LibreDrive for Pioneer drives
Post by MartyMcNuts » Mon Feb 26, 2024 10:56 pm
sikk788 wrote: Mon Feb 26, 2024 3:51 pm
asmcom wrote: Mon Feb 26, 2024 8:36 am We have posted on MakeMKV about the issues with the BDR-UD04 and links to other forums with very poor reviews. Please see the links below.
If you are looking for playback, this drive is out as it freezes repeatedly.
viewtopic.php?f=16&t=33094
viewtopic.php?f=16&t=30198&start=45
The Pioneer drives we sell have proven exceptionally reliable in our lineup, except for the BDR-UD04, which is designed for enterprise entry-level budget usage.
Please see our seller page on this forum.
viewtopic.php?t=19387
Asmcom
I'm confused, in your seller page you are selling BDR-UD04 saying it's UHD friendly, here you are saying it freezes repeatedly. In either case, I'm not looking for playback, I'm looking for ripping with MakeMKV only, does that change around the odds? Am I correct in that ripping is reliable with BDR-UD04 but playback is not?
I read the following on reddit, is there any truth to the below in italics?
The European versions have a Pioneer BDR-UD04 drive inside that has Firmware 1.14. The US version is Verbatim 43890 and Verbatim 43889 that has a Pioneer BDR-UD03 drive that is not LibreDrive and cannot be used to rip 4K UHD discs yet and firmware to flash UD03 to UD04 is not available publicly. The European version Verbatim 43888 just works right out of the box without any firmware flashing.
It was written 2 months ago, many thanks!
Correct. The 43888 is fine for ripping UHD discs.
sikk788
Post by sikk788 » Mon Feb 26, 2024 11:09 pm
MartyMcNuts wrote: Mon Feb 26, 2024 10:56 pm Correct. The 43888 is fine for ripping UHD discs.
Thank you, appreciated!
asmcom
Post by asmcom » Tue Feb 27, 2024 1:33 am
Asmcom
We suggest you do some reading on the forum, then you won't be confused.
Asmcom
asmcom
Post by asmcom » Tue Feb 27, 2024 1:38 am
asmcom wrote: Tue Feb 27, 2024 1:33 am
Asmcom
Just to clarify: The drives that have been returned faulty by customers are all unable to read Blu-ray discs, most of them the laser has failed.
We have had 23 faulty drives returned in 9 months period. Compared to one Pioneer retail drive. We find this particular model to be our least reliable drive.
Please ensure you read the links on the DBPOWERAMP forum about the reliability problems of this drive.
Asmcom
torque-wrench
Post by torque-wrench » Tue Feb 27, 2024 3:34 pm
Tom886 wrote: Thu Sep 14, 2023 10:27 am
miba78 wrote: Mon Sep 04, 2023 8:22 pm Hi Tom886,
which tool did you use to flash the BDR-209EBK to BDR-211, please?
Sorry, I was absent for a few days, so didn't see your message.
I believe you got help already, and I have to admit, I am not sure whether it is allowed to share links to another forum.
But I can tell you, it's available on a Polish forum, however, not public.
Tom
Hi Tom886,
i also own a BDR-209EBK and want to crossflash to BDR-211.
Can you please tell how do you have done this ?
Sorry for writing here, but i can not wirte PM´s yet.
Best Regards
Post by Billycar11 » Tue Feb 27, 2024 7:52 pm
torque-wrench wrote: Tue Feb 27, 2024 3:34 pm
Tom
Hi Tom886,
Best Regards
Email me for an automated flasher see below for email and price
tspan09
Post by tspan09 » Thu Feb 29, 2024 5:51 am
I have a PIONEER BD-RW BDR-S13U running firmware version 1.05. Is there any hope of flashing this drive so that it will work with MakeMKV? I'm running on MacOS.
Error: LibreDrive compatible drive is required to open this disc - video can't be decrypted.
Post by Billycar11 » Thu Feb 29, 2024 5:57 am
tspan09 wrote: Thu Feb 29, 2024 5:51 am I have a PIONEER BD-RW BDR-S13U running firmware version 1.05. Is there any hope of flashing this drive so that it will work with MakeMKV? I'm running on MacOS.
its possible but not likely.
i would recommend you return it and order a pioneer drive with old fw in your region i have some UBKs still but this will be my last batch until late march my supplier is out currently.
bmcampjr
Post by bmcampjr » Sun Mar 03, 2024 1:50 am
I have a Pioneer BDR-XD08UMB-S that has yet to read a 4K disk.
It has V1.02 Rom
Post by MartyMcNuts » Sun Mar 03, 2024 4:07 am
bmcampjr wrote: Sun Mar 03, 2024 1:50 am I have a Pioneer BDR-XD08UMB-S that has yet to read a 4K disk.
It has V1.02 Rom
Either return it or hold on to it and hope that it one day gets supported.
asmcom
Post by asmcom » Sun Mar 03, 2024 5:45 pm
It has V1.02 Rom
We have BDR-XD08EMB-S which is same drive with Libre-Drive firmware.
Asmcom :mrgreen:
bmcampjr
Post by bmcampjr » Mon Mar 04, 2024 4:11 pm
I am trying to continuously read a 4K disk in an effort to get libreDrive installed. Don't know what else to do.
Post by Coopervid » Mon Mar 04, 2024 9:18 pm
Forget it. You have the scrambled and degraded firmware and no relief is in sight.
bmcampjr
Post by bmcampjr » Tue Mar 05, 2024 3:37 am
Should I upgrade to 1.03?
Post by Billycar11 » Tue Mar 05, 2024 3:39 am
bmcampjr wrote: Tue Mar 05, 2024 3:37 am Should I upgrade to 1.03?
no
really you should return it and buy a pioneer from a seller in your region
