Pioneer/Verbatim 43888 Firmware?
Derp1984
#1 Post by Derp1984 » Tue Apr 02, 2024 3:03 am
Hey all,
Just got my first drive in the mail today. The specs in MakeMKV indicate that the firmware should be okay but I'm not able to rip 4K and I'm also not getting any audio in my blu-ray rips.
I'm super new to this. I've tried to glean all I could from the forums but I'm not quite grasping what I could be doing wrong or what I need to do.
DavoBR
Re: Pioneer/Verbatim 43888 Firmware?
#2 Post by DavoBR » Tue Apr 02, 2024 3:15 am
I'd suggest posting the specs so those in the know can maybe help?
#3 Post by MartyMcNuts » Tue Apr 02, 2024 4:58 am
Derp1984 wrote: Tue Apr 02, 2024 3:03 am Hey all,
Did you allow MakeMKV internet access so it can download the hashed keys for UHD ripping?
What does the log say?
Derp1984
#4 Post by Derp1984 » Tue Apr 02, 2024 9:54 am
Hey there!
Sorry I knew to do that and didn't.
MakeMKV v1.17.6 win(x64-release) started
Downloading latest SDF to C:\Users\randa/.MakeMKV ...
Automatic SDF downloading is disabled or failed.
Using LibreDrive mode (v01.0 id=489CDFD6D392)
Downloading latest HK to C:\Users\randa/.MakeMKV ...
Saved AACS dump file as C:\Users\randa/.MakeMKV/MKB20_v68_Once_Upon_a_Time_in_Hollywood_F22B.tgz
MrPenguin
#5 Post by MrPenguin » Tue Apr 02, 2024 10:23 am
Derp1984 wrote: Tue Apr 02, 2024 3:03 am Just got my first drive in the mail today. The specs in MakeMKV indicate that the firmware should be okay but I'm not able to rip 4K and I'm also not getting any audio in my blu-ray rips.
I have successfully ripped two UHD discs using a Verbatim 43888 drive with MakeMKV 1.17.5+, and so I am confident that it can work. However, mine were both well-known discs whose keys were already available. FYI I have reason to believe that LibreDrive cannot read a UHD disc's VID value correctly with a Verbatim 43888, which would likely make its dump files useless for sending to svq@makemkv.com to generate new keys.
#6 Post by Billycar11 » Tue Apr 02, 2024 11:03 am
Derp1984 wrote: Tue Apr 02, 2024 9:54 am Hey there!
well thats the problem you need to fix you internet blocking key downloads or enable them
thigs to try are change your dns
remove geo blocking for russia
vpn
Derp1984
#7 Post by Derp1984 » Tue Apr 02, 2024 8:04 pm
[/quote]
vpn
[/quote]
Is there a way to do this without having to pay for a VPN or proxy server?
#8 Post by Billycar11 » Tue Apr 02, 2024 10:48 pm
Derp1984 wrote: Tue Apr 02, 2024 8:04 pm
Yeah try changing your DNS and geoblocking settings as I said
Derp1984
#9 Post by Derp1984 » Wed Apr 03, 2024 12:55 am
tbh I don't know how to change geoblocking. I was able to change DNS but that didn't help.
#10 Post by dcoke22 » Wed Apr 03, 2024 3:15 am
Derp1984 wrote: Wed Apr 03, 2024 12:55 am tbh I don't know how to change geoblocking. I was able to change DNS but that didn't help.
Geoblocking is usually a thing in one's router. Folks who have it generally know that they do. If you don't really know what that is, then you probably don't have it.
Hopefully you've read about hashed keys. That's what MakeMKV is trying to download so it can decrypt the UHD you're trying to rip. If ripping UHDs is something you're intending to do going into the future, getting that work is something you're going to have to figure out.
There is the alternative, older method of using KEYDB.cfg. There are posts on this forum explaining how to use it. It might work.
Derp1984
#11 Post by Derp1984 » Wed Apr 03, 2024 8:53 am
I figured it out.
I had my firewall up. Also I was confused by "geoblocking" because there didn't seem to be any sources linking it to my router until that comment. With Xfinity, it's referred to as "advanced security" and can be disabled through their app.
Thanks everyone!
