Chaos_Sandwich
Re: Pioneer firmware update February 2023
#151 Post by Chaos_Sandwich » Fri Dec 08, 2023 10:13 pm
CoffeeDrinker wrote:
Fri Dec 08, 2023 9:02 pm
I think we just have to wait.
In that case are there any other recommended slot drives? What Im planning would really benefit from a slot drive but I cant find any others on the market except for some bare slim SATA drives and im not sure if those would even work
lacabl
#152 Post by lacabl » Sat Dec 09, 2023 12:18 pm
alminderson wrote:
Wed Sep 13, 2023 5:26 pm
I'd like to transition my LibreDrive status from Possible, not yet enabled to Enabled.
Running MakeMKV v1.17.4 on macOS Ventury 13.5.2:
Manufacturer: PIONEER
Product: BD-RW BDR-XS07U
Revision: 1.03
Firmware date: 2023-01-06
Bus encryption flags: 13
Highest AACS version: 655
Firmware version: ID05
My goal here, really, is just to remove the 2x speed limit for archiving my discs, and achieve the drive's 6x max speed as advertised. If LibreDrive isn't what I'm looking for to achieve that, I'd appreciate any advice or links.
hope this is helpful for this 3 month old post. other people with this question have been told to run the windows utility from pioneer jp site to enable the full speed setting
Rusty Shackleford
#153 Post by Rusty Shackleford » Sat Dec 23, 2023 12:49 am
Hello, I am new to MakeMKV and accidentally bought one of the pioneer models with the new firmware that disables LibreDrive. Below is the drive information if that helps at all. Otherwise, I would appreciate any tips that can get LibreDrive enabled without buying a new disc drive.
OS device name: G:
Product: BD-RW BDR-XD08U
Revision: 1.02
Firmware date: 2022-12-27
Highest AACS version: 77
Drive platform: Pioneer RS9331
Please let me know if any other information is needed and thank you to anyone for their help.
#154 Post by MartyMcNuts » Sat Dec 23, 2023 6:22 am
OS device name: G:
Revision: 1.02
That drive cannot currently have libredrive enabled as the firmware is too new. Your choices are to keep it and wait possibly several months (or even years) or return it if possible and get another drive. If you are after a Pioneer, your best bet is to get one from a seller on this forum.
paulhenry26
#155 Post by paulhenry26 » Sun Dec 24, 2023 12:50 pm
Hi there,
I unwittingly updated the firmware in my Pioneer BDR-S12UHT to V1.05 and its now its paperweight in regards of using it with MakeMKV.
Does anyone know of a way to flash back to V1.01 or where I can get the firmware?
I feel like a right tool, as they say if it ain't broke, don't fix it :oops:
#156 Post by SamuriHL » Sun Dec 24, 2023 1:21 pm
No one reads anymore. Sigh
MrPenguin
#157 Post by MrPenguin » Sun Dec 24, 2023 1:39 pm
I unwittingly updated the firmware in my Pioneer BDR-S12UHT to V1.05 ...
I am curious. How does anyone update firmware "unwittingly"? :?
paulhenry26
#158 Post by paulhenry26 » Sat Dec 30, 2023 4:06 pm
it was unwittingly because I did not read this forum (or any forum) first and wrongly assumed that updating the firmware would be ok.
Seraphic-
#159 Post by Seraphic- » Sun Dec 31, 2023 1:01 pm
After reading about the firmware issues with Pioneer drivers post 2022, I decided to check out the BDR-S13U-X I purchased back in February 2023. Luckily, it looks like it escaped the newer 1.04 encrypted firmware and was produced with the older 1.03 that MKV flags as Libre Enabled. So just a DataPoint for those interested:
OS device name: A
Product: BD-RW BDR-S13JX
Revision: 1.03
Serial number: XXXXXXXXXXXX
Firmware date: 2022-07-26
Drive platform: RS9201
Firmware name: PIONEER BDR-213T
Firmware version: 1.03/ID72
Only thing that seems off is that it is not showing the Highest AACS version for the drive. Is that odd?
#160 Post by dcoke22 » Mon Jan 01, 2024 11:55 pm
As I understand it, that AACS version you see is only the highest AACS version that drive has encountered and does not indicate any limitation the drive has regarding AACS levels.
Seraphic-
#161 Post by Seraphic- » Tue Jan 02, 2024 10:19 pm
I haven't actually put a disc in it as of yet. So that make senses. Thanks.
jocel
#162 Post by jocel » Sat Feb 03, 2024 6:32 pm
Hi, I'm Jocelyn, I have had this drive for some time, I would like to know if it is possible to upgrade it to read 4k UHD, please.
I purchased it in March 2021, but until now I hadn't had any need to read UHD, my "old" PC didn't have the potential (I now have a 5950x that I got at a good price).
Thank you.
Unit information
OS Device Name: G:
Product: BD-RW BDR-S12
Revision: 1.00
Serial number: (***)
Firmware date: 2019-01-10
Bus encryption flag: 1B
LibreDrive information
Drive platform: RS8F00
Firmware Name: PIONEER BDR-212T
Firmware type: Original (unmodified)
Firmware version: 1.00/ID45
Read BD raw data: Yes
Read raw BD metadata: Yes
Unrestricted reading speed: Yes
#163 Post by Billycar11 » Sat Feb 03, 2024 11:58 pm
Thank you.
Unit information
OS Device Name: G:
Revision: 1.00
You sure it does not already read UHD if not email me for an automated flasher see below
jocel
#164 Post by jocel » Sun Feb 04, 2024 9:08 am
Thank you.
Unit information
OS Device Name: G:
Revision: 1.00
I bought this but it doesn't read it from the features it would look like a 4KUHD.
https://amzn.eu/d/25K4Xhc
I would like to transform them in ISO to be able to read them with my nvidia shield by my HDD, because I no have at any another BR reader…
In fact, it doesn't read the disc, it doesn't even detect it. I no have anothers UHD disk… (In the package there are four discs). I'm doing something wrong?
Thx.
#165 Post by Billycar11 » Sun Feb 04, 2024 9:26 am
Thx.
then just email me for the flasher see below its $25
