In that case are there any other recommended slot drives? What Im planning would really benefit from a slot drive but I cant find any others on the market except for some bare slim SATA drives and im not sure if those would even work
Chaos_Sandwich
Re: Pioneer firmware update February 2023
lacabl
hope this is helpful for this 3 month old post. other people with this question have been told to run the windows utility from pioneer jp site to enable the full speed settingalminderson wrote: Wed Sep 13, 2023 5:26 pm I'd like to transition my LibreDrive status from Possible, not yet enabled to Enabled.
Running MakeMKV v1.17.4 on macOS Ventury 13.5.2:
My goal here, really, is just to remove the 2x speed limit for archiving my discs, and achieve the drive's 6x max speed as advertised. If LibreDrive isn't what I'm looking for to achieve that, I'd appreciate any advice or links.Code: Select all
Drive Information Current profile: BD-ROM Manufacturer: PIONEER Product: BD-RW BDR-XS07U Revision: 1.03 Firmware date: 2023-01-06 Bus encryption flags: 13 Highest AACS version: 655 LibreDrive Information Status: Possible, not yet enabled Drive platform: Pioneer RS8E21 Firmware version: ID05
Rusty Shackleford
Hello, I am new to MakeMKV and accidentally bought one of the pioneer models with the new firmware that disables LibreDrive. Below is the drive information if that helps at all. Otherwise, I would appreciate any tips that can get LibreDrive enabled without buying a new disc drive.
OS device name: G:
Product: BD-RW BDR-XD08U
Revision: 1.02
Firmware date: 2022-12-27
Highest AACS version: 77
Drive platform: Pioneer RS9331
Please let me know if any other information is needed and thank you to anyone for their help.
OS device name: G:
Revision: 1.02
That drive cannot currently have libredrive enabled as the firmware is too new. Your choices are to keep it and wait possibly several months (or even years) or return it if possible and get another drive. If you are after a Pioneer, your best bet is to get one from a seller on this forum.Rusty Shackleford wrote: Sat Dec 23, 2023 12:49 am Hello, I am new to MakeMKV and accidentally bought one of the pioneer models with the new firmware that disables LibreDrive. Below is the drive information if that helps at all. Otherwise, I would appreciate any tips that can get LibreDrive enabled without buying a new disc drive.
OS device name: G:
Revision: 1.02
paulhenry26
Hi there,
I unwittingly updated the firmware in my Pioneer BDR-S12UHT to V1.05 and its now its paperweight in regards of using it with MakeMKV.
Does anyone know of a way to flash back to V1.01 or where I can get the firmware?
I feel like a right tool, as they say if it ain't broke, don't fix it
No one reads anymore. Sigh
MrPenguin
I am curious. How does anyone update firmware "unwittingly"?paulhenry26 wrote: Sun Dec 24, 2023 12:50 pm I unwittingly updated the firmware in my Pioneer BDR-S12UHT to V1.05 ...
paulhenry26
it was unwittingly because I did not read this forum (or any forum) first and wrongly assumed that updating the firmware would be ok.
Seraphic-
After reading about the firmware issues with Pioneer drivers post 2022, I decided to check out the BDR-S13U-X I purchased back in February 2023. Luckily, it looks like it escaped the newer 1.04 encrypted firmware and was produced with the older 1.03 that MKV flags as Libre Enabled. So just a DataPoint for those interested:
Only thing that seems off is that it is not showing the Highest AACS version for the drive. Is that odd?
OS device name: A
Product: BD-RW BDR-S13JX
Revision: 1.03
Serial number: XXXXXXXXXXXX
Firmware date: 2022-07-26
Bus encryption flags: 1BCode: Select all
Drive platform: RS9201
Firmware name: PIONEER BDR-213T
Firmware version: 1.03/ID72
Unrestricted read speed: Yes-
As I understand it, that AACS version you see is only the highest AACS version that drive has encountered and does not indicate any limitation the drive has regarding AACS levels.Seraphic- wrote: Sun Dec 31, 2023 1:01 pm Only thing that seems off is that it is not showing the Highest AACS version for the drive. Is that odd?
Seraphic-
I haven't actually put a disc in it as of yet. So that make senses. Thanks.dcoke22 wrote: Mon Jan 01, 2024 11:55 pmAs I understand it, that AACS version you see is only the highest AACS version that drive has encountered and does not indicate any limitation the drive has regarding AACS levels.Seraphic- wrote: Sun Dec 31, 2023 1:01 pm Only thing that seems off is that it is not showing the Highest AACS version for the drive. Is that odd?
jocel
Hi, I'm Jocelyn, I have had this drive for some time, I would like to know if it is possible to upgrade it to read 4k UHD, please.
I purchased it in March 2021, but until now I hadn't had any need to read UHD, my "old" PC didn't have the potential (I now have a 5950x that I got at a good price).
Thank you.
Thank you.
Unit information
OS Device Name: G:
Product: BD-RW BDR-S12
Revision: 1.00
Serial number: (***)
Firmware date: 2019-01-10
Bus encryption flag: 1B
LibreDrive information
Drive platform: RS8F00
Firmware Name: PIONEER BDR-212T
Firmware type: Original (unmodified)
Firmware version: 1.00/ID45
Read BD raw data: Yes
Read raw BD metadata: Yes
Unrestricted reading speed: Yes
You sure it does not already read UHD if not email me for an automated flasher see belowjocel wrote: Sat Feb 03, 2024 6:32 pm Hi, I'm Jocelyn, I have had this drive for some time, I would like to know if it is possible to upgrade it to read 4k UHD, please.
Thank you.Unit information
OS Device Name: G:
Revision: 1.00
jocel
I bought this but it doesn't read it from the features it would look like a 4KUHD.Billycar11 wrote: Sat Feb 03, 2024 11:58 pmYou sure it does not already read UHD if not email me for an automated flasher see belowjocel wrote: Sat Feb 03, 2024 6:32 pm Hi, I'm Jocelyn, I have had this drive for some time, I would like to know if it is possible to upgrade it to read 4k UHD, please.
OS Device Name: G:
Revision: 1.00
https://amzn.eu/d/25K4Xhc
I would like to transform them in ISO to be able to read them with my nvidia shield by my HDD, because I no have at any another BR reader…
In fact, it doesn't read the disc, it doesn't even detect it. I no have anothers UHD disk… (In the package there are four discs). I'm doing something wrong?
Thx.
then just email me for the flasher see below its $25jocel wrote: Sun Feb 04, 2024 9:08 am
Thx.
