Confusion about Pioneer BDR-X13E-S vs. BDR-X13E-X
fhw72
Post by fhw72 »
Hi @ll,
I'm still confused about the Pioneer drives and the nomenclature - especially these two:
BDR-X13E-S
BDR-X13E-X
I understand that "E" means European market and "S"/"X" differentiates betweens internal external. ok.
But what else?
From the Specs on the Pioneer site they should be UHD-Compatible? So I can read UHD (how?)
but cannot use Libredrive?
Apart from that they look different... Copper vs. Silver stripe. Is it just the look or are there other technical differences known?
https://pioneer-blurayodd.eu/products/b ... /index.php
Re: Confusion about Pioneer BDR-X13E-S vs. BDR-X13E-X
fhw72 wrote: Thu Apr 04, 2024 8:31 am Hi @ll,
BDR-X13E-S
BDR-X13E-X
But what else?
Don't buy any of these two as they come with firmware that makes it impossible to read or rip UHDs. You should buy from a seller in your region who has these drives with old firmware. Since you linked a EU web site you should check with asmcom.
the x13e-s is usb
the s13e-x is sata you got the model number wrong there
the ex/ux/jx all same have higher build quality and more sound deadening and have it all blacked out it not really worth it for the price difference.
but both of those drive need fw from before 12/22 or they wont work with makemkv and UHD
there is no way of downgrading them you must buy from a seller if you want one with old fw
fhw72
Post by fhw72 »
Thanks. Will check for a drive from one of the sellers.
Will there ever be a possibility go flash a higher firmware version without degrading UHD capabilites?
In the past they usually fixed some burning quality issues with newer media...
fhw72 wrote: Thu Apr 04, 2024 10:32 am Thanks. Will check for a drive from one of the sellers.
if the developer releases MK fw yes but we dont know when or if that is going to happen.
the pioneer stuff will always ruin it now sadly
DavoBR
Post by DavoBR »
Highly recommend asmcom. Just explain your setup and what you are looking for.
asmcom
Post by asmcom »
Coopervid wrote: Thu Apr 04, 2024 9:55 am
BDR-X13E-S
BDR-X13E-X
But what else?
Yes we have these from time to time, actually sold 5 of each today. We have a list of customers who have registered an interested when we acquire these drives.
Clare.
UHD Friendly Drive Team
zaqqaz6917
Post by zaqqaz6917 »
It is an amazing service the resellers are providing here selling the pioneer drives with older firmware. I imagine these drives must be extremely hard to acquire.
alninek
Post by alninek »
Hi everyone, I hope this is helpful. I'm trying to summarize the features of the Pioneer BDR-X13E/U/J - S/X drives.
Key:
E = European market
J = Japanese market
U = US market
S = External drive with USB interface
X = Internal drive with SATA interface
US Models:
BDR-X13U-S (US, external, USB): https://usa.pioneer/collections/optical ... bdr-x13u-s
Manual: https://images.salsify.com/images/nppz9 ... C8396A.pdf
BDR-X13U-X (US, internal, SATA): https://usa.pioneer/products/bdr-s13u-x
Manual: https://images.salsify.com/images/glj1m ... C8393B.pdf
Japanese Models:
BDR-X13J-S (Japan, external, USB): https://jpn.pioneer/ja/pcperipherals/bd ... dr-x13j-s/
Manual: https://jpn.pioneer/ja/support/manual/m ... m_id=17351
BDR-X13J-X (Japan, internal, SATA): https://jpn.pioneer/ja/pcperipherals/bd ... dr-x13j-x/
Manual: https://jpn.pioneer/ja/support/manual/m ... m_id=17701
European Models:
BDR-X13E-S (Europe, external, SATA): https://pioneer-blurayodd.eu/products/bdr-x13e-s/
Manual: https://pioneer-blurayodd.eu/products/i ... X13E-S.pdf
BDR-X13E-X (Europe, internal, SATA): https://pioneer-blurayodd.eu/products/bdr-s13e-x/
Manual: https://pioneer-blurayodd.eu/products/i ... S13E-X.pdf
Summary:
Based on the european manuals, the main difference between the models lies in the connection interface: SATA for internal drives and USB for external drives.
I haven't found any other significant differences, but please let me know if you find any.
Ulrich
Post by Ulrich »
Hi forum, I'm new to the topic and hoping for a quick reply, thanks.
I don't have a 4K BlueRay disc and would like to buy the BDR-X13EBK.
Can Makemkv read normal BlueRay discs from this device?
Ulrich wrote: Tue Jan 21, 2025 5:06 pm Hi forum, I'm new to the topic and hoping for a quick reply, thanks.
Yes, using MakeMKV it can read DVD and BD, jut not UHD (unless it happens to have older firmware that is pre 12/2022)
BillOne
Post by BillOne »
The new firmware (1.05) is now compatible?
BillOne wrote: Mon Mar 10, 2025 7:15 pm The new firmware (1.05) is now compatible?
With DVD & BD, yes. But not for UHD and cannot be downgraded.
zoom+slomo
Post by zoom+slomo »
MartyMcNuts wrote: Wed Jan 22, 2025 1:03 am
Sadly, this happened. https://www.flatpanelshd.com/news.php?s ... 1746788660 But were those external and internal Pioneer models about the most reliable BD drives available?
And which other makes/models might likely be the next best?
While I only have one UHD 4K BD disc and don't on buying other than 2K BDs, which Pioneer and/or next best make/model will play those 4k discs, using Makemkv?
zoom+slomo wrote: Sun Oct 19, 2025 2:39 am
Direct UHD disc playback is not recommended for any drive as you will wear out your drive a lot faster. Ripping with MakeMKV is recommended. For UHD compatibility, currently all Pioneer drives must have firmware that is pre 12/2022.
