Makemkv is useless
Re: Makemkv is useless
#31 Post by SamuriHL » Mon Feb 19, 2024 8:18 pm
It's helpful but ultimately unnecessary to have FindVUK. You can download the keydb directly from the website. FindVUK just makes it easier to keep it up to date.
#32 Post by Coopervid » Mon Feb 19, 2024 8:29 pm
...and with the .bat file it's 1-2-3. No fumbling. All is done automatically.
rkhollister
#33 Post by rkhollister » Mon Feb 19, 2024 8:33 pm
Ah - found the URL in the ini file. Thx for the heads up for us Mac users
rkhollister
#34 Post by rkhollister » Mon Feb 19, 2024 8:38 pm
So this kinda begs the question of why MakeMKV doesn't just download & use that key file directly instead of rolling its own?
MrPenguin
#35 Post by MrPenguin » Mon Feb 19, 2024 8:50 pm
Partly because KEYDB.cfg is a "legacy" format that contains less information than either MakeMKV's database or even FinkVUK's XML files.
#36 Post by SamuriHL » Mon Feb 19, 2024 8:51 pm
Because as kuel as the keydb is, and it is very very awesome, it's user generated. Meaning it requires people to upload keys. And that's hardly comprehensive of every single disc that someone may encounter. Whereas submitting a dump to MakeMKV submits the data necessary to always (AACS 2.1 notwithstanding) decrypt the keys. I'm just thankful Mike left support for reading the keydb in place.
#37 Post by Coopervid » Mon Feb 19, 2024 10:44 pm
Not anymore.
MrPenguin
#38 Post by MrPenguin » Tue Feb 20, 2024 12:53 am
Not anymore.
Err, really? KEYDB.cfg doesn't contain any field for (say) whether the disc uses bus-encryption, whereas FindVUK's XML file does. Everything that comes after ";" in KEYDB.cfg is just a free-format comment.
#39 Post by SamuriHL » Tue Feb 20, 2024 1:05 am
EVERY UHD contains bus encryption so that's pointless. The only thing that REALLY matters is the decryption key(s) and the disc ID. It's not like you get to see all that great information from MakeMKV's hashed keys which are embedded and encrypted.
MrPenguin
#40 Post by MrPenguin » Tue Feb 20, 2024 1:11 am
And some non-UHD discs also contain bus encryption. The point is that KEYDB.cfg was created before bus encryption (and UHD!) even existed and so obviously its format doesn't support it.
#41 Post by SamuriHL » Tue Feb 20, 2024 1:39 am
And if you enable LIbreDrive, bus encryption ceases to become a problem. Again, the only thing that REALLY matters is the unit keys and the disc ID. All the other information is wholly irrelevant.
Peterduke
#42 Post by Peterduke » Fri Jan 31, 2025 8:46 pm
Someguy1234 wrote:
Thu Feb 15, 2024 8:29 am
Radiocomms237 wrote:
Sat Feb 03, 2024 12:41 am
Sounds like he is talking about sending dumps for new UltraHD discs and having to wait for the keys to be added.
I agree the system is flawed, but it's the only option we have for ripping UHDs at the moment, so it is what it is.
I agree. The software is now where you A) have to be using a VPN in the United States to even download the new keys when the dump files are decrypted and B) you have to wait up to three weeks for a new 4K UHD Blu-ray to be able to be ripped. However, I can only imagine that what Mike does can't be easy. Or, I'm starting to worry about Mike and the servers that he uses for things. Anyone else starting to actually get worried that UHD discs that are post-January 30th or so release will no longer rip? I mean this is a possible reality.
That’s my issue if I don’t use a vpn I can’t get the keys it just says failed to download, i
Try downloading them from another database website and extracting them but Makemkv won’t read them. I used to use anydvd hd until they closed down and I had no issues downloading the keys from anydvd hd but now they are gone and some fake Chinese websites took over their domain.
I want to love Makemkv but every time it needs to download the database I am cooked unless I pay for a vpn
#43 Post by d00zah » Fri Jan 31, 2025 8:49 pm
There are options. Have you tried?
Free VPN to protect your privacy
Peterduke
#44 Post by Peterduke » Fri Jan 31, 2025 9:24 pm
I tried troubleshooting, disabling firewall, AV, adding exceptions, reinstalling Makemkv I think I’m running out of options
#45 Post by d00zah » Fri Jan 31, 2025 9:29 pm
But still haven't tried the *FREE* VPN i linked? Not the greatest, but free & for the purpose of this exercise...
