"Another way"? You mean, like (say) sacrificing a ripe mango (or possibly a kumquat) to Cthulhu?
The only way I know of would be buying a licence .
OS device name: /dev/sr1
Manufacturer: PIONEER
Product: BD-RW BDR-UD04
Revision: 1.14
Serial number: <BONK!>
Firmware date: 2020-06-15
Highest AACS version: 81
Drive platform: RS8A10
Firmware version: 1.14
Revision: 1.14
Serial number: <redacted>
Highest AACS version: 61
Hi everyone, new forum member with a question:MartyMcNuts wrote: ↑Sun Dec 24, 2023 4:27 amThe only drive you can currently get that should still work out of the box is the Verbatim 43888
YesPaulRB wrote: ↑Wed Dec 27, 2023 10:37 amHi everyone, new forum member with a question:MartyMcNuts wrote: ↑Sun Dec 24, 2023 4:27 amThe only drive you can currently get that should still work out of the box is the Verbatim 43888
Is this advice still true? Has this drive not been shipped with any firmware version which would need to be flashed for ripping BR and 4k UHD disks?
I have spotted it here for ~£90:
https://www.scan.co.uk/products/verbati ... sb-c-black
Scan is a well respected seller for many years in UK.
Thanks Marty!
43890 and 43889 have a Pioneer BDR-UD03-drive. 43888 a Pioneer BDR-UD04.PaulRB wrote: ↑Thu Dec 28, 2023 1:35 pmThanks Marty!
Is 43889 equivalent & compatible for use with makeMKV, do you know?
https://www.scan.co.uk/products/verbati ... 5gbits-sec
I'm having trouble understanding the difference(s) between 43888 and 43889 !
