Ultimate UHD Drives Flashing Guide Updated New Pioneer Flashing 2026
Fanofurban
Ugghh....I was hoping updates might have possibly been made to change that, but thank you so much for the reply and confirmation
No problem. 2015 is the transition year - early in the year, unlikely, but there were SOME drives built in LATE 2015 that could do UHD.
Generally, though, 2016 is when things became more likely to do UHD.
jimmyg
Hello !
I have a problem to flash my drive.
I have a TechPulse120 with the following information
I have downloaded the firmware and started the following command :
The message I got is the following :
But when I restart makemkv, nothing changes in the drive information. And I can't rip 4K movies.
Any idea what I am doing wrong ?
Thank you very much !
Informations lecteur
Nom du lecteur SE : E:
Fabricant : HL-DT-ST
Produit : BD-RE BU40N
Révision : PA03
Numéro de série : *****
Date micrologiciel : 2118-12-24 16:02
Marqueurs d'encryptage bus : 1F
Version AACS la plus haute : 76
Aucun disque
makemkvcon64.exe f --all-yes -d E: rawflash enc -i D:\HL-DT-ST-BD-RE_BU40N-1.03-NM00000-211810241934.bin
D:\Program Files (x86)\MakeMKV>makemkvcon64.exe f --all-yes -d E: rawflash enc -i D:\HL-DT-ST-BD-RE_BU40N-1.03-NM00000-211810241934.bin
Reading input file D:\HL-DT-ST-BD-RE_BU40N-1.03-NM00000-211810241934.bin
Current Drive ID: HL-DT-ST_BD-RE_BU40N_PA03_211812241602_***
100% Operation finished
Done successfully
No enc that fw is oldjimmyg wrote: Thu Dec 28, 2023 5:14 pm Hello !
I have downloaded the firmware and started the following command :Code: Select all
Informations lecteur Nom du lecteur SE : E: Fabricant : HL-DT-ST Produit : BD-RE BU40N Révision : PA03 Numéro de série : ***** Date micrologiciel : 2118-12-24 16:02 Marqueurs d'encryptage bus : 1F Version AACS la plus haute : 76 LibreDrive Information Status: Possible, not yet enabled Drive platform: MT1959 Aucun disque
The message I got is the following :Code: Select all
But when I restart makemkv, nothing changes in the drive information. And I can't rip 4K movies.Code: Select all
D:\Program Files (x86)\MakeMKV>makemkvcon64.exe f --all-yes -d E: rawflash enc -i D:\HL-DT-ST-BD-RE_BU40N-1.03-NM00000-211810241934.bin Reading input file D:\HL-DT-ST-BD-RE_BU40N-1.03-NM00000-211810241934.bin Flashing flags = 0x0 : 0 0 0 0 : ---- ---- ---- ---- Sending image in encrypted format Current Drive ID: HL-DT-ST_BD-RE_BU40N_PA03_211812241602_*** Ready to write drive flash memory. (auto confirmed) Operation started: Sending flash image to drive 100% Operation finished Operation started: Programming flash 100% Operation finished Done successfully
jimmyg
Thank you. I tried without "enc" and got this error.
Command produced error code 0x82052400
D:\Program Files (x86)\MakeMKV>makemkvcon64.exe f --all-yes -d E: rawflash -i D:\HL-DT-ST-BD-RE_BU40N-1.03-NM00000-211810241934.bin
98% .................................................
Write DRAM NG 05/24/00
It seems like we cannot flash this drive and I will have to purchase a new one. Any good references that we can purchase in Europe (Belgium more precisely) ? Thank you.
CovertRain
Sorry if a dumb question. I am looking at the recommended drives list but then there is a comment about not buying any Pioneer drives for 4K (UHD). Is that still the case? Also, should I not bother trying to find a drive that does 3D? I was hoping to rip those as well. Sounds like trying to find something that works out of the box on Amazon is a lost cause.
i see yeah techpulse had a batch of bad cases that dont pass libredrive or flashingjimmyg wrote: Thu Dec 28, 2023 7:58 pm
It seems that this guy had the same FW : viewtopic.php?p=132851#p132851Code: Select all
D:\Program Files (x86)\MakeMKV>makemkvcon64.exe f --all-yes -d E: rawflash -i D:\HL-DT-ST-BD-RE_BU40N-1.03-NM00000-211810241934.bin Reading input file D:\HL-DT-ST-BD-RE_BU40N-1.03-NM00000-211810241934.bin Flashing flags = 0x0 : 0 0 0 0 : ---- ---- ---- ---- Current Drive ID: HL-DT-ST_BD-RE_BU40N_PA03_211812241602_*** Ready to write drive flash memory. (auto confirmed) Operation started: Sending flash image to drive 98% ................................................. Write DRAM NG 05/24/00 Command produced error code 0x82052400
Millmaster
I just purchased a new WH16NS40 (Manufactured: May 2023)
I flashed it a couple different times trying to resolve this issue and to no avail.
It throws all sorts of errors when I open a disk and never opens it.
I Did have success once when I switched computers and it had V17.4, but then it ran into errors too.
I updated to 17.5 and still errors.
The one that I did successfully on V17.4 ran completely normally - didn't throw errors, but there were a couple spots in the resulting .MKV file that were garbled for a few seconds.
Tried to attached a log and screen shot but the attachment status says "Sorry, the board attachment quota has been reached."
Recommendations?
I flashed using the Utility and then also using command line when I was getting errors.
I am surprised it still reads WH14NS40 since I flashed it with the WH16NS40 Firmware.
Any help appreciated.
The drive info shows:
OS device name: E:
Product: BD-RE WH14NS40
Revision: 1.02
Serial number: KLFN5GE3324
Firmware date: 2115-12-11 15:03
Highest AACS version: 57
Firmware version: 1.02
Recommendations?
OS device name: E:
Revision: 1.02
CardMe
Sorry if this has been asked a lot. Too many pages to go through. The first post says:
"drives that Currently work are:
BDR-XD08UMB-S Slim top load USB Rip speed 4x BD 66 ~1 Hour BD 100 ~1 hour 35mins
BDR-XD07UHD Slim top load USB Rip speed 4x BD 66 ~1 Hour BD 100 ~1 hour 35mins
BDR-XD06JUHD Slim top load USB Rip speed 4x BD 66 ~1 Hour BD 100 ~1 hour 35mins
BDR-S12UHT Internal 5.25 sata Rip speed 4x BD 66 ~1 Hour BD 100 ~1 hour 35mins
BDR-XS07UHD Slim Slot load USB Rip speed 4x BD 66 ~1 Hour BD 100 ~1 hour 35mins
BDR-212UBK Internal 5.25 sata Rip speed 4x BD 66 ~1 Hour BD 100 ~1 hour 35mins
BDR-211UBK Internal 5.25 sata Rip speed 4x BD 66 ~1 Hour BD 100 ~1 hour 35mins
BDR-UD04 Slim 9.5mm tray load slim sata Rip speed 4x BD 66 ~1 Hour BD 100 ~1 hour 35mins
BDR-S13U-X Internal 5.25 sata Rip speed 4x BD 66 ~1 Hour BD 100 ~1 hour 35mins
BDR-S13UBK Internal 5.25 sata Rip speed 4x BD 66 ~1 Hour BD 100 ~1 hour 35mins"
Does this mean these can be used as is without flashing?
Thank you.
Thank you.
You missed this VERY IMPORTANT part:Does this mean these can be used as is without flashing?
So, generally speaking, unless you can be sure the drive was built with prior firmware (before December 2022), these drives do not currently work for UHD.PSA now most Pioneers come with new fw that prevents them from be crossflashed or downgraded do not buy one for UHD at this time
asmcom
In Europe, drives can still be on old firmware in the 1st quarter of 2023. AsmcomWoodstock wrote: Mon Jan 01, 2024 3:49 pmYou missed this VERY IMPORTANT part:Does this mean these can be used as is without flashing?
ironsniper1
just wanted to say thanks for all of the great info in this thread! i bought a blu ray drive that said it could do 4k, but i didnt see that it was a customer return for parts or as is, after i got it it would see the disc but not read and after flashing it now works perfectly!
Yes, still the case for Pioneer drives. As for 3D, I don't have much experience here, but I'm pretty sure any LibreDrive compatible drive can rip 3D movies.CovertRain wrote: Thu Dec 28, 2023 9:09 pm Sorry if a dumb question. I am looking at the recommended drives list but then there is a comment about not buying any Pioneer drives for 4K (UHD). Is that still the case? Also, should I not bother trying to find a drive that does 3D? I was hoping to rip those as well. Sounds like trying to find something that works out of the box on Amazon is a lost cause.
The sellers on this forum are the best resource for Pioneer drives (they're split up by region and listed in the first post of this thread).
As a side note, the first post of this thread is maintained to a very high degree. If anything changes regarding the Pioneer drives, the first post will be updated.
ikomrad
Which instructions are you following(link?)? The only instructions for Windows I see are these from page 1 of this thread.strangedays wrote: Fri Dec 22, 2023 6:56 am so im pretty green at this .... just flashed my LG WP50NB40 (NB52) with "DE_LG_WP50NB40-NB50_1.03_MK" but now on to the cross flash as per instructions --- however id like my drive to be compatible with most ripping SW as per below - however seeing this is almost a year old is there any new .bin files for cross flashing that would make this little drive even better ? If not should i be flashing DE_LG_BU40N_1.00.bin or DE_LG_BU40N_1.03_MK.bin ?
would be cool to rip (backup) games with this, but if not possible ill stick with ripping (backing up) my BR movies... please advise
LG WP50NB40, SVC: NB52, ROM VER: 1.03, Manufactured in October 2022
...and in step #3 above Marty writes that it can be flashed with either firmware:
BP60NB10 1.00-MK
BU40N 1.00
Is there any appreciable difference, features, or advantage/disadvantage between those two firmwares on this drive?
The BP60NB10 firmware only works with MAkeMKV & AnyDVD. The BU40N 1.00 firmware works with all ripping software.
If I wanted to flash this drive back to it's original firmware to return it, would I just do that with the original firmware dump I made with SDFTool before flashing it to be UHD capable?
I did see your post with the official LG flasher for this drive, but since mine is SVC NB52 and that flasher is for SVC NB50, I thought I'd ask.
No. That dump is not really helpful as it only contains important bits of the firmware, not the complete firmware. There isn't a NB52 flasher available either.
Why return it? They are good little drives once flashed! I use one myself. I suggest using the BU40N 1.00 firmware though, as it's compatible with a wider range of ripping software.
The closest firmware match I see in the "The all you firmware..." download is "HL-DT-ST-BD-RE_BP50NB40-NB50-1.03-NM00800-212005070917.bin" , which is different than the "DE_LG_WP50NB40-NB50_1.03_MK" you mentioned. I don't see that one in the pack.How To Flash Videos and commands:
New Updated guide for all Drives and firmware including encrypted firmware: https://www.youtube.com/watch?v=jyQV1aPlbow
1. Open cmd as admin
2. Navigate to makemkvs install directory by default on 64 bit systems it is here: cd "C:\Program Files (x86)\MakeMKV"
3. If you have a listed encrypted firmware you must use this command: makemkvcon64.exe f --all-yes -d “ your drive letter here Example: D”: rawflash enc -i “path to your firmware Example: C:\Users\Billy\Downloads\Downgrade-Enabled-Firmware\Auto-Flash\LG-Desktop-NS60-sleep-fix\WH16NS60-1.02-MK.bin”
4. If you have unencrypted firmware use this command: makemkvcon64.exe f --all-yes -d “ your drive letter here Example: D”: rawflash -i “path to your firmware Example: C:\Users\Billy\Downloads\Downgrade-Enabled-Firmware\Auto-Flash\LG-Desktop-NS60-sleep-fix\WH16NS60-1.02-MK.bin”
5. Remove my examples and quotes ”” when you run the commands
For the most software compatibility use the BU40N 1.00 firmware.ikomrad wrote: Tue Jan 02, 2024 2:12 amWhich instructions are you following(link?)? The only instructions for Windows I see are these from page 1 of this thread.strangedays wrote: Fri Dec 22, 2023 6:56 am so im pretty green at this .... just flashed my LG WP50NB40 (NB52) with "DE_LG_WP50NB40-NB50_1.03_MK" but now on to the cross flash as per instructions --- however id like my drive to be compatible with most ripping SW as per below - however seeing this is almost a year old is there any new .bin files for cross flashing that would make this little drive even better ? If not should i be flashing DE_LG_BU40N_1.00.bin or DE_LG_BU40N_1.03_MK.bin ?
BP60NB10 1.00-MK
BU40N 1.00
