firmware does not work with LibreDrive but am wondering if I could update to 1.03 and still use it. Figured I would ask before actually doing it.
The first rule of a Pioneer drive is "Do Not Update its Firmware".
The second rule of a Pioneer drive is also "Do Not Update its Firmware".
The third rule of a Pioneer drive is "Check whether its firmware date is December 2022 or later", because these drives do not work with LibreDrive and probably never will. They also cannot be downgraded to use earlier firmware.
Assume that higher firmware versions correspond to later firmware dates.
#207 Post by Coopervid » Sun Jun 16, 2024 11:53 pm
Do not f...ing update any Pioneer firmware. All bogus reasons in those descriptions that render your drive unusuable for UHD discs.
CSManiac33
#208 Post by CSManiac33 » Mon Jun 17, 2024 2:02 am
MrPenguin wrote: Sun Jun 16, 2024 11:29 pm
The 1.03 firmware was updated on November 22, 2022 on the website (using wayback machine which is why I asked) but yeah better play it safe since 1.04 is the December 2022 firmware (but on the website it was updated on Jan 30, 2023) . Guess another question. Would downloading the Drive Utility tool force a firmware update or not?
qops1981
#209 Post by qops1981 » Tue Jun 18, 2024 5:07 pm
I posted in another Pioneer thread here, but then found this one. I am new to all this, but with my revision at 1.00, does that mean I can still flash mine? I also see Version ID23 at the bottom, so is that the 2023 one?
Current profile: DVD-ROM
Manufacturer: PIONEER
Product: BD-RW BDRUD03AS
Revision: 1.00
Serial number: *************
Firmware date: 2014-04-01
Highest AACS version: 50
Drive platform: Pioneer RS8510
Firmware version: ID23
#210 Post by Billycar11 » Tue Jun 18, 2024 9:54 pm
qops1981 wrote: Tue Jun 18, 2024 5:07 pm I posted in another Pioneer thread here, but then found this one. I am new to all this, but with my revision at 1.00, does that mean I can still flash mine? I also see Version ID23 at the bottom, so is that the 2023 one?
Revision: 1.00
No it's from 2014
Email me for a flasher for it see below
