The question is really, why would you need to flash it?
UHD didn't start shipping until almost two years after this drive was built, so it doesn't add anything to your capabilities.
G.P.L.
Post by G.P.L. »
Hello everybody,
The Abyss UHD disc toasted my ASUS BW-16D1HT drive that I've had working for over 3 years. My system recognizes the drive (internally and externally), but no type of disc can be read. I'm thinking that something happened with the optics inside the drive.
So, I bought another ASUS BW-16D1HT internal drive. It comes with firmware 3.11.
Manufacturer: ASUS
Product: BW-16D1HT
Revision: 3.11
Serial number: KL9N7ED3329
Firmware date: 2120-12-01 17:59
Bus encryption flags: 1F
Highest AACS version: 81
I tried to downgrade the firmware to DE_ASUS_BW-16D1HT_3.02.bin and then 3.01 with ASUS_ODD_FW_Changer_(Modified).exe, but each time I got the error:
Updating Failure #5.
Then I tried using SDFtool Flasher.exe (as well as the older version) with the same .bin file for 3.02, but it gave me the error:
Command produced error code #0xff056103
I'm using Windows 7 64-bit, and the drive is connected internally. The .exe files were Run As Administrator.
I'd be very grateful for any advice that is available.
Thanks.
Gary
The very first post in this thread is maintained and has a section titled "Recommended Firmware to flash for MakeMKV:"
And in there is says: Asus BW-16D1HT on any Firmware directly to > Asus BW-16D1HT 3.10MK
I think the 3.11 firmware is encrypted, so you've got to go to 3.10MK first. You can go to 3.02 or whatever after going to 3.10MK. The SDFtool is the recommended tool to use.
BTW, if buying a new drive today, buying a Pioneer drive with an older, supported firmware from a seller in your region is the way to go.
G.P.L.
Post by G.P.L. »
Thanks for the reply.
I did see that post, but I couldn't find the 3.10 .bin file.
Any idea where it is?
It didn't come with the .zip file that contained the SDFtool Flasher.exe and 3.02 .bin files.
G.P.L. wrote: Sat Mar 23, 2024 8:09 pm Thanks for the reply.
It is in the first post. There's a section titled "Unlocked Flashers, Downgrade Enabled Firmware and MK Firmware:"
The first link in there is called "The all you need firmware pack".
Exc3l
Post by Exc3l »
Hello All!
I see in the beginning of the post it mentions that the Pioneer drives do not work unless they come with an older version of hardware.
Later on in the post though it says they are now supported by MakeMKV.
Am I now able to just purchase one off of Amazon or is it still recommended to purchase a preflashed item from a seller?
G.P.L.
Post by G.P.L. »
dcoke22 wrote: Sat Mar 23, 2024 11:24 pm
Excellent!
Thank you very much! It worked perfectly.
In fact, I went and bought a second drive as a backup, and downgraded it as well.
I'm now in the process of ripping True Lies to test it out. So far, so good!
Exc3l wrote: Sun Mar 24, 2024 4:12 pm Hello All!
Pioneers with new fw do not work you would need to buy one from a seller that has them with old firmware
jayper
Post by jayper »
It looks like the Vantec NST-510S3-BK 9.5mm slim sata case has been discontinued. Is there another good recommended case for the LG BU40N?
asmcom
Post by asmcom »
jayper wrote: Mon Mar 25, 2024 9:16 pm It looks like the Vantec NST-510S3-BK 9.5mm slim sata case has been discontinued. Is there another good recommended case for the LG BU40N?
It has not been discontinued in Europe.
Asmcom :mrgreen:
jayper
Post by jayper »
Does anyone know if this might work?
https://www.amazon.com/Vantec-Slim-Opti ... r=8-4&th=1
asmcom
Post by asmcom »
jayper wrote: Tue Mar 26, 2024 11:40 pm
Slim case has not been discontinued, we gave plenty and more on order.
Asmcom
jayper
Post by jayper »
According to the Vantec USA site, it has been discontinued.
https://www.vantecusa.com/products_deta ... -+Products
Either way, I am not looking to debate whether or not it is discontinued.
I am trying to understand if this would work with the LG BU40N - https://www.amazon.com/Vantec-Slim-Opti ... r=8-4&th=1
jayper wrote: Wed Mar 27, 2024 2:40 am According to the Vantec USA site, it has been discontinued.
No, as the BU40N is 9.5mm
jayper
Post by jayper »
Understood, thanks very much.
