Blu-ray Backup unplayable from SSD/HDD in VLC?
mas1701
Post by mas1701 »
Hi folks,
I've migrated my main work machine from Windows 10 Enterprise to Linux Mint 21.3. A great experience so far.
On Windows, I used MakeMKV and another solution for DVD and Blu-ray backups, so I could later play them from SSD/HDD in VLC or further process them with Handbrake.
Now, on Linux, it seems I have to rely on MakeMKV alone. No problem, as long as it works.
Today, I processed the first two Blu-ray discs and dumped them to harddisk. After that, although I told MakeMKV to decrypt the video files, VLC was unable to play any of these discs. The player just crashed. The video files themselves seem to be fine though, so single file playback works.
As far as I understand, it should work properly with VLC in Blu-ray mode. Libraries are installed. And it works with the backups I created when still working with Windows.
So far, I didn't configure anything for direct BD disc playback with VLC and frankly, I don't really need that.
Any hints why it does not work with the backups created with Linux? I know MakeMKV may require Java, but does it need a specific version like VLC?
I'm currently on MakeMKV v1.17.6 (Flatpak).
mas1701
Re: Blu-ray Backup unplayable from SSD/HDD in VLC?
Post by mas1701 »
Update:
Uninstalled Flatpak, compiled MakeMKV for Linux myself. Same version. Unfortunately, same problem persists. So it wasn't the Flatpak version's fault.
MrPenguin
Post by MrPenguin »
mas1701 wrote:
Wed Apr 03, 2024 4:05 pm
This is insufficient information to say anything about what your problem might be. Some things you might like to consider are:
- Does this crash produce a stack trace?
- What version of VLC are you using?
- What kind of graphics card does this machine have?
- Do you have the correct drivers installed for your graphics card?
- Does mpv play H.264 video correctly with hardware acceleration enabled?
- Have you tried disabling VLC's hardware acceleration?
For what it's worth, I can play ordinary Blu-Ray discs with menu support on Linux using VLC 3.0.20. (AMD graphics, Mesa 23.3.6).
mas1701
Post by mas1701 »
Thanks for replying.
As I mentioned above, it is NOT a VLC for Linux problem, since it plays anything flawlessly, UNLESS it is a Blu-ray dump created by MakeMKV for Linux.
VLC DOES play
a) any video file (I have thousands!) and
b) any Blu-ray dump created before I changed to Linux (dumps made with MakeMKV for Windows or Any***HD for Windows are playing fine).
It is clearly a problem with the Linux version of MakeMKV.
So we don't need to talk about debugging VLC, but debugging a MakeMKV problem. It seems the dumps produced with MakeMKV for Linux are corrupted somehow. As I also said, the raw m2ts files from these dumped Blu-rays DO play fine, but not the whole disc in Blu-ray mode. Which makes me think that the navigation or menu structures are damaged.
All your questions become irrelevant, because they are clearly focussing on the VLC part. For debugging VLC, I wouldn't even post in this forum.
Btw., I'm not using mpv for playback. But I tried. It plays normal video files, but it doesn't seem to support Blu-ray. And I need Blu-ray menu support including Java-based menus. VLC does that.
MrPenguin
Post by MrPenguin »
mas1701 wrote:
Fri Apr 05, 2024 8:42 am
VLC DOES play
VLC is an extremely complex piece of software, and I have no idea how Linux Mint has chosen to compile and configure it. You say it is VLC which is crashing, in which case the stack trace is always a useful place to start from because as a rule, applications are never supposed to crash.
Does VLC play a Blu-Ray correctly straight from disk, i.e. removing MakeMKV from the equation? It should be able to do that for any non-UHD Blu-Ray.
mas1701 wrote: It is clearly a problem with the Linux version of MakeMKV.
I successfully use the Linux version of MakeMKV in order to create disk back-ups of UHD Blu-Rays, and so there is nothing "clear" about this. For the record, I also successfully watch non-UHD Blu-Rays with Java-based menus on Linux using VLC. However, I would advise against using it to watch disk back-ups of UHD Blu-Rays because VLC 3.x doesn't support HDR.
mas1701 wrote: So we don't need to talk about debugging VLC, but debugging a MakeMKV problem.
You are making assumptions, which is unwise when debugging anything. Again, you say it is VLC which is crashing, for reasons still unknown.
mas1701 wrote: It seems the dumps produced with MakeMKV for Linux are corrupted somehow. As I also said, the raw m2ts files from these dumped Blu-rays DO play fine, but not the whole disc in Blu-ray mode. Which makes me think that the navigation or menu structures are damaged.
If the m2ts files play fine then it certainly sounds like MakeMKV has copied and decrypted them correctly to me. Have you remembered to install libbluray's JAR files? On Fedora, these JARs are packaged separately:
$ rpm -q libbluray-bdj --list
/usr/share/java/libbluray-awt-j2se-1.3.4.jar
/usr/share/java/libbluray-j2se-1.3.4.jar
mas1701 wrote: Btw., I'm not using mpv for playback. But I tried. It plays normal video files, but it doesn't seem to support Blu-ray. And I need Blu-ray menu support including Java-based menus. VLC does that.
But mpv will at least handle HDR correctly, so you might end up having to choose between Java-based menus and washed-out colors.
flojo
Post by flojo »
The problem is you, work it out.
I can confirm that using...
VirtualBox 7.0.12 r159484 (Qt5.15.10)
Ubuntu 23.10 (mantic)
VLC 3.0.18 Vetinari
openjdk-17-jdk
libbluray-bdj 1.3.4-1
libbluray-bin 1.3.4-1
Makemkv v1.17.4
Makemkv options: [ "backup", "--decrypt", "--cache=16", "--noscan", "-r", "--progress=-same" ]
... that VLC does "Menu" play "Goonies" 4K/UHD ripped via makemkv. I click "Open Disc..." (CTRL + D) -> toggle the radio button labled "Blu-ray" -> click "Browse..." -> then enter the link to the root directory of Goonies, ie. /movies/THE_GOONIES -> click "Play" ... ... it loads the internal menu for Goonies and I click "Play" and the movie plays. It also supports internal resume history (which is nice), because if I close VLC, open VLC, then open the directory again the internal Goonies menu now has a "Resume" option.
In case you have Goonies, purchased in the USA with volume label of "THE_GOONIES", here's the sha3 256 hashes of all the files. Again, Goonies works fine in VLC.
sha3_256 269494ef69cba050d8b79f9a799c71d37b8edd69540944ab3a784934e6f952e4 THE_GOONIES/MAKEMKV/discattd.dat
sha3_256 93353a6c9bddd819874c484fa1f1a404a6d772b0f625e2e5b3019fbfb8ba43ad THE_GOONIES/MAKEMKV/CMAP/00018.cmap
sha3_256 93353a6c9bddd819874c484fa1f1a404a6d772b0f625e2e5b3019fbfb8ba43ad THE_GOONIES/MAKEMKV/CMAP/00043.cmap
sha3_256 93353a6c9bddd819874c484fa1f1a404a6d772b0f625e2e5b3019fbfb8ba43ad THE_GOONIES/MAKEMKV/CMAP/00014.cmap
sha3_256 93353a6c9bddd819874c484fa1f1a404a6d772b0f625e2e5b3019fbfb8ba43ad THE_GOONIES/MAKEMKV/CMAP/00045.cmap
sha3_256 93353a6c9bddd819874c484fa1f1a404a6d772b0f625e2e5b3019fbfb8ba43ad THE_GOONIES/MAKEMKV/CMAP/00056.cmap
sha3_256 93353a6c9bddd819874c484fa1f1a404a6d772b0f625e2e5b3019fbfb8ba43ad THE_GOONIES/MAKEMKV/CMAP/00046.cmap
sha3_256 93353a6c9bddd819874c484fa1f1a404a6d772b0f625e2e5b3019fbfb8ba43ad THE_GOONIES/MAKEMKV/CMAP/00026.cmap
sha3_256 93353a6c9bddd819874c484fa1f1a404a6d772b0f625e2e5b3019fbfb8ba43ad THE_GOONIES/MAKEMKV/CMAP/00063.cmap
sha3_256 93353a6c9bddd819874c484fa1f1a404a6d772b0f625e2e5b3019fbfb8ba43ad THE_GOONIES/MAKEMKV/CMAP/00009.cmap
sha3_256 93353a6c9bddd819874c484fa1f1a404a6d772b0f625e2e5b3019fbfb8ba43ad THE_GOONIES/MAKEMKV/CMAP/00000.cmap
sha3_256 93353a6c9bddd819874c484fa1f1a404a6d772b0f625e2e5b3019fbfb8ba43ad THE_GOONIES/MAKEMKV/CMAP/00036.cmap
sha3_256 93353a6c9bddd819874c484fa1f1a404a6d772b0f625e2e5b3019fbfb8ba43ad THE_GOONIES/MAKEMKV/CMAP/00051.cmap
sha3_256 93353a6c9bddd819874c484fa1f1a404a6d772b0f625e2e5b3019fbfb8ba43ad THE_GOONIES/MAKEMKV/CMAP/00019.cmap
sha3_256 93353a6c9bddd819874c484fa1f1a404a6d772b0f625e2e5b3019fbfb8ba43ad THE_GOONIES/MAKEMKV/CMAP/00050.cmap
sha3_256 93353a6c9bddd819874c484fa1f1a404a6d772b0f625e2e5b3019fbfb8ba43ad THE_GOONIES/MAKEMKV/CMAP/00040.cmap
sha3_256 93353a6c9bddd819874c484fa1f1a404a6d772b0f625e2e5b3019fbfb8ba43ad THE_GOONIES/MAKEMKV/CMAP/00025.cmap
sha3_256 93353a6c9bddd819874c484fa1f1a404a6d772b0f625e2e5b3019fbfb8ba43ad THE_GOONIES/MAKEMKV/CMAP/00035.cmap
sha3_256 93353a6c9bddd819874c484fa1f1a404a6d772b0f625e2e5b3019fbfb8ba43ad THE_GOONIES/MAKEMKV/CMAP/00021.cmap
sha3_256 93353a6c9bddd819874c484fa1f1a404a6d772b0f625e2e5b3019fbfb8ba43ad THE_GOONIES/MAKEMKV/CMAP/00029.cmap
sha3_256 93353a6c9bddd819874c484fa1f1a404a6d772b0f625e2e5b3019fbfb8ba43ad THE_GOONIES/MAKEMKV/CMAP/00044.cmap
sha3_256 93353a6c9bddd819874c484fa1f1a404a6d772b0f625e2e5b3019fbfb8ba43ad THE_GOONIES/MAKEMKV/CMAP/00020.cmap
sha3_256 93353a6c9bddd819874c484fa1f1a404a6d772b0f625e2e5b3019fbfb8ba43ad THE_GOONIES/MAKEMKV/CMAP/00012.cmap
sha3_256 93353a6c9bddd819874c484fa1f1a404a6d772b0f625e2e5b3019fbfb8ba43ad THE_GOONIES/MAKEMKV/CMAP/00032.cmap
sha3_256 93353a6c9bddd819874c484fa1f1a404a6d772b0f625e2e5b3019fbfb8ba43ad THE_GOONIES/MAKEMKV/CMAP/00049.cmap
sha3_256 93353a6c9bddd819874c484fa1f1a404a6d772b0f625e2e5b3019fbfb8ba43ad THE_GOONIES/MAKEMKV/CMAP/00052.cmap
sha3_256 93353a6c9bddd819874c484fa1f1a404a6d772b0f625e2e5b3019fbfb8ba43ad THE_GOONIES/MAKEMKV/CMAP/00030.cmap
sha3_256 93353a6c9bddd819874c484fa1f1a404a6d772b0f625e2e5b3019fbfb8ba43ad THE_GOONIES/MAKEMKV/CMAP/00031.cmap
sha3_256 93353a6c9bddd819874c484fa1f1a404a6d772b0f625e2e5b3019fbfb8ba43ad THE_GOONIES/MAKEMKV/CMAP/00034.cmap
sha3_256 93353a6c9bddd819874c484fa1f1a404a6d772b0f625e2e5b3019fbfb8ba43ad THE_GOONIES/MAKEMKV/CMAP/00060.cmap
sha3_256 93353a6c9bddd819874c484fa1f1a404a6d772b0f625e2e5b3019fbfb8ba43ad THE_GOONIES/MAKEMKV/CMAP/00015.cmap
sha3_256 93353a6c9bddd819874c484fa1f1a404a6d772b0f625e2e5b3019fbfb8ba43ad THE_GOONIES/MAKEMKV/CMAP/00003.cmap
sha3_256 93353a6c9bddd819874c484fa1f1a404a6d772b0f625e2e5b3019fbfb8ba43ad THE_GOONIES/MAKEMKV/CMAP/00038.cmap
sha3_256 93353a6c9bddd819874c484fa1f1a404a6d772b0f625e2e5b3019fbfb8ba43ad THE_GOONIES/MAKEMKV/CMAP/00001.cmap
sha3_256 93353a6c9bddd819874c484fa1f1a404a6d772b0f625e2e5b3019fbfb8ba43ad THE_GOONIES/MAKEMKV/CMAP/00022.cmap
sha3_256 93353a6c9bddd819874c484fa1f1a404a6d772b0f625e2e5b3019fbfb8ba43ad THE_GOONIES/MAKEMKV/CMAP/00023.cmap
sha3_256 93353a6c9bddd819874c484fa1f1a404a6d772b0f625e2e5b3019fbfb8ba43ad THE_GOONIES/MAKEMKV/CMAP/00010.cmap
sha3_256 93353a6c9bddd819874c484fa1f1a404a6d772b0f625e2e5b3019fbfb8ba43ad THE_GOONIES/MAKEMKV/CMAP/00004.cmap
sha3_256 93353a6c9bddd819874c484fa1f1a404a6d772b0f625e2e5b3019fbfb8ba43ad THE_GOONIES/MAKEMKV/CMAP/00037.cmap
sha3_256 93353a6c9bddd819874c484fa1f1a404a6d772b0f625e2e5b3019fbfb8ba43ad THE_GOONIES/MAKEMKV/CMAP/00011.cmap
sha3_256 93353a6c9bddd819874c484fa1f1a404a6d772b0f625e2e5b3019fbfb8ba43ad THE_GOONIES/MAKEMKV/CMAP/00007.cmap
sha3_256 93353a6c9bddd819874c484fa1f1a404a6d772b0f625e2e5b3019fbfb8ba43ad THE_GOONIES/MAKEMKV/CMAP/00041.cmap
sha3_256 93353a6c9bddd819874c484fa1f1a404a6d772b0f625e2e5b3019fbfb8ba43ad THE_GOONIES/MAKEMKV/CMAP/00042.cmap
sha3_256 93353a6c9bddd819874c484fa1f1a404a6d772b0f625e2e5b3019fbfb8ba43ad THE_GOONIES/MAKEMKV/CMAP/00048.cmap
sha3_256 93353a6c9bddd819874c484fa1f1a404a6d772b0f625e2e5b3019fbfb8ba43ad THE_GOONIES/MAKEMKV/CMAP/00059.cmap
sha3_256 93353a6c9bddd819874c484fa1f1a404a6d772b0f625e2e5b3019fbfb8ba43ad THE_GOONIES/MAKEMKV/CMAP/00008.cmap
sha3_256 93353a6c9bddd819874c484fa1f1a404a6d772b0f625e2e5b3019fbfb8ba43ad THE_GOONIES/MAKEMKV/CMAP/00024.cmap
sha3_256 93353a6c9bddd819874c484fa1f1a404a6d772b0f625e2e5b3019fbfb8ba43ad THE_GOONIES/MAKEMKV/CMAP/00053.cmap
sha3_256 93353a6c9bddd819874c484fa1f1a404a6d772b0f625e2e5b3019fbfb8ba43ad THE_GOONIES/MAKEMKV/CMAP/00039.cmap
sha3_256 93353a6c9bddd819874c484fa1f1a404a6d772b0f625e2e5b3019fbfb8ba43ad THE_GOONIES/MAKEMKV/CMAP/00054.cmap
sha3_256 93353a6c9bddd819874c484fa1f1a404a6d772b0f625e2e5b3019fbfb8ba43ad THE_GOONIES/MAKEMKV/CMAP/00013.cmap
sha3_256 93353a6c9bddd819874c484fa1f1a404a6d772b0f625e2e5b3019fbfb8ba43ad THE_GOONIES/MAKEMKV/CMAP/00017.cmap
sha3_256 93353a6c9bddd819874c484fa1f1a404a6d772b0f625e2e5b3019fbfb8ba43ad THE_GOONIES/MAKEMKV/CMAP/00058.cmap
sha3_256 93353a6c9bddd819874c484fa1f1a404a6d772b0f625e2e5b3019fbfb8ba43ad THE_GOONIES/MAKEMKV/CMAP/00028.cmap
sha3_256 93353a6c9bddd819874c484fa1f1a404a6d772b0f625e2e5b3019fbfb8ba43ad THE_GOONIES/MAKEMKV/CMAP/00005.cmap
sha3_256 93353a6c9bddd819874c484fa1f1a404a6d772b0f625e2e5b3019fbfb8ba43ad THE_GOONIES/MAKEMKV/CMAP/00057.cmap
sha3_256 93353a6c9bddd819874c484fa1f1a404a6d772b0f625e2e5b3019fbfb8ba43ad THE_GOONIES/MAKEMKV/CMAP/00002.cmap
sha3_256 93353a6c9bddd819874c484fa1f1a404a6d772b0f625e2e5b3019fbfb8ba43ad THE_GOONIES/MAKEMKV/CMAP/00027.cmap
sha3_256 93353a6c9bddd819874c484fa1f1a404a6d772b0f625e2e5b3019fbfb8ba43ad THE_GOONIES/MAKEMKV/CMAP/00016.cmap
sha3_256 93353a6c9bddd819874c484fa1f1a404a6d772b0f625e2e5b3019fbfb8ba43ad THE_GOONIES/MAKEMKV/CMAP/00033.cmap
sha3_256 93353a6c9bddd819874c484fa1f1a404a6d772b0f625e2e5b3019fbfb8ba43ad THE_GOONIES/MAKEMKV/CMAP/00055.cmap
sha3_256 93353a6c9bddd819874c484fa1f1a404a6d772b0f625e2e5b3019fbfb8ba43ad THE_GOONIES/MAKEMKV/CMAP/00047.cmap
sha3_256 31df2264f420aa981a581976cb6be81dc8ef8f9d980e1378b37bb45ae7bb0cc9 THE_GOONIES/MAKEMKV/AACS/Content000.cer
sha3_256 b2945fe8e556fb989571330dfa12678cb8e10ded10a33caac26c158de7ddbe9f THE_GOONIES/MAKEMKV/AACS/Unit_Key_RO.inf
sha3_256 f0a80c866044b036e3375f15f56ab3e8c1f3edc4a1ea456f6cb0bce2ce2a0d1b THE_GOONIES/MAKEMKV/AACS/ContentHash001.tbl
sha3_256 1cfdbbbc2f3f01ab405c2795b7fefdcaa09c4fec1731e5a804d4762a703347e6 THE_GOONIES/MAKEMKV/AACS/CPSUnit00001.cci
sha3_256 31df2264f420aa981a581976cb6be81dc8ef8f9d980e1378b37bb45ae7bb0cc9 THE_GOONIES/MAKEMKV/AACS/DUPLICATE/Content000.cer
sha3_256 b2945fe8e556fb989571330dfa12678cb8e10ded10a33caac26c158de7ddbe9f THE_GOONIES/MAKEMKV/AACS/DUPLICATE/Unit_Key_RO.inf
sha3_256 f0a80c866044b036e3375f15f56ab3e8c1f3edc4a1ea456f6cb0bce2ce2a0d1b THE_GOONIES/MAKEMKV/AACS/DUPLICATE/ContentHash001.tbl
sha3_256 1cfdbbbc2f3f01ab405c2795b7fefdcaa09c4fec1731e5a804d4762a703347e6 THE_GOONIES/MAKEMKV/AACS/DUPLICATE/CPSUnit00001.cci
sha3_256 d3711b06d5c12f01a3ce64d22b7df3650799a4046ddc0b5e79ce0bbf92289553 THE_GOONIES/MAKEMKV/AACS/DUPLICATE/MKB_RO.inf
sha3_256 4066958642a7319a0870f27df7bd6eca5642f83a70154c59faaa397c0b869280 THE_GOONIES/MAKEMKV/AACS/DUPLICATE/ContentHash000.tbl
sha3_256 66ff571a1b36f6f8171d86010f80ce2550f4a3b99f0a3f7271824d7eb06c32b8 THE_GOONIES/MAKEMKV/AACS/DUPLICATE/Content001.cer
sha3_256 456545dd877291ac1c7b1e9fbef9ae1fc8e1eefe1f309ec56a5088bcbe9f9385 THE_GOONIES/MAKEMKV/AACS/DUPLICATE/DH_Pairing_Server.cer
sha3_256 ef6eb550f5ae7b7cb5fbaeb25e4801542e7c4332316516325589d630d5ef5173 THE_GOONIES/MAKEMKV/AACS/DUPLICATE/ContentRevocation.lst
sha3_256 d3711b06d5c12f01a3ce64d22b7df3650799a4046ddc0b5e79ce0bbf92289553 THE_GOONIES/MAKEMKV/AACS/MKB_RO.inf
sha3_256 4066958642a7319a0870f27df7bd6eca5642f83a70154c59faaa397c0b869280 THE_GOONIES/MAKEMKV/AACS/ContentHash000.tbl
sha3_256 66ff571a1b36f6f8171d86010f80ce2550f4a3b99f0a3f7271824d7eb06c32b8 THE_GOONIES/MAKEMKV/AACS/Content001.cer
sha3_256 456545dd877291ac1c7b1e9fbef9ae1fc8e1eefe1f309ec56a5088bcbe9f9385 THE_GOONIES/MAKEMKV/AACS/DH_Pairing_Server.cer
sha3_256 ef6eb550f5ae7b7cb5fbaeb25e4801542e7c4332316516325589d630d5ef5173 THE_GOONIES/MAKEMKV/AACS/ContentRevocation.lst
sha3_256 35b4fa9b1a3678b80bbe94609e3143f939ae7c07e3ef3d285ad544da493be086 THE_GOONIES/CERTIFICATE/online.crl
sha3_256 398599fdfdcfa8ef2c982dd5c7f1149bacbc4a50d0258e118863479df53f9bf9 THE_GOONIES/CERTIFICATE/bu.discroot.crt
sha3_256 35b4fa9b1a3678b80bbe94609e3143f939ae7c07e3ef3d285ad544da493be086 THE_GOONIES/CERTIFICATE/BACKUP/online.crl
sha3_256 398599fdfdcfa8ef2c982dd5c7f1149bacbc4a50d0258e118863479df53f9bf9 THE_GOONIES/CERTIFICATE/BACKUP/bu.discroot.crt
sha3_256 398599fdfdcfa8ef2c982dd5c7f1149bacbc4a50d0258e118863479df53f9bf9 THE_GOONIES/CERTIFICATE/BACKUP/app.discroot.crt
sha3_256 c80a81ba7420ac721538908f004214cafe6cbbaf52ff46bda912d0a722005613 THE_GOONIES/CERTIFICATE/BACKUP/id.bdmv
sha3_256 5a238e8215d87c33cfab8e768ce436ba1b8bef31bb0074c63b121c16fdd090a2 THE_GOONIES/CERTIFICATE/BACKUP/online.sig
sha3_256 ef0006b000dec9c718c14c8871f8e20a6461082cfcba13f0ddab8bc1c286bdbb THE_GOONIES/CERTIFICATE/BACKUP/online.crt
sha3_256 398599fdfdcfa8ef2c982dd5c7f1149bacbc4a50d0258e118863479df53f9bf9 THE_GOONIES/CERTIFICATE/app.discroot.crt
sha3_256 c80a81ba7420ac721538908f004214cafe6cbbaf52ff46bda912d0a722005613 THE_GOONIES/CERTIFICATE/id.bdmv
sha3_256 5a238e8215d87c33cfab8e768ce436ba1b8bef31bb0074c63b121c16fdd090a2 THE_GOONIES/CERTIFICATE/online.sig
sha3_256 ef0006b000dec9c718c14c8871f8e20a6461082cfcba13f0ddab8bc1c286bdbb THE_GOONIES/CERTIFICATE/online.crt
sha3_256 b76919369a7feb7d3d3572fe6c946b3dfaea30dcc125ae01de1609b20fb442d2 THE_GOONIES/BDMV/STREAM/00005.m2ts
sha3_256 51d9657ba56191ff2b5cce92396dba99c8e63146114204aa94982dc522a51594 THE_GOONIES/BDMV/STREAM/00036.m2ts
sha3_256 3ac79ebfe1219ca3d20986ed812adf4a29ceddf70bdf5331585776309831b540 THE_GOONIES/BDMV/STREAM/00037.m2ts
sha3_256 9c842e7ace26b16657373c816a8c261a2ec63030d2cf3e5def1f38a341c5f92b THE_GOONIES/BDMV/STREAM/00057.m2ts
sha3_256 d03012598c74f142e5988ce31fbf68bac6e49bc4725ac2372d98675b36686061 THE_GOONIES/BDMV/STREAM/00000.m2ts
sha3_256 3f2327ad86a13c66efa2b3dd3d09a4660aaef2b887dd75906cc96e31d2dbfa5c THE_GOONIES/BDMV/STREAM/00019.m2ts
sha3_256 926365420823e78b3f6fb29c1898557394a6d1900eb7c76151d4f564c5138a62 THE_GOONIES/BDMV/STREAM/00040.m2ts
sha3_256 2280e411cfa01dedab02fecc50ee159f44429297007e0faeb08da98fdfa2452a THE_GOONIES/BDMV/STREAM/00001.m2ts
sha3_256 08ff7367f3f320b28a749619907f24db17c279451f027374803a1065878df357 THE_GOONIES/BDMV/STREAM/00027.m2ts
sha3_256 e4305a7289ad37e86f65e247dfb7d03a3edef98e8bf0e7d10f22b150441bdc70 THE_GOONIES/BDMV/STREAM/00044.m2ts
sha3_256 53004c0b4023d01307b6980be07b3019dfaac4585a12123975229e735e016c67 THE_GOONIES/BDMV/STREAM/00031.m2ts
sha3_256 b0e5e685c1021d8567b6d66d36ade22704914b8f0bc1f751e449422f85a814a8 THE_GOONIES/BDMV/STREAM/00047.m2ts
sha3_256 086d864cf8c8345bf48974e1d145ddf6381b709189de05b58f5175558e5bf194 THE_GOONIES/BDMV/STREAM/00023.m2ts
sha3_256 ff9248b2d61668e7ef2db205da523f72065a85c76c3dbfc34a044b4e42ed9ca8 THE_GOONIES/BDMV/STREAM/00045.m2ts
sha3_256 bc6e201256d1e95dd2b9a1f46fd3fb7065bee683bc69cbd766b5e5982e1195d0 THE_GOONIES/BDMV/STREAM/00042.m2ts
sha3_256 caa1e69ea608a29a8d88909264b646d996b62f2c49100f7f5924650b36e7e665 THE_GOONIES/BDMV/STREAM/00016.m2ts
sha3_256 346b89578d6f1ed042100e9d91eeba5dc29d87f88637f913011d4d61420214a6 THE_GOONIES/BDMV/STREAM/00048.m2ts
sha3_256 e65ae40c6b8056fe968d3e55ec450a4b8c21222b3f61f8a2411018c45316f319 THE_GOONIES/BDMV/STREAM/00032.m2ts
sha3_256 9e8e151f79e383e2094877ab95579a3543ddb56d33850bc614aaae68777a40c8 THE_GOONIES/BDMV/STREAM/00035.m2ts
sha3_256 2e174e97e0a8cee6a31af04224ac7716f0dc1aaa937fed6e2e19043164c2cedb THE_GOONIES/BDMV/STREAM/00038.m2ts
sha3_256 4daeaf77dea4b24a99cf078dfbc41758f2aefd54a2091964cf1321a3da0f2f90 THE_GOONIES/BDMV/STREAM/00051.m2ts
sha3_256 cdb5caca3aad9e793f7160eaef8b2a9df6a7ac63acc0ff93f2533fc3fd8e1a42 THE_GOONIES/BDMV/STREAM/00054.m2ts
sha3_256 396cbab9a4af603873184c549ef67f948f93159a60373ef42b15e809f05a0f88 THE_GOONIES/BDMV/STREAM/00029.m2ts
sha3_256 16163a990843f99b8cd9d80490ac1b2c66a712eaa83169c483624bf6640e9cbe THE_GOONIES/BDMV/STREAM/00049.m2ts
sha3_256 2c2cbd159b358c9aac1ca5d6ac75d68cef0ac0ee4cf33acdbe7236a47bc7371a THE_GOONIES/BDMV/STREAM/00008.m2ts
sha3_256 b23cbd038acc5ab0b5e114b939d0d80337248ca9452215bafa80e2d321e31d3a THE_GOONIES/BDMV/STREAM/00033.m2ts
sha3_256 758990055a81053d22d8b18b23935246dfc1280c5f02c1fdf19b5f5c5f6c9d40 THE_GOONIES/BDMV/STREAM/00002.m2ts
sha3_256 5025208f805661d653099ab4064ac21df8ee2c17e7b205d665434f35b8dadbe0 THE_GOONIES/BDMV/STREAM/00020.m2ts
sha3_256 8909146fc5a695fb022dcd05993af6f7211d065507b93468a422bcc546242d72 THE_GOONIES/BDMV/STREAM/00050.m2ts
sha3_256 6296a7393c7420690935def6d649141423555c0f583c9130348b84debf0ae33b THE_GOONIES/BDMV/STREAM/00025.m2ts
sha3_256 9422d0055d5cca8ef758ccd9b0126c2cd94a12d4ddcf81e81283d5e55b81f0e6 THE_GOONIES/BDMV/STREAM/00041.m2ts
sha3_256 b0a468e4b17b6bb0efc29712f4a50f29fde2cf153ec9b79a81401fdc9fd903df THE_GOONIES/BDMV/STREAM/00046.m2ts
sha3_256 be6054eff4a45af5561f449602fe66467954da629e8abaa5ae06669cd9b46015 THE_GOONIES/BDMV/STREAM/00052.m2ts
sha3_256 f8c6ed672b5ea6cc401d3f562e30b7dc6a5b8144a7612e7f6ba2aed30205b856 THE_GOONIES/BDMV/STREAM/00015.m2ts
sha3_256 568f82174c57d99d6b473ce69ddd60757b02c8eb58512ecd03438a9455b4729d THE_GOONIES/BDMV/STREAM/00056.m2ts
sha3_256 779c07d27b705404d98cc0b9bf26b8d2f12cc04e0bad224324e38570992feba7 THE_GOONIES/BDMV/STREAM/00012.m2ts
sha3_256 25213bf8bbfcfd5348824e18fa6266f85901c83f480891e217fe53fe528172c8 THE_GOONIES/BDMV/STREAM/00060.m2ts
sha3_256 9686c6dfcb0546c79c92ce02f9e153fba4fe4396b1f37195c4af8dcd651362dd THE_GOONIES/BDMV/STREAM/00026.m2ts
sha3_256 37ea995e0f63d43100829caa2a591194a35e19725e324ee17e7bf5ddcc7d06f9 THE_GOONIES/BDMV/STREAM/00010.m2ts
sha3_256 c648cc9936321dea1e46b1fcf557658016216425d60086f3b4aad47d24954033 THE_GOONIES/BDMV/STREAM/00063.m2ts
sha3_256 270bd347f4b276c4296926a7380c401b5b94443481206f9a42b1d46b725e8d62 THE_GOONIES/BDMV/STREAM/00034.m2ts
sha3_256 59b6b85d3496aa3018793ce8b53925960b18a198bf9296c77dec14426d3f7830 THE_GOONIES/BDMV/STREAM/00009.m2ts
sha3_256 cbcf38867f856c495098aefd4721cb4b183a48bfbab0afa616009e8e6e0bea84 THE_GOONIES/BDMV/STREAM/00022.m2ts
sha3_256 c409201a4f8dec96694fb08b33de4d30068eb3ed9a5bc9efc633ddc54d40f896 THE_GOONIES/BDMV/STREAM/00021.m2ts
sha3_256 6d1179642629c35dfd1b9b53a53a48f210e115158b23dcf5b61f307c96708d23 THE_GOONIES/BDMV/STREAM/00013.m2ts
sha3_256 5ae7c7455fb63e02eb608473cabea62bfca02cf0e041671e7471c828e003a357 THE_GOONIES/BDMV/STREAM/00017.m2ts
sha3_256 6d63edea34f9de1c13374e9b897676f5a7e8d154eef3f52043b2740e7a587c35 THE_GOONIES/BDMV/STREAM/00039.m2ts
sha3_256 d65d318b45b82364c664320b90d7804fb5c6b245085cf6fb25072c1d21c9bd6b THE_GOONIES/BDMV/STREAM/00053.m2ts
sha3_256 e3d807a2ec38b0a7384123d8a3d920fff7897d5e37a23fed32339d20219ff008 THE_GOONIES/BDMV/STREAM/00014.m2ts
sha3_256 0a1550c005c162c13767456266985b6805b0e792c5b5df97ab8fc2d06bcb6447 THE_GOONIES/BDMV/STREAM/00004.m2ts
sha3_256 9a011509ad642e2c3f85168e93896cef65b9257da50ce289aa87845a98554cfb THE_GOONIES/BDMV/STREAM/00011.m2ts
sha3_256 83797588642e3ebc318358640a3acb5db1f14e7beba72b597d6ee012dc1e2246 THE_GOONIES/BDMV/STREAM/00028.m2ts
sha3_256 262e3a4d96b8137f4f04e1dd9c40e247521f531be21cceeebf6ad5fee5d89946 THE_GOONIES/BDMV/STREAM/00007.m2ts
sha3_256 e4bf9389ae6baa0739d68e10b8976081f80aab1b15329ddfd62fbb0990c5913a THE_GOONIES/BDMV/STREAM/00055.m2ts
sha3_256 5041ce2c4260154299f6964d6f63eb6e79953423791745fad9064f29aef9b9ad THE_GOONIES/BDMV/STREAM/00059.m2ts
sha3_256 0f0644e2c0a7f6d191d728617048a5451ad4af9e7c6dee35856422619357dc6a THE_GOONIES/BDMV/STREAM/00003.m2ts
sha3_256 5b2daea369354b32ee4c96e51002f28df128ae5d7ada1595ea3a2676709f2bd3 THE_GOONIES/BDMV/STREAM/00018.m2ts
sha3_256 4c7d77835405561a18ff7280e2f6eae8b5a18a1789c0df65f7b54c470536895e THE_GOONIES/BDMV/STREAM/00030.m2ts
sha3_256 dfb64de16557eee65dd031aa108e418f2b124ef0c96af79314f8effdf8f4f3ce THE_GOONIES/BDMV/STREAM/00043.m2ts
sha3_256 851a8a33079a9d898d222f60d0a031b3ceb41bf8277d6fe3437b3decc930f647 THE_GOONIES/BDMV/STREAM/00058.m2ts
sha3_256 141cf2f5990af864e02e0c7cef49f3008ebdda422787f392de1a233afaa044d9 THE_GOONIES/BDMV/STREAM/00024.m2ts
sha3_256 1f2513a58973ef624b5016588e1950a544a1d1e3c05d89081d97a300d8bee192 THE_GOONIES/BDMV/MovieObject.bdmv
sha3_256 021ca7b00f51ce0d6576bf3149d81adc17507c72b3463b353054976a8a741f7b THE_GOONIES/BDMV/CLIPINF/00025.clpi
sha3_256 42b41a019b073d2da7a117ffaf511213b4503cd8149ce511e2e591fc810a5507 THE_GOONIES/BDMV/CLIPINF/00022.clpi
sha3_256 fea026f9aa1c2f0c82d0777cf1181b093eff291312e927d2b967f82a7331c5c7 THE_GOONIES/BDMV/CLIPINF/00018.clpi
sha3_256 d0f537e4f6f1438ab8e454b34cc267a99946d3e3aeac13ba8353227061e03737 THE_GOONIES/BDMV/CLIPINF/00008.clpi
sha3_256 3ad2e2e75368883ebca432f1d6ab61a890a77ff7ad52e7f27c7bc9d5d66a1c6d THE_GOONIES/BDMV/CLIPINF/00051.clpi
sha3_256 b1c7f9a363627ae5536166c0e18762391b70962b318438f2058d25515896b107 THE_GOONIES/BDMV/CLIPINF/00013.clpi
sha3_256 4c2cd439b9bfe1a999448ad1804cd8d6e6c6fefced93faaef1cfdcea71af7848 THE_GOONIES/BDMV/CLIPINF/00021.clpi
sha3_256 dd6f54834e761b27e55a28886992d31a2b34a4d2d39327bd2a87a8edbf99babd THE_GOONIES/BDMV/CLIPINF/00000.clpi
sha3_256 dbb4aa9314b12c17945b0255bedf2bd21a7e623f50922972bdd6990b120b9c00 THE_GOONIES/BDMV/CLIPINF/00007.clpi
sha3_256 52431a969814d3c5284186709edff98022cec17963ac1f03abc46cb741401731 THE_GOONIES/BDMV/CLIPINF/00028.clpi
sha3_256 fac1f0005fe052aa4435d1e246d3d81f0e2f71e27ac226b1ef903ac12d05050e THE_GOONIES/BDMV/CLIPINF/00035.clpi
sha3_256 4d52c876b87891ec837d2bf54f9798165895f4780c1cf670118313d398efec94 THE_GOONIES/BDMV/CLIPINF/00036.clpi
sha3_256 eeb6bd67a7c71770d36c6b4ca6cd19c381fe80c98068fee2f4386f4f769ae84f THE_GOONIES/BDMV/CLIPINF/00055.clpi
sha3_256 b57b29e55e3ec316e968efafa306a6c94fc0e1d03f550cc2079fe521ccb15c93 THE_GOONIES/BDMV/CLIPINF/00049.clpi
sha3_256 b44f6e3fbaade0b23e6fab30cd9b56a01e4afc8b01201981c71a32ce72b6d793 THE_GOONIES/BDMV/CLIPINF/00058.clpi
sha3_256 015a0c8ebfb70fc6af1515d6e2e25fcba498ae309552f30b4818e9567e1b29ec THE_GOONIES/BDMV/CLIPINF/00003.clpi
sha3_256 2a42ff36c417474b8816fb09f039455c565635a17a7b134e426f3d3fb7dc81f6 THE_GOONIES/BDMV/CLIPINF/00042.clpi
sha3_256 05040131f43edc17ccb5effd982dba6b6fdac533b48b456023fe4b1869952737 THE_GOONIES/BDMV/CLIPINF/00053.clpi
sha3_256 a25f49c599c6f31e20ccc783f246f0aa6603abcc38f714452813f6c9cb2971fb THE_GOONIES/BDMV/CLIPINF/00027.clpi
sha3_256 a1b0be3c3ff968b84d2fcc7d876518d736705c55306f35a473a55961b67e2e2a THE_GOONIES/BDMV/CLIPINF/00031.clpi
sha3_256 fa1fd3fcb97539170884c60fe1720f1b9c144cf4a53697b2ddc06d61942741ca THE_GOONIES/BDMV/CLIPINF/00038.clpi
sha3_256 95fdee768ed26b0479cfae77f29cead24cac92db9548df12aa57cbb17770903e THE_GOONIES/BDMV/CLIPINF/00019.clpi
sha3_256 d28f8e6edf1bc957cfe8c2868cc17196390d65293f188db85a01e5b0de06b1a0 THE_GOONIES/BDMV/CLIPINF/00052.clpi
sha3_256 472adb88db15431f60e0fc482c17b3e0eab65797ff0ce0aff9269454b548ebd8 THE_GOONIES/BDMV/CLIPINF/00024.clpi
sha3_256 36b4ed77be7a2a04955b18f7313232928ea741ad28d614f9e8b8c207f1115e6e THE_GOONIES/BDMV/CLIPINF/00016.clpi
sha3_256 aaa82ee28251ba93ebeaf0ebd20b10c9546a7d5f2a9cfb7db1c061b326233d3e THE_GOONIES/BDMV/CLIPINF/00033.clpi
sha3_256 ed37fb9fc8ff8e7a958bcf7fff763683c59642647a9d393c65530880cb2f84d7 THE_GOONIES/BDMV/CLIPINF/00009.clpi
sha3_256 7f60912f7086e24de2d5fc7a895d8812a08347e2acb5957f551f998ccc8462a8 THE_GOONIES/BDMV/CLIPINF/00043.clpi
sha3_256 3e120181dd3c46b5799164a7646211ea7851b53a7f59d7120f7478f8f35783f9 THE_GOONIES/BDMV/CLIPINF/00063.clpi
sha3_256 ccd05023e83c925b349f5ebf7ea064b5052b752f28e8bc7f12ae8d71fe7cf178 THE_GOONIES/BDMV/CLIPINF/00050.clpi
sha3_256 4e27dc59123426882b80f1a4e4f73dcfd31988a2760fbd2d7a74badb5123eb31 THE_GOONIES/BDMV/CLIPINF/00029.clpi
sha3_256 c3b182e1045d668070a4d97f673c6c97a70835f47f92e1aa4234c108f479287f THE_GOONIES/BDMV/CLIPINF/00039.clpi
sha3_256 3a23251d73ae14adb161d67e30ad928823dee7feba09b8b39191a97c810643a9 THE_GOONIES/BDMV/CLIPINF/00041.clpi
sha3_256 dce0064676d57acf3b1c117934d29d1a19889a86c049b5f91b48e5a6107a9677 THE_GOONIES/BDMV/CLIPINF/00045.clpi
sha3_256 fec10ecc8191bae506eee147cdb3697a65f424b8ab1981474cb2376c7d170cc9 THE_GOONIES/BDMV/CLIPINF/00005.clpi
sha3_256 e4fa80c1b44b1e062c8094a5a10b6d66bf546946c156f990e3643d80e339ffe1 THE_GOONIES/BDMV/CLIPINF/00037.clpi
sha3_256 fea026f9aa1c2f0c82d0777cf1181b093eff291312e927d2b967f82a7331c5c7 THE_GOONIES/BDMV/CLIPINF/00010.clpi
sha3_256 72dacfb0dd7998ff388b8feff934310172df61d85d2f32d1627f1bcbae1e6a8b THE_GOONIES/BDMV/CLIPINF/00023.clpi
sha3_256 dc527aa10654b5db3487bd6fc9a979c5991955a2531e246584146d896977044f THE_GOONIES/BDMV/CLIPINF/00057.clpi
sha3_256 a68549b8bab68e44553b58debd0af5fb4a3cf3852770c5adb283d2c716c96059 THE_GOONIES/BDMV/CLIPINF/00034.clpi
sha3_256 c0bfce3d173541b5f82fee4307c0975d2eb1f3851d958bac3bb7e9e2bbc7c4c7 THE_GOONIES/BDMV/CLIPINF/00046.clpi
sha3_256 55158fb95ec12ade837a7f7ebef54b4c5d45bd963df553585627858e8eac2736 THE_GOONIES/BDMV/CLIPINF/00060.clpi
sha3_256 e6e8f11f7aec33e300faa2e42efd07963927184e7ce5c9cc0ee2db7908fd7a12 THE_GOONIES/BDMV/CLIPINF/00032.clpi
sha3_256 a368ae2a9a2040bb0b6c9944183803c628497dffbc75fc8e15f64a60a7f99c02 THE_GOONIES/BDMV/CLIPINF/00056.clpi
sha3_256 39ab9c024fe85717e619484a90c56810e527876be2d78b299f1f21e58601c178 THE_GOONIES/BDMV/CLIPINF/00015.clpi
sha3_256 aa1edcd4a104d49a86803fcb1e7fa50f167ec0e3d240434511c907a4d7742460 THE_GOONIES/BDMV/CLIPINF/00001.clpi
sha3_256 67d71f83f8abf36d458012efb89e68051d1efe42a38467a630e0ce56c9a9d615 THE_GOONIES/BDMV/CLIPINF/00048.clpi
sha3_256 69302410560b0a51f02116c8c3377da15987c2f9f7ec72dba8b84fe8de7d7bee THE_GOONIES/BDMV/CLIPINF/00017.clpi
sha3_256 9b4ebfcaad55f6ed6a5ee35d12dc8b335029106c8f72453ccfdd8237828116f4 THE_GOONIES/BDMV/CLIPINF/00054.clpi
sha3_256 1d5e4cb07b6bd858ba94cff914b6b51226027fb2ffb62daa488c420a57c58c1e THE_GOONIES/BDMV/CLIPINF/00004.clpi
sha3_256 fc3e0c7bea12bae66e97842c886b50548252f2b2eac67442597cdb90562afb76 THE_GOONIES/BDMV/CLIPINF/00002.clpi
sha3_256 21820703a7266c65269175c22298a23cf1563d715274adcf60fcb1afc4c8c24b THE_GOONIES/BDMV/CLIPINF/00044.clpi
sha3_256 b1e82fa54104b8822f8416535f83a6dc2c6778ae49559019cec7cad3951b105a THE_GOONIES/BDMV/CLIPINF/00020.clpi
sha3_256 b8f57e78c39ff22df602b0881e14804ce16e891bb609f409d57ca54dcaf1e699 THE_GOONIES/BDMV/CLIPINF/00030.clpi
sha3_256 014607d2d08823c0b37997aa4d8929a92fe15fe847e17ec668507e47d2a93766 THE_GOONIES/BDMV/CLIPINF/00047.clpi
sha3_256 092069647a674fa39d5c69607585be3ea537059e6e405bb994b4c9bb3ed05c6e THE_GOONIES/BDMV/CLIPINF/00012.clpi
sha3_256 2d71db6947eae6bd6e266e4e74fc94d501c03b660cb32a0c52cdd172ec77e742 THE_GOONIES/BDMV/CLIPINF/00059.clpi
sha3_256 7e9736cca23e0fbabe92e8c80c6b4ab99dabaae891f6f543074c6f6942a761d2 THE_GOONIES/BDMV/CLIPINF/00026.clpi
sha3_256 f1a4dec4af1c7aaa0504e710234b765eaa7c853720e24558d1b20d7889bc58e5 THE_GOONIES/BDMV/CLIPINF/00011.clpi
sha3_256 a2e171671944ec27813261910c5957e255f72930eb459867d59ad5821aa47ee0 THE_GOONIES/BDMV/CLIPINF/00040.clpi
sha3_256 8da92c7957eb2a7e733fa9de146f4aaabccee6eea06ecba25a4290f764a57f0c THE_GOONIES/BDMV/CLIPINF/00014.clpi
sha3_256 cfbacf2619104e864ed939b95a4b9efb903aac2628fd6e553d245f836c22dccc THE_GOONIES/BDMV/PLAYLIST/00050.mpls
sha3_256 068ba49ce9c8824400662592c30604e5620d5dded5f74c03c29113af29e8f4d0 THE_GOONIES/BDMV/PLAYLIST/00800.mpls
sha3_256 d2571cbb90b610b5b2c7d4b05a2d9219bb8bcaa7887a98a3b0700df2cf558e1a THE_GOONIES/BDMV/PLAYLIST/00801.mpls
sha3_256 a2cdc7f49e833c3c867496ce92a5d00749541a0d5221482beaae874e1a680659 THE_GOONIES/BDMV/PLAYLIST/00120.mpls
sha3_256 6ff6b1af48bdf8800415b5812d3c58b446887ca7fe7e45a54560a4a59a2b0a35 THE_GOONIES/BDMV/PLAYLIST/00053.mpls
sha3_256 d94e8d0221ff77bc17eb104acc3d3c88cc9f257c4ed3699781dad64425a82f31 THE_GOONIES/BDMV/PLAYLIST/00142.mpls
sha3_256 738542a76e76ac475d695d9803c5f801bc1791617d457d2561f84bafe213ac25 THE_GOONIES/BDMV/PLAYLIST/00055.mpls
sha3_256 6f7689718ee04e13bc2c815dc2724966cbd08b2283f884f3bb5ee896afd5009d THE_GOONIES/BDMV/PLAYLIST/00016.mpls
sha3_256 fd56adf83298416183c448420d6c78507c2ec00d5d1d9d009c1e1ad3bab39d12 THE_GOONIES/BDMV/PLAYLIST/00017.mpls
sha3_256 b9d7ae1abf42f346432482a044f990d984d66646758843a27d1e12266d86df7b THE_GOONIES/BDMV/PLAYLIST/00099.mpls
sha3_256 9ce9e19f9685897722b5618697b60394f202ff71ea00f6bb3c054297af90a4c2 THE_GOONIES/BDMV/PLAYLIST/00014.mpls
sha3_256 67ade4cd541e7c71a8917652b7b0e109b97df183a694aa85223c370b03c3ff02 THE_GOONIES/BDMV/PLAYLIST/00056.mpls
sha3_256 bc5beac065109641ac2977d010490499c5dd9725530c2a3a17670c73ae00f61d THE_GOONIES/BDMV/PLAYLIST/00015.mpls
sha3_256 a2cdc7f49e833c3c867496ce92a5d00749541a0d5221482beaae874e1a680659 THE_GOONIES/BDMV/PLAYLIST/00140.mpls
sha3_256 dea9e53db9f04faf884948a5d73ce2cf1ad6ab36d2ce4dcffbfec9dc2844ac92 THE_GOONIES/BDMV/PLAYLIST/00013.mpls
sha3_256 032fc9f554753b04d329669403b81858ecbc36b40aa4184cd8801fb11a3e14b3 THE_GOONIES/BDMV/PLAYLIST/00049.mpls
sha3_256 64c10f538aaacf05e193aa65d665e986c92e920788a684b957ecfe96993b93c8 THE_GOONIES/BDMV/PLAYLIST/00054.mpls
sha3_256 9329dad3d4544dec65a9508133fe4b59e85281224d818d426b44b2ffaa6d356c THE_GOONIES/BDMV/PLAYLIST/00119.mpls
sha3_256 d94e8d0221ff77bc17eb104acc3d3c88cc9f257c4ed3699781dad64425a82f31 THE_GOONIES/BDMV/PLAYLIST/00122.mpls
sha3_256 9adf5990200588c9c41ac6cea9983459c0d58a20f257cd329d56b9d380057942 THE_GOONIES/BDMV/PLAYLIST/00052.mpls
sha3_256 9e39b62a179416c4cb1152e0c3ca987f11d01783f7a9d09f3643f9043b7d2497 THE_GOONIES/BDMV/PLAYLIST/00010.mpls
sha3_256 1a9aac08476b68009f76327b4bf0b8c56e496a1c9553bc2f3cda9104f5db6e47 THE_GOONIES/BDMV/PLAYLIST/00032.mpls
sha3_256 3bc7f0e7e95e34d16f9217f8af02f80b0e5acb45e2c1a2f9afcf2a8f10734db1 THE_GOONIES/BDMV/PLAYLIST/00012.mpls
sha3_256 1f2513a58973ef624b5016588e1950a544a1d1e3c05d89081d97a300d8bee192 THE_GOONIES/BDMV/BACKUP/MovieObject.bdmv
sha3_256 021ca7b00f51ce0d6576bf3149d81adc17507c72b3463b353054976a8a741f7b THE_GOONIES/BDMV/BACKUP/CLIPINF/00025.clpi
sha3_256 42b41a019b073d2da7a117ffaf511213b4503cd8149ce511e2e591fc810a5507 THE_GOONIES/BDMV/BACKUP/CLIPINF/00022.clpi
sha3_256 fea026f9aa1c2f0c82d0777cf1181b093eff291312e927d2b967f82a7331c5c7 THE_GOONIES/BDMV/BACKUP/CLIPINF/00018.clpi
sha3_256 d0f537e4f6f1438ab8e454b34cc267a99946d3e3aeac13ba8353227061e03737 THE_GOONIES/BDMV/BACKUP/CLIPINF/00008.clpi
sha3_256 3ad2e2e75368883ebca432f1d6ab61a890a77ff7ad52e7f27c7bc9d5d66a1c6d THE_GOONIES/BDMV/BACKUP/CLIPINF/00051.clpi
sha3_256 b1c7f9a363627ae5536166c0e18762391b70962b318438f2058d25515896b107 THE_GOONIES/BDMV/BACKUP/CLIPINF/00013.clpi
sha3_256 4c2cd439b9bfe1a999448ad1804cd8d6e6c6fefced93faaef1cfdcea71af7848 THE_GOONIES/BDMV/BACKUP/CLIPINF/00021.clpi
sha3_256 dd6f54834e761b27e55a28886992d31a2b34a4d2d39327bd2a87a8edbf99babd THE_GOONIES/BDMV/BACKUP/CLIPINF/00000.clpi
sha3_256 dbb4aa9314b12c17945b0255bedf2bd21a7e623f50922972bdd6990b120b9c00 THE_GOONIES/BDMV/BACKUP/CLIPINF/00007.clpi
sha3_256 52431a969814d3c5284186709edff98022cec17963ac1f03abc46cb741401731 THE_GOONIES/BDMV/BACKUP/CLIPINF/00028.clpi
sha3_256 fac1f0005fe052aa4435d1e246d3d81f0e2f71e27ac226b1ef903ac12d05050e THE_GOONIES/BDMV/BACKUP/CLIPINF/00035.clpi
sha3_256 4d52c876b87891ec837d2bf54f9798165895f4780c1cf670118313d398efec94 THE_GOONIES/BDMV/BACKUP/CLIPINF/00036.clpi
sha3_256 eeb6bd67a7c71770d36c6b4ca6cd19c381fe80c98068fee2f4386f4f769ae84f THE_GOONIES/BDMV/BACKUP/CLIPINF/00055.clpi
sha3_256 b57b29e55e3ec316e968efafa306a6c94fc0e1d03f550cc2079fe521ccb15c93 THE_GOONIES/BDMV/BACKUP/CLIPINF/00049.clpi
sha3_256 b44f6e3fbaade0b23e6fab30cd9b56a01e4afc8b01201981c71a32ce72b6d793 THE_GOONIES/BDMV/BACKUP/CLIPINF/00058.clpi
sha3_256 015a0c8ebfb70fc6af1515d6e2e25fcba498ae309552f30b4818e9567e1b29ec THE_GOONIES/BDMV/BACKUP/CLIPINF/00003.clpi
sha3_256 2a42ff36c417474b8816fb09f039455c565635a17a7b134e426f3d3fb7dc81f6 THE_GOONIES/BDMV/BACKUP/CLIPINF/00042.clpi
sha3_256 05040131f43edc17ccb5effd982dba6b6fdac533b48b456023fe4b1869952737 THE_GOONIES/BDMV/BACKUP/CLIPINF/00053.clpi
sha3_256 a25f49c599c6f31e20ccc783f246f0aa6603abcc38f714452813f6c9cb2971fb THE_GOONIES/BDMV/BACKUP/CLIPINF/00027.clpi
sha3_256 a1b0be3c3ff968b84d2fcc7d876518d736705c55306f35a473a55961b67e2e2a THE_GOONIES/BDMV/BACKUP/CLIPINF/00031.clpi
sha3_256 fa1fd3fcb97539170884c60fe1720f1b9c144cf4a53697b2ddc06d61942741ca THE_GOONIES/BDMV/BACKUP/CLIPINF/00038.clpi
sha3_256 95fdee768ed26b0479cfae77f29cead24cac92db9548df12aa57cbb17770903e THE_GOONIES/BDMV/BACKUP/CLIPINF/00019.clpi
sha3_256 d28f8e6edf1bc957cfe8c2868cc17196390d65293f188db85a01e5b0de06b1a0 THE_GOONIES/BDMV/BACKUP/CLIPINF/00052.clpi
sha3_256 472adb88db15431f60e0fc482c17b3e0eab65797ff0ce0aff9269454b548ebd8 THE_GOONIES/BDMV/BACKUP/CLIPINF/00024.clpi
sha3_256 36b4ed77be7a2a04955b18f7313232928ea741ad28d614f9e8b8c207f1115e6e THE_GOONIES/BDMV/BACKUP/CLIPINF/00016.clpi
sha3_256 aaa82ee28251ba93ebeaf0ebd20b10c9546a7d5f2a9cfb7db1c061b326233d3e THE_GOONIES/BDMV/BACKUP/CLIPINF/00033.clpi
sha3_256 ed37fb9fc8ff8e7a958bcf7fff763683c59642647a9d393c65530880cb2f84d7 THE_GOONIES/BDMV/BACKUP/CLIPINF/00009.clpi
sha3_256 7f60912f7086e24de2d5fc7a895d8812a08347e2acb5957f551f998ccc8462a8 THE_GOONIES/BDMV/BACKUP/CLIPINF/00043.clpi
sha3_256 3e120181dd3c46b5799164a7646211ea7851b53a7f59d7120f7478f8f35783f9 THE_GOONIES/BDMV/BACKUP/CLIPINF/00063.clpi
sha3_256 ccd05023e83c925b349f5ebf7ea064b5052b752f28e8bc7f12ae8d71fe7cf178 THE_GOONIES/BDMV/BACKUP/CLIPINF/00050.clpi
sha3_256 4e27dc59123426882b80f1a4e4f73dcfd31988a2760fbd2d7a74badb5123eb31 THE_GOONIES/BDMV/BACKUP/CLIPINF/00029.clpi
sha3_256 c3b182e1045d668070a4d97f673c6c97a70835f47f92e1aa4234c108f479287f THE_GOONIES/BDMV/BACKUP/CLIPINF/00039.clpi
sha3_256 3a23251d73ae14adb161d67e30ad928823dee7feba09b8b39191a97c810643a9 THE_GOONIES/BDMV/BACKUP/CLIPINF/00041.clpi
sha3_256 dce0064676d57acf3b1c117934d29d1a19889a86c049b5f91b48e5a6107a9677 THE_GOONIES/BDMV/BACKUP/CLIPINF/00045.clpi
sha3_256 fec10ecc8191bae506eee147cdb3697a65f424b8ab1981474cb2376c7d170cc9 THE_GOONIES/BDMV/BACKUP/CLIPINF/00005.clpi
sha3_256 e4fa80c1b44b1e062c8094a5a10b6d66bf546946c156f990e3643d80e339ffe1 THE_GOONIES/BDMV/BACKUP/CLIPINF/00037.clpi
sha3_256 fea026f9aa1c2f0c82d0777cf1181b093eff291312e927d2b967f82a7331c5c7 THE_GOONIES/BDMV/BACKUP/CLIPINF/00010.clpi
sha3_256 72dacfb0dd7998ff388b8feff934310172df61d85d2f32d1627f1bcbae1e6a8b THE_GOONIES/BDMV/BACKUP/CLIPINF/00023.clpi
sha3_256 dc527aa10654b5db3487bd6fc9a979c5991955a2531e246584146d896977044f THE_GOONIES/BDMV/BACKUP/CLIPINF/00057.clpi
sha3_256 a68549b8bab68e44553b58debd0af5fb4a3cf3852770c5adb283d2c716c96059 THE_GOONIES/BDMV/BACKUP/CLIPINF/00034.clpi
sha3_256 c0bfce3d173541b5f82fee4307c0975d2eb1f3851d958bac3bb7e9e2bbc7c4c7 THE_GOONIES/BDMV/BACKUP/CLIPINF/00046.clpi
sha3_256 55158fb95ec12ade837a7f7ebef54b4c5d45bd963df553585627858e8eac2736 THE_GOONIES/BDMV/BACKUP/CLIPINF/00060.clpi
sha3_256 e6e8f11f7aec33e300faa2e42efd07963927184e7ce5c9cc0ee2db7908fd7a12 THE_GOONIES/BDMV/BACKUP/CLIPINF/00032.clpi
sha3_256 a368ae2a9a2040bb0b6c9944183803c628497dffbc75fc8e15f64a60a7f99c02 THE_GOONIES/BDMV/BACKUP/CLIPINF/00056.clpi
sha3_256 39ab9c024fe85717e619484a90c56810e527876be2d78b299f1f21e58601c178 THE_GOONIES/BDMV/BACKUP/CLIPINF/00015.clpi
sha3_256 aa1edcd4a104d49a86803fcb1e7fa50f167ec0e3d240434511c907a4d7742460 THE_GOONIES/BDMV/BACKUP/CLIPINF/00001.clpi
sha3_256 67d71f83f8abf36d458012efb89e68051d1efe42a38467a630e0ce56c9a9d615 THE_GOONIES/BDMV/BACKUP/CLIPINF/00048.clpi
sha3_256 69302410560b0a51f02116c8c3377da15987c2f9f7ec72dba8b84fe8de7d7bee THE_GOONIES/BDMV/BACKUP/CLIPINF/00017.clpi
sha3_256 9b4ebfcaad55f6ed6a5ee35d12dc8b335029106c8f72453ccfdd8237828116f4 THE_GOONIES/BDMV/BACKUP/CLIPINF/00054.clpi
sha3_256 1d5e4cb07b6bd858ba94cff914b6b51226027fb2ffb62daa488c420a57c58c1e THE_GOONIES/BDMV/BACKUP/CLIPINF/00004.clpi
sha3_256 fc3e0c7bea12bae66e97842c886b50548252f2b2eac67442597cdb90562afb76 THE_GOONIES/BDMV/BACKUP/CLIPINF/00002.clpi
sha3_256 21820703a7266c65269175c22298a23cf1563d715274adcf60fcb1afc4c8c24b THE_GOONIES/BDMV/BACKUP/CLIPINF/00044.clpi
sha3_256 b1e82fa54104b8822f8416535f83a6dc2c6778ae49559019cec7cad3951b105a THE_GOONIES/BDMV/BACKUP/CLIPINF/00020.clpi
sha3_256 b8f57e78c39ff22df602b0881e14804ce16e891bb609f409d57ca54dcaf1e699 THE_GOONIES/BDMV/BACKUP/CLIPINF/00030.clpi
sha3_256 014607d2d08823c0b37997aa4d8929a92fe15fe847e17ec668507e47d2a93766 THE_GOONIES/BDMV/BACKUP/CLIPINF/00047.clpi
sha3_256 092069647a674fa39d5c69607585be3ea537059e6e405bb994b4c9bb3ed05c6e THE_GOONIES/BDMV/BACKUP/CLIPINF/00012.clpi
sha3_256 2d71db6947eae6bd6e266e4e74fc94d501c03b660cb32a0c52cdd172ec77e742 THE_GOONIES/BDMV/BACKUP/CLIPINF/00059.clpi
sha3_256 7e9736cca23e0fbabe92e8c80c6b4ab99dabaae891f6f543074c6f6942a761d2 THE_GOONIES/BDMV/BACKUP/CLIPINF/00026.clpi
sha3_256 f1a4dec4af1c7aaa0504e710234b765eaa7c853720e24558d1b20d7889bc58e5 THE_GOONIES/BDMV/BACKUP/CLIPINF/00011.clpi
sha3_256 a2e171671944ec27813261910c5957e255f72930eb459867d59ad5821aa47ee0 THE_GOONIES/BDMV/BACKUP/CLIPINF/00040.clpi
sha3_256 8da92c7957eb2a7e733fa9de146f4aaabccee6eea06ecba25a4290f764a57f0c THE_GOONIES/BDMV/BACKUP/CLIPINF/00014.clpi
sha3_256 cfbacf2619104e864ed939b95a4b9efb903aac2628fd6e553d245f836c22dccc THE_GOONIES/BDMV/BACKUP/PLAYLIST/00050.mpls
sha3_256 068ba49ce9c8824400662592c30604e5620d5dded5f74c03c29113af29e8f4d0 THE_GOONIES/BDMV/BACKUP/PLAYLIST/00800.mpls
sha3_256 d2571cbb90b610b5b2c7d4b05a2d9219bb8bcaa7887a98a3b0700df2cf558e1a THE_GOONIES/BDMV/BACKUP/PLAYLIST/00801.mpls
sha3_256 a2cdc7f49e833c3c867496ce92a5d00749541a0d5221482beaae874e1a680659 THE_GOONIES/BDMV/BACKUP/PLAYLIST/00120.mpls
sha3_256 6ff6b1af48bdf8800415b5812d3c58b446887ca7fe7e45a54560a4a59a2b0a35 THE_GOONIES/BDMV/BACKUP/PLAYLIST/00053.mpls
sha3_256 d94e8d0221ff77bc17eb104acc3d3c88cc9f257c4ed3699781dad64425a82f31 THE_GOONIES/BDMV/BACKUP/PLAYLIST/00142.mpls
sha3_256 738542a76e76ac475d695d9803c5f801bc1791617d457d2561f84bafe213ac25 THE_GOONIES/BDMV/BACKUP/PLAYLIST/00055.mpls
sha3_256 6f7689718ee04e13bc2c815dc2724966cbd08b2283f884f3bb5ee896afd5009d THE_GOONIES/BDMV/BACKUP/PLAYLIST/00016.mpls
sha3_256 fd56adf83298416183c448420d6c78507c2ec00d5d1d9d009c1e1ad3bab39d12 THE_GOONIES/BDMV/BACKUP/PLAYLIST/00017.mpls
sha3_256 b9d7ae1abf42f346432482a044f990d984d66646758843a27d1e12266d86df7b THE_GOONIES/BDMV/BACKUP/PLAYLIST/00099.mpls
sha3_256 9ce9e19f9685897722b5618697b60394f202ff71ea00f6bb3c054297af90a4c2 THE_GOONIES/BDMV/BACKUP/PLAYLIST/00014.mpls
sha3_256 67ade4cd541e7c71a8917652b7b0e109b97df183a694aa85223c370b03c3ff02 THE_GOONIES/BDMV/BACKUP/PLAYLIST/00056.mpls
sha3_256 bc5beac065109641ac2977d010490499c5dd9725530c2a3a17670c73ae00f61d THE_GOONIES/BDMV/BACKUP/PLAYLIST/00015.mpls
sha3_256 a2cdc7f49e833c3c867496ce92a5d00749541a0d5221482beaae874e1a680659 THE_GOONIES/BDMV/BACKUP/PLAYLIST/00140.mpls
sha3_256 dea9e53db9f04faf884948a5d73ce2cf1ad6ab36d2ce4dcffbfec9dc2844ac92 THE_GOONIES/BDMV/BACKUP/PLAYLIST/00013.mpls
sha3_256 032fc9f554753b04d329669403b81858ecbc36b40aa4184cd8801fb11a3e14b3 THE_GOONIES/BDMV/BACKUP/PLAYLIST/00049.mpls
sha3_256 64c10f538aaacf05e193aa65d665e986c92e920788a684b957ecfe96993b93c8 THE_GOONIES/BDMV/BACKUP/PLAYLIST/00054.mpls
sha3_256 9329dad3d4544dec65a9508133fe4b59e85281224d818d426b44b2ffaa6d356c THE_GOONIES/BDMV/BACKUP/PLAYLIST/00119.mpls
sha3_256 d94e8d0221ff77bc17eb104acc3d3c88cc9f257c4ed3699781dad64425a82f31 THE_GOONIES/BDMV/BACKUP/PLAYLIST/00122.mpls
sha3_256 9adf5990200588c9c41ac6cea9983459c0d58a20f257cd329d56b9d380057942 THE_GOONIES/BDMV/BACKUP/PLAYLIST/00052.mpls
sha3_256 9e39b62a179416c4cb1152e0c3ca987f11d01783f7a9d09f3643f9043b7d2497 THE_GOONIES/BDMV/BACKUP/PLAYLIST/00010.mpls
sha3_256 1a9aac08476b68009f76327b4bf0b8c56e496a1c9553bc2f3cda9104f5db6e47 THE_GOONIES/BDMV/BACKUP/PLAYLIST/00032.mpls
sha3_256 3bc7f0e7e95e34d16f9217f8af02f80b0e5acb45e2c1a2f9afcf2a8f10734db1 THE_GOONIES/BDMV/BACKUP/PLAYLIST/00012.mpls
sha3_256 534a155447ebb993176eb624326f63f82cb74fea4a5c3d7586021665f38283a6 THE_GOONIES/BDMV/BACKUP/BDJO/00003.bdjo
sha3_256 3a91b5c944438d0f9b638e842d9175754f4a73cae0e7dd332b7ea7bd4690e00d THE_GOONIES/BDMV/BACKUP/BDJO/00001.bdjo
sha3_256 fb8625d697189324fde5bf4e5058fef4b9aca889bae92cc7d084db60338329b0 THE_GOONIES/BDMV/BACKUP/BDJO/00000.bdjo
sha3_256 cb8234cc24ce03eff8a8e58b10dd24283a30be9a1b583d2eebbfc3dc9570a725 THE_GOONIES/BDMV/BACKUP/index.bdmv
sha3_256 001c93c241286eae89a1ee44a8a8e9f0504127e3c09f0cb8e5b995319fd6cef6 THE_GOONIES/BDMV/BACKUP/JAR/00000/Goonies_French_R2_Composite1.png
sha3_256 82d1b4c1c261c22696d00d0d1adda0a87c1835323f6a82c7065bb565452e4c86 THE_GOONIES/BDMV/BACKUP/JAR/00000/font_strip_Composite1.png
sha3_256 ac9db8ba6c14529847de9ece0011d1d6356b99f14ae55b68d9082b0f52ef621f THE_GOONIES/BDMV/BACKUP/JAR/00000/Goonies_French_R2_Composite2.png
sha3_256 953221f2b4759793b411a2ba5c27e0c65c0a6a1ccbbedca50dc06df85d53027a THE_GOONIES/BDMV/BACKUP/JAR/00000/Goonies_Japan_Composite2.png
sha3_256 4c715dab96fd580102e9bafec5a81d6deb872257e62a0544e31f2bf00f48acaf THE_GOONIES/BDMV/BACKUP/JAR/00000/Goonies_English_R2_Composite1.png
sha3_256 b970e8c0334fe17170437a339041a23d2f4d1ea0301e833f995262dfd75c5563 THE_GOONIES/BDMV/BACKUP/JAR/00000/Goonies_Japan_Composite1.png
sha3_256 b8313d5b0ee4c774cfac56ba52f11dd30406d9f90ebabc8b98a1bd9b5cdba947 THE_GOONIES/BDMV/BACKUP/JAR/00000/Goonies_English_R2_Composite2.png
sha3_256 c6561cc3470daaf72d4b56ceb0afb11cb0ba16eb3d7d7956a9d6d4dd1c1c2c93 THE_GOONIES/BDMV/BACKUP/JAR/88888/disc.properties
sha3_256 aa937897c36f45794a0d686e330e6e126a3f4e1678e533c08844e7531ab5fe14 THE_GOONIES/BDMV/BACKUP/JAR/88888/loadingAnimation.xml
sha3_256 6645c7bb2284c1d8192b72ea2a8876d2880fe53e0f11f815240789fb2d97ac3d THE_GOONIES/BDMV/BACKUP/JAR/88888/LoadingComposite1.png
sha3_256 534a155447ebb993176eb624326f63f82cb74fea4a5c3d7586021665f38283a6 THE_GOONIES/BDMV/BDJO/00003.bdjo
sha3_256 3a91b5c944438d0f9b638e842d9175754f4a73cae0e7dd332b7ea7bd4690e00d THE_GOONIES/BDMV/BDJO/00001.bdjo
sha3_256 fb8625d697189324fde5bf4e5058fef4b9aca889bae92cc7d084db60338329b0 THE_GOONIES/BDMV/BDJO/00000.bdjo
sha3_256 e684d97e804af86ab0194097efdcb74206a7dfb2673bf18b9c4aca5bd1f73287 THE_GOONIES/BDMV/META/DL/Goonies_metadata416.JFIF
sha3_256 38b27e339ecb4dc48346d0aef39927da0cf8d35b06f641eb623425f3bb273271 THE_GOONIES/BDMV/META/DL/bdmt_jpn.xml
sha3_256 0dcfe82549d094695d40fa916535cb330e99dd608307acbf32b0f7cca8dbe179 THE_GOONIES/BDMV/META/DL/bdmt_eng.xml
sha3_256 38b27e339ecb4dc48346d0aef39927da0cf8d35b06f641eb623425f3bb273271 THE_GOONIES/BDMV/META/DL/bdmt_fra.xml
sha3_256 cd93b1fa0c105148380a8eaba9582ba32cba7101d2438b7ef01628eaf122f9d3 THE_GOONIES/BDMV/META/DL/Goonies_metadata640.JFIF
sha3_256 cb8234cc24ce03eff8a8e58b10dd24283a30be9a1b583d2eebbfc3dc9570a725 THE_GOONIES/BDMV/index.bdmv
sha3_256 43f25c7f5eece99818a25d6a6dc755682c93480569d773da87144641e97490da THE_GOONIES/BDMV/AUXDATA/00000.otf
sha3_256 150c89089ea7378d79df63392628fe1b24558506a73aa8a760cbde3c396b8401 THE_GOONIES/BDMV/AUXDATA/00001.otf
sha3_256 efda09bd8545b46af3223681bdf9f79afbc9fdee4e1f75dde5a5b1e98de2534b THE_GOONIES/BDMV/AUXDATA/sound.bdmv
sha3_256 001c93c241286eae89a1ee44a8a8e9f0504127e3c09f0cb8e5b995319fd6cef6 THE_GOONIES/BDMV/JAR/00000/Goonies_French_R2_Composite1.png
sha3_256 82d1b4c1c261c22696d00d0d1adda0a87c1835323f6a82c7065bb565452e4c86 THE_GOONIES/BDMV/JAR/00000/font_strip_Composite1.png
sha3_256 ac9db8ba6c14529847de9ece0011d1d6356b99f14ae55b68d9082b0f52ef621f THE_GOONIES/BDMV/JAR/00000/Goonies_French_R2_Composite2.png
sha3_256 953221f2b4759793b411a2ba5c27e0c65c0a6a1ccbbedca50dc06df85d53027a THE_GOONIES/BDMV/JAR/00000/Goonies_Japan_Composite2.png
sha3_256 4c715dab96fd580102e9bafec5a81d6deb872257e62a0544e31f2bf00f48acaf THE_GOONIES/BDMV/JAR/00000/Goonies_English_R2_Composite1.png
sha3_256 b970e8c0334fe17170437a339041a23d2f4d1ea0301e833f995262dfd75c5563 THE_GOONIES/BDMV/JAR/00000/Goonies_Japan_Composite1.png
sha3_256 b8313d5b0ee4c774cfac56ba52f11dd30406d9f90ebabc8b98a1bd9b5cdba947 THE_GOONIES/BDMV/JAR/00000/Goonies_English_R2_Composite2.png
sha3_256 c6561cc3470daaf72d4b56ceb0afb11cb0ba16eb3d7d7956a9d6d4dd1c1c2c93 THE_GOONIES/BDMV/JAR/88888/disc.properties
sha3_256 aa937897c36f45794a0d686e330e6e126a3f4e1678e533c08844e7531ab5fe14 THE_GOONIES/BDMV/JAR/88888/loadingAnimation.xml
sha3_256 6645c7bb2284c1d8192b72ea2a8876d2880fe53e0f11f815240789fb2d97ac3d THE_GOONIES/BDMV/JAR/88888/LoadingComposite1.png
sha3_256 9e7028eab0a1f54029e570f1c4d500e1365df20d703f3390c83c544d909bf332 THE_GOONIES/BDMV/JAR/00001.jar
This might be the Goonies version, I really don't know where this information is or if it's available, so this might be wrong/unreliable. From the file "TheGooniesXletUHD01.version" within the file "THE_GOONIES/BDMV/JAR/00001.jar":
#Wed, 20 May 2020 11:59:11 -0400
xlet=title.TheGooniesXletUHD01
SKU=UHD01
version=8
date=200520
studio=Warner
beandog
Post by beandog »
I know you're not interested in using mpv, but it does support bluray playback (although I can't remember the CLI syntax off the top of my head). At the very *least* it'll let you know that it ripped correctly. And I mean opening it as if it were a disc, not individual files.
Found the syntax: https://mpv.io/manual/master/#protocols
If you're comfortable compiling stuff from source, there's a few more options I could send your way.
mas1701
Post by mas1701 »
Thanks for feedback. I found out that the problem is related to the Blu-ray discs I tested with. Turned out these specific discs cause problems no matter the OS or ripping software used. Unfortunately, they were the first two of a new show I got on Blu-ray, so I had no previous experience with this set of discs.
Meanwhile, I was able to test with some other discs and they work. So it is neither VLC nor MakeMKV. Maybe it has something to do with Java version compatibility - although I've been lucky so far (obviously - or I would've had problems much sooner).
MrPenguin
Post by MrPenguin »
mas1701 wrote:
Wed Apr 10, 2024 11:56 am
Well, maybe they do or maybe they don't, because you still haven't provided a shred of useful information about your problem :roll:.
