any known non-UHD BDs with Bus Encryption Enabled
jemima
#1 Post by jemima » Sat Jan 20, 2024 2:29 am
Hey there.
Hopefully not too off-topic, but for experimenting a bit with my setup, I wanted to check a non-UHD BD that does however request Bus Encryption (i.e. the Bus Encryption Enabled flag).
If someone know such (non-UHD) BDs or if there'd be list, I'd be happy to hear from it.
The only one that I found out which might have it (namely "The Alien Anthology Archives disc from Alien Anthology") is a bit too expensive to buy just for some minor testing.
Thanks in advance,
Jemima
jemima
Re: any known non-UHD BDs with Bus Encryption Enabled
#2 Post by jemima » Mon Feb 05, 2024 8:42 pm
FYI: many such mediums are marked with "BEE" in the well known libaacs config file.
MrPenguin
#3 Post by MrPenguin » Mon Feb 05, 2024 8:55 pm
jemima wrote: Sat Jan 20, 2024 2:29 am Hopefully not too off-topic, but for experimenting a bit with my setup, I wanted to check a non-UHD BD that does however request Bus Encryption (i.e. the Bus Encryption Enabled flag).
Try "Oppenheimer". It's also a good movie in its own right.
