R.I.P.D. UHD no Key
Osman_28
Re: R.I.P.D. UHD no Key
Oh ok good to know thanks I appreciate your reply, thought a week would be enough until a dump would be added
Osman_28
But you don't think It could be a disc problem?
Because there was another user who had the exact same dump file and he submitted it on November 13th.
No, the disc isn't the problem. Since you are getting the volume key not available message and you appear to be getting the hashed key updates it's just a waiting game.Osman_28 wrote: Thu Jan 04, 2024 9:15 pm But you don't think It could be a disc problem?
We also don't know if the other person was able to rip theirs...
It's only Mike generating them and we don't know if he's having a holiday or what...
Osman_28
Thank you so much I really appreciate your reply!MartyMcNuts wrote: Fri Jan 05, 2024 1:48 amNo, the disc isn't the problem. Since you are getting the volume key not available message and you appear to be getting the hashed key updates it's just a waiting game.Osman_28 wrote: Thu Jan 04, 2024 9:15 pm But you don't think It could be a disc problem?
I thought maybe I had some technical difficulties e.g. Drive or disk vise, because it’s my first time waiting so long for a key to be implemented, since the user I mentioned submitted it almost 2 Months ago.
Not sure If the developer got a huge load of dump files through Black Friday and Christmas time and also not sure how difficult it can be to generate a Volume Key.
I'm new to this stuff just started in Summer 2023 sorry if I’m bothering anyone.
Like you said it’s now just a waiting game
murx75
Very strange, MakeMKV still does not rip the disk for me...
Has anybody been able to backup the disk?
I have sent the file MKB20_v77_R_I_P_D_057F.tgz last Wednesday, but apparently many have done so before. Or is this another (German) disk version?
MrPenguin
There are two entries for a UHD disc like yours already in the public KEYDB.cfg file, which you can download from http://fvonline-db.bplaced.net and unpack into your .MakeMKV directory. Does either of these entries allow MakeMKV to decrypt your disc?
murx75
Thank you so much!
The keydb.cfg file did it! I was able to back the disk up. I thought the time for downloading these key files were over.
I got a number of strange problems recently with one drive not being able to rip the disk, making MakeMKV create the tgz-file, while the other did rip the disk. Not sure if this has been introduced with a recent release and/or if this is due to me mixing different drives (Pioneer & LG based) or because I have multiple instances of MakeMKV running in parallel on the same PC.
MrPenguin
To be fair, your disc would need to match one of these two entries in order for KEYDB.cfg to work for you:murx75 wrote: Wed Apr 03, 2024 6:22 pm The keydb.cfg file did it! I was able to back the disk up. I thought the time for downloading these key files were over.
0xFF3755D6278B23B0472FBF6D7E5FD74F9B3391B7 = RIPD_UPK1_GH (R.I.P.D.) | D | 2022-10-06
0x1B9D924C34C21DA6A3358D88DEF9F97CAB723CAC = RIPD_UPK1_GH (R.I.P.D.) | D | 2022-09-13But all the same, I would still recommend not dismissing KEYDB.cfg, because it might be able to help you if ever MakeMKV's key processing seems to have stalled.
VarHD
Submitted my dump today.
MrPenguin
I recommend also copying the latest KEYDB.cfg file into your .MakeMKV/ directory, just to see if it helps.
VarHD
Thanks, I forgot to post an update here. I did later check out the file and... it worked so problem solved for me. First time I had to download it manually, though, usually it seems to get the key on its own, but whatever - it worked so I'm happy
MrPenguin
I don't understand the Deep Magic behind MakeMKV's processing queue: sometimes it generates keys within days, and other times it takes weeksVarHD wrote: Wed Jun 19, 2024 4:17 pm Thanks, I forgot to post an update here. I did later check out the file and... it worked so problem solved for me. First time I had to download it manually, though, usually it seems to get the key on its own, but whatever - it worked so I'm happy![]()
There's no magic mystery. It's Mike. LOL Whenever he gets to it and posts a new hashed key update.
MrPenguin
I must assume that Mike has automated / delegated the processing queue to at least some degree. And that this particular disk has somehow fallen through the cracks.SamuriHL wrote: Wed Jun 19, 2024 6:17 pm There's no magic mystery. It's Mike. LOL Whenever he gets to it and posts a new hashed key update.
The other possibility is that the submitted tgz file is not usable for whatever reason. And yes, that is possible.
