New Linux user needs help installing please
Logansfury
Post by Logansfury »
Hello everyone,
I am very eager to try MakeMKV, but I am a bit confused by the installation instructions on the page from this forum. I see:
Unpack both packages and starting from source package do the following steps:
For makemkv-oss package:
./configure
make
sudo make install
I am now afraid to proceed because I don't know if this is a single command (the select all seems to suggest it) or if I enter this as three separate commands (which seems more sensical to me)
next step is just as cryptic:
For makemkv-bin package:
make
sudo make install
The application will be installed as "/usr/bin/makemkv".
Again, I dont know if this is one command in terminal or two.
Also I am brand new to linux I have never unpacked a tar.gz before.
Do I just download, and navigate to the directory it downloaded to in terminal and start performing the above commands or do I have to use a Linux version of window's 7zip to open it first?
I am on Linux Mint 21.2 Victoria | Cinnamon.
Can anyone please help?
Thank you for reading,
Logan
MrPenguin
Re: New Linux user needs help installing please
Post by MrPenguin »
Logansfury wrote: Tue Nov 28, 2023 10:28 pm ./configure
make
sudo make install
These are three separate commands. Invoking "sudo" ensures that "make install" is executed as "root", because only "root" should be able to write to the /usr/bin etc directories.
Logansfury wrote: Tue Nov 28, 2023 10:28 pm Also I am brand new to linux I have never unpacked a tar.gz before.
Try
$ tar zxvf filename.tar.gz
PimpDiggler
Post by PimpDiggler »
Logansfury
Thank you for the reply :)
I have successfully installed MakeMKV and used it to rip a DVD. I have also encountered my first problem with a DVD with copywrite protection that cannot be read by the program and will not allow me to back it up.
