Honestly I wouldn't buy it. Better off buying a new one and flashing it to WH16NS60 1.92-MKjcvb_ wrote: ↑Fri Jan 26, 2024 12:58 pmHi guys,
I hope this is the right place to post my question.
I am looking to buy this LG BH16NS55, in hope it supports ripping of uhd blu-rays. As I don't have it yet, i can't post any information makemkv would provide. The seller sent me a picture of the drives label, but i find the information found in this thread hard to understand. Can anyone help me make sense of it?
The label states:
MODEL: BH16NS55
[chinese characters] 2016 01 25
ROM VER:1.20
MANUFACTURED: JANUARY 2016 RoHS
SVC CODE:NS55
Does this drive need to be flashed, and if so, which version would be the correct one?
Ultimate UHD Drives Flashing Guide Updated 2025
i bought a 213EBK a few weeks ago.
Can someone provide me with a UHD firmware incl. flash tool?
Thanks !!
Thanks !!
You know the go to guy.turntable97 wrote: ↑Tue Jan 30, 2024 9:26 pmHi,
Thanks !!
Seems I've got a pretty old drive which I'd like to flash. Can anybody tell me if this drive is possible to flash and what firmware to use?
OS device name: E:
Manufacturer: ASUS
Product: BW-16D1HT
Revision: 1.01
Serial number: K94EA6A3122
Firmware date: 2113-02-05 19:30
Bus encryption flags: 1F
Drive platform: MT1939
Firmware version: 1.01
BD raw metadata read: Partial
Hello everyone. I did everything & my drive has been patched properly. But it's not detecting any disc- be it cd or dvd or blu ray.
Can anyone help me about what to do?
No don't flash itBoehserWolf wrote: ↑Sun Feb 04, 2024 11:03 amSeems I've got a pretty old drive which I'd like to flash. Can anybody tell me if this drive is possible to flash and what firmware to use?
Drive Information OS device name: E: Manufacturer: ASUS Product: BW-16D1HT Revision: 1.01 Serial number: K94EA6A3122 Firmware date: 2113-02-05 19:30 Bus encryption flags: 1F LibreDrive Information Status: Enabled Drive platform: MT1939 Firmware type: Original (unpatched) Firmware version: 1.01 DVD all regions: Yes BD raw data read: Yes BD raw metadata read: Partial Unrestricted read speed: Yes No disc inserted
Flashing it will kill it
What's the build date on your drive 2016+ as the guide says?bittuvns12 wrote: ↑Mon Feb 05, 2024 2:01 pmHello everyone. I did everything & my drive has been patched properly. But it's not detecting any disc- be it cd or dvd or blu ray.
1-It's made in 2017.Billycar11 wrote: ↑Mon Feb 05, 2024 9:35 pmWhat's the build date on your drive 2016+ as the guide says?bittuvns12 wrote: ↑Mon Feb 05, 2024 2:01 pmHello everyone. I did everything & my drive has been patched properly. But it's not detecting any disc- be it cd or dvd or blu ray.
2-My drive used to work just fine before firmware update. Then I installed this firmware for getting the Libre drive functions. But now it's not reading any disc. Have tried changing firmware version to wh16s60mk 1.03 also but it's still not working.
I tried attaching a picture of my makemkv description but that 1.5mb is ablve allotted quota. Will try to copy & paste it manually.
use imgur or similar and just link it you could aslo embed it but its whateverbittuvns12 wrote: ↑Mon Feb 05, 2024 11:59 pm
what drive do you have and what fw did you go to?
Drive InformationBillycar11 wrote: ↑Tue Feb 06, 2024 1:31 amuse imgur or similar and just link it you could aslo embed it but its whateverbittuvns12 wrote: ↑Mon Feb 05, 2024 11:59 pm
OS device name: K:
Product: BD-RE WH16NS60
Revision: 1.02
Serial number:
Firmware version: 1.02
We need to know what kind of drive that was before you flashed it. If you don't remember please pull it out of your PC and tell us what's on the sticker.
We highly recommend avoiding this product as it may be a counterfeit. If you're considering purchasing from Aliexpress, be cautious. We recently bought two drives from a seller on the platform out of curiosity about their quality, but regretfully, they turned out to be of poor quality with numerous read errors. The sellers assured us that the drives were original but also said he had copies.jcvb_ wrote: ↑Fri Jan 26, 2024 12:58 pmHi guys,
The label states:
MODEL: BH16NS55
ROM VER:1.20
SVC CODE:NS55
See the website. He will openly tell you he can copy any drive. Scary world! We do have brand new Hitachi BH16NS55 and ASUS desktop drives, but to be hones these drives do not read all BD100 3 layer discs.
https://tuowang.aliexpress.com/store/5961003
Asmcom
Re: Ultimate UHD Drives Flashing Guide Updated 2023 - BRUHD-PU3-BK
Hi Guys
Just a few question before i accidentally brick my new drive.
It's a "Buffalo BRUHD-PU3-BK", bought that (from Japan) because it's listed as a good drive.
MakeMKV says this:
I use it on a Mac, so i'm not sure if it's encrypted or not.
This guide i followed: viewtopic.php?p=74718#p74718
Now i'm at step 7 and unsure if i have to use the first or second command.
or
First of all, i'm not sure if it's the right Firmware "DE_LG_BU40N_1.03_MK.bin", and second, which command to use.
I'm almost sure i'll have to use the second command (for the encrypted one), but better just ask before brick
Thanks for your help
MakeMKV says this:
./makemkvcon f -l
Found 1 drives(s)
00: /IOBDServices/3084F95F
BUFFALO_Optical_Drive_BU14_212106211330_MODN9KA0530
./makemkvcon f -d '/IOBDServices/3084F95F' -f /tmp/sdf.bin rawflash main -i /tmp/DE_LG_BU40N_1.03_MK.bin
./makemkvcon f -d '/IOBDServices/3084F95F' -f /tmp/sdf.bin rawflash enc -i /tmp/DE_LG_BU40N_1.03_MK.bin
the one with enc should work_D3V_ wrote: ↑Thu Feb 08, 2024 7:18 pmHi Guys
MakeMKV says this:
Now i'm at step 7 and unsure if i have to use the first or second command.Code: Select all
./makemkvcon f -l Found 1 drives(s) 00: /IOBDServices/3084F95F BUFFALO_Optical_Drive_BU14_212106211330_MODN9KA0530
orCode: Select all
./makemkvcon f -d '/IOBDServices/D5D25996' -f /tmp/sdf.bin rawflash main -i /tmp/DE_LG_BU40N_1.03_MK.bin
First of all, i'm not sure if it's the right Firmware "DE_LG_BU40N_1.03_MK.bin", and second, which command to use.Code: Select all
./makemkvcon f -d '/IOBDServices/D5D25996' -f /tmp/sdf.bin rawflash enc -i /tmp/DE_LG_BU40N_1.03_MK.bin
