R.I.P.D. UHD no Key
Osman_28
Re: R.I.P.D. UHD no Key
#16 Post by Osman_28 » Thu Jan 04, 2024 9:12 pm
Oh ok good to know thanks I appreciate your reply, thought a week would be enough until a dump would be added :)
Osman_28
#17 Post by Osman_28 » Thu Jan 04, 2024 9:15 pm
But you don't think It could be a disc problem?
Because there was another user who had the exact same dump file and he submitted it on November 13th.
#18 Post by MartyMcNuts » Fri Jan 05, 2024 1:48 am
No, the disc isn't the problem. Since you are getting the volume key not available message and you appear to be getting the hashed key updates it's just a waiting game.
We also don't know if the other person was able to rip theirs...
It's only Mike generating them and we don't know if he's having a holiday or what...
Osman_28
#19 Post by Osman_28 » Fri Jan 05, 2024 5:38 pm
Thank you so much I really appreciate your reply! :D
I thought maybe I had some technical difficulties e.g. Drive or disk vise, because it’s my first time waiting so long for a key to be implemented, since the user I mentioned submitted it almost 2 Months ago.
Not sure If the developer got a huge load of dump files through Black Friday and Christmas time and also not sure how difficult it can be to generate a Volume Key.
I'm new to this stuff just started in Summer 2023 sorry if I’m bothering anyone.
Like you said it’s now just a waiting game
murx75
#20 Post by murx75 » Mon Apr 01, 2024 3:13 pm
Very strange, MakeMKV still does not rip the disk for me...
Has anybody been able to backup the disk?
I have sent the file MKB20_v77_R_I_P_D_057F.tgz last Wednesday, but apparently many have done so before. Or is this another (German) disk version?
MrPenguin
#21 Post by MrPenguin » Mon Apr 01, 2024 4:17 pm
There are two entries for a UHD disc like yours already in the public KEYDB.cfg file, which you can download from http://fvonline-db.bplaced.net and unpack into your .MakeMKV directory. Does either of these entries allow MakeMKV to decrypt your disc?
murx75
#22 Post by murx75 » Wed Apr 03, 2024 6:22 pm
Thank you so much!
The keydb.cfg file did it! I was able to back the disk up. I thought the time for downloading these key files were over.
I got a number of strange problems recently with one drive not being able to rip the disk, making MakeMKV create the tgz-file, while the other did rip the disk. Not sure if this has been introduced with a recent release and/or if this is due to me mixing different drives (Pioneer & LG based) or because I have multiple instances of MakeMKV running in parallel on the same PC.
MrPenguin
#23 Post by MrPenguin » Wed Apr 03, 2024 11:43 pm
To be fair, your disc would need to match one of these two entries in order for KEYDB.cfg to work for you:
0xFF3755D6278B23B0472FBF6D7E5FD74F9B3391B7 = RIPD_UPK1_GH (R.I.P.D.) | D | 2022-10-06
0x1B9D924C34C21DA6A3358D88DEF9F97CAB723CAC = RIPD_UPK1_GH (R.I.P.D.) | D | 2022-09-13
and even then (AFAIK) only because the VUK for each of these is known. It is also possible that your VUK was added to MakeMKV's hashed keys in the past 48 hours.
But all the same, I would still recommend not dismissing KEYDB.cfg, because it might be able to help you if ever MakeMKV's key processing seems to have stalled.
VarHD
#24 Post by VarHD » Fri Jun 14, 2024 3:28 pm
Submitted my dump today.
MrPenguin
#25 Post by MrPenguin » Sat Jun 15, 2024 6:49 pm
I recommend also copying the latest KEYDB.cfg file into your .MakeMKV/ directory, just to see if it helps.
VarHD
#26 Post by VarHD » Wed Jun 19, 2024 4:17 pm
Thanks, I forgot to post an update here. I did later check out the file and... it worked so problem solved for me. First time I had to download it manually, though, usually it seems to get the key on its own, but whatever - it worked so I'm happy :)
MrPenguin
#27 Post by MrPenguin » Wed Jun 19, 2024 5:50 pm
I don't understand the Deep Magic behind MakeMKV's processing queue: sometimes it generates keys within days, and other times it takes weeks :|. In this particular instance, your disk's VUK has just appeared in KEYDB.cfg first.
#28 Post by SamuriHL » Wed Jun 19, 2024 6:17 pm
There's no magic mystery. It's Mike. LOL Whenever he gets to it and posts a new hashed key update.
MrPenguin
#29 Post by MrPenguin » Wed Jun 19, 2024 9:41 pm
I must assume that Mike has automated / delegated the processing queue to at least some degree. And that this particular disk has somehow fallen through the cracks.
#30 Post by SamuriHL » Wed Jun 19, 2024 9:47 pm
The other possibility is that the submitted tgz file is not usable for whatever reason. And yes, that is possible.
