James Bond - Casino Royale, Spectre, Quantum of Solace, Skyfall
LoneBal
Re: James Bond - Casino Royale, Spectre, Quantum of Solace, Skyfall
Post by LoneBal »
Gryphon wrote:
Mon Mar 22, 2021 9:26 pm
LoneBal wrote:
Sat Mar 20, 2021 11:39 pm
Has anyone had any luck with Quantum of Solace 4K?
I ran that disk through 1.15.4 a couple weeks ago without issue. Checked again just now & it's still reading it.
Thanks. Do you know where you got that copy? I know there are usually multiple keys as there are different discs out there. Got mine from amazon, Feb 2020 version.
Gryphon
Post by Gryphon »
LoneBal wrote:
Tue Mar 23, 2021 7:42 pm
Probably Best Buy, as part of the Daniel Craig 4 movie box set. Looks like I bought it in the fall of 2019, when it first came out.
LoneBal
Post by LoneBal »
Gryphon wrote:
Tue Mar 23, 2021 8:49 pm
Thank you! Local store had 1 copy left, and it worked! Also with lenient return policies on the originals, costs me less overall.
chetk
Post by chetk »
Sorry to revive an old thread, but I am using the same Daniel Craig Collection you mentioned. I bought it a few years ago and just now starting to attempt to rip my library. Tried converting to MKV using MakeMKV twice last night. It found the key, no problem, but the actual rip fails about half way in. I'm using an Asus W-16D1HT with flashed firmware to 3.10.
This is also true with most, if not all, of the Game of Thrones complete collection 4K Blu-ray set, but that set is known to be $#!+ manufactured in Mexico. They won't even play back in most 4K Blu-ray players.
Anyone have any advice for getting this set to convert to MKV?
Depends on why it failed. If it has trouble reading the disk, cleaning it is the first step.
AnBird
Post by AnBird »
Dump submitted for
MKB20_v72_Spectre_62E9
MrPenguin
Post by MrPenguin »
AnBird wrote:
Thu Oct 16, 2025 7:48 am
Dump submitted for
Could you also share your TGZ dump file please, so that people can try adding it to KEYDB too?
You might also need to share the AACS/MKB_RO.inf file from your physical UHD disk too, since the copy of this file inside your TGZ dump file has almost certainly been truncated to only 56 bytes, which would make it unusable to anyone except MakeMKV itself.
Edit: Never mind, found it! :)
