Run synchronize.bat and move the new version to the folder. 2 versions of the movie have just been added.
UHD discs decrypting
Re: UHD discs decrypting
Yeah, I had just done that, but no luck with vanilla MakeMKV. Tried Any DVD and it worked.
Wow... I completely forgot I had changed this a long time ago and was racking my brain to understand as to why the keydb.cfg file was not read by Makemkv... Thanks!
Someguy1234 wrote: ↑Sun Feb 18, 2024 2:15 amI couldn't get the version in the link to download and found the v1.72 elsewhere. I can't get this to work, even after using someone's suggestion of adding a line to the batch file. It put the keydb.cfg in the /.Makemkv folder but all of the discs I've been inserting are still creating dump files and failing. I'm a bit confused how this is working for some?Coopervid wrote: ↑Sun Dec 24, 2023 10:57 pmIf your discs aren't supported you can try this.
Download FindVUK 1.72.
https://forum.doom9.org/showthread.php?t=172472
Put it somewhere.
Run FindVUK - Synchronize.bat
It will write a file keydb.cfg to C:\users\USERNAME\Appdata\Roamimg\AACS
Make a copy of this file and copy to:
C:\users\USERNAME\.Makemkv
Put your disc in the drive.
Run Makemkv.
Then run the Synchronize.bat from time to time in order to get new UHD keys. Replace the updated one and copy to the .Makemkv folder.
i get the same thing. no download or anything. I wondering if something is blocking the download? chrome, antivirus or my router. any thoughts anyone?
