LibreDrive for Pioneer drives
asmcom
Post by asmcom » Mon Jan 08, 2024 9:25 pm
atp-flo wrote: Sun Jan 07, 2024 3:17 pm Is there a chance that the Pioneer BDR-XS07TUHD / BDR-XS07UHD or BDR-S13U will be flashable for casual users in the future? Guess I'll have to go for a BU40N drive now because of that crap.
We have these drives in stock on firmware 1-02
viewtopic.php?f=20&t=19387
Asmcom
ava1ar
Post by ava1ar » Sun Jan 14, 2024 8:47 pm
Hi all!
How to I flash this guy?
OS device name: /dev/sr0
Manufacturer: PIONEER
Product: BD-RW BDR-XS07U
Revision: 1.02
Serial number: XXXXXXXXXXX
Firmware date: 2022-10-24
Bus encryption flags: 13
Drive platform: RS8E21
Firmware version: 1.02/ID05
asmcom
Post by asmcom » Sun Jan 14, 2024 8:55 pm
ava1ar wrote: Sun Jan 14, 2024 8:47 pm Hi all!
Revision: 1.02
Serial number:
Do not flash this drive as it is on correct firmware. Leave as is
Asmcom
ava1ar
Post by ava1ar » Sun Jan 14, 2024 9:05 pm
Ok, got it - I was curious about LibveDrive firmware, but it looks like it is not needed? Will try it today as-is.
asmcom
Post by asmcom » Sun Jan 14, 2024 9:09 pm
ava1ar wrote: Sun Jan 14, 2024 9:05 pm
If you flash there is no going back, drive will not read UHD discs again. Do not flash.
Asmcom
mrcobra92
Post by mrcobra92 » Sun Jan 14, 2024 11:52 pm
asmcom wrote: Mon Jan 08, 2024 9:25 pm
Asmcom
Just sent you an email about buying one of these. Thanks!
asmcom
Post by asmcom » Mon Jan 15, 2024 12:00 am
mrcobra92 wrote: Sun Jan 14, 2024 11:52 pm
Asmcom
Thank you, we will look straight away.
Hayley
UHD Friendly Drives Team
weslovesnats
Post by weslovesnats » Tue Jan 16, 2024 4:13 am
Hi, Here is the nicely formatted data from AnyDVD (which now takes credit cards, I used them years ago). This is an internal SATA drive. I have had no problems with DVD and Blu-Ray (1080p) but UHD is what I'm trying to do - in this case I have the Bond boxed set with Craig's movies in UHD.
Summary for drive V: (AnyDVD HD 8.6.8.0, BDPHash.bin 20-03-11)
PIONEER BD-RWBDR-S13U 1.04
Drive (Hardware) Region: 1
Media is a Blu-ray disc.
Total size: 48876960 sectors (95462 MBytes)
Video Blu-ray label: NO_TIME_TO_DIE
Media is AACS protected!
AACS MKB version 76
UHD Blu-ray disc.
Drive supports bus encryption!
Disc wants bus encryption!
DRIVE NOT SUPPORTED BY MAKEMKV LIBREDRIVE!
couldn't retrieve AGID (bus encryption)!
ERROR processing Blu-ray disc!
What am about to add is an Asus which seems to match what you mentioned as compatible (I don't care for external drives when I have a full tower to mount an internal one), taken from the factory sticker on the top:
Short Model: BS-160HT
Longer model #: BW-1601HT/BLK/G/AS
I'd like to keep the old one and add the new one but I could do a replacement. Space is not the problem. While I plan to replace my Socket 2011 system, I'd like to wait until Intel 15th gen ships along with Win 12.This is loaded with multiple SSDs and a rather large amount of RAM so just getting a drive to work is the priority. It isn't clear if I can flash the existing drive or not (likely not). I'll know about the Asus when I install it and try a disk.
Is my understanding of what will work correct - or nearly so - above? I have about 20-30 UHD disks I want to rip. The other disks (even more in number) are largely TV series and will be a pain to get the files and [episodes by name or number] correct, and the existing drive will work for them but not UHD. So it's just UHD that is the risk at this moment.
Post by MartyMcNuts » Tue Jan 16, 2024 5:37 am
weslovesnats wrote: Tue Jan 16, 2024 4:13 am Hi, Here is the nicely formatted data from AnyDVD (which now takes credit cards, I used them years ago). This is an internal SATA drive. I have had no problems with DVD and Blu-Ray (1080p) but UHD is what I'm trying to do - in this case I have the Bond boxed set with Craig's movies in UHD.
AACS MKB version 76
UHD Blu-ray disc.
If you mean ASUS BW-16D1HT, then yes, once flashed it can rip UHD discs.
weslovesnats
Post by weslovesnats » Tue Jan 16, 2024 9:35 pm
Thanks. The way manufacturers use part numbers, basic and adding various letters or binders for subset or minor updates, causes a small amount of uneasy feeling about compatibility. I've seen the lists of models and some of that happens for what, in retail packaging, looks the same in the shelf. So this is useful since, while I was a hardware engineer decades ago, before switching to software, I've never flashed a drive. I has an "unsuccessful" update if BIOS back in the Pentium 4 days for why I might be concerned.
As for the worst of part numbers with minute changes being like different chips, you'd have to be old enough to remember the 386 and 486 days where mere "steppings" of shipped production clips could mean whether a specific machine instruction would work or not.
Again, thanks.
Saebasan
Post by Saebasan » Sun Jan 21, 2024 7:02 am
How can I flash this drive, in order to make it Libredrive enable?
OS device name: H:
Product: BD-RW BDR-UD03
Revision: 1.03
Serial number: MLDL038441WL
Firmware date: 2015-05-14
Drive platform: Pioneer RS8510
Firmware version: ID19
Thank you.
Libredrives: HLDS BH16NS58 (ext. enclosure), HLDS BH14NS58
Other: Pioneer BDR-UD03
Post by MartyMcNuts » Sun Jan 21, 2024 9:14 am
Saebasan wrote: Sun Jan 21, 2024 7:02 am Hello,
OS device name: H:
Revision: 1.03
Thank you.
There is no publicly available flasher for Pioneer drives.
Saebasan
Post by Saebasan » Sun Jan 21, 2024 12:37 pm
Then, how to make this UD03, Makemkv “enable”?
What about the sdf.bin file?
Should I ask to enlist this drive in it, or something like so?
Post by MartyMcNuts » Sun Jan 21, 2024 11:49 pm
Saebasan wrote: Sun Jan 21, 2024 12:37 pm :)
The only way to enable UHD ripping on that drive is to contact Billycar11 and purchase his flasher.
Saebasan
Post by Saebasan » Mon Jan 22, 2024 3:02 am
MartyMcNuts wrote: Sun Jan 21, 2024 11:49 pm
Thank you but really? It sounds a little bit odd... :roll:
As the first post of this thread, from mike, the admin, just says "none of the Pioneer drives require firmware update - they should just work"...
Regarding his explanations, it may just work without firmware upgrade.
