M3GAN 4k Volume Key Unknown
markjames81
#1 Post by markjames81 » Sat Nov 04, 2023 2:55 pm
Hello
Im getting an error when trying to rip M3GAN on 4K withit saying that the volume key is needed. This titlke has been out for some time so I would expect this to not be a problem.
MakeMKV v1.16.5 win(x64-release) started
The new version 1.17.5 is available for download at http://www.makemkv.com/download/
Using LibreDrive mode (v06.3 id=7FA2657C7667)
Backing up disc into folder "D:/Video/backup/M3GAN"
Saved AACS dump file as C:\Users\markj/.MakeMKV/MKB20_v77_M3GAN_AF42.tgz
Backup failed
Backup failed
Is there anything I can do to remedy
Mark
Re: M3GAN 4k Volume Key Unknown
#2 Post by Woodstock » Sat Nov 04, 2023 7:25 pm
Version 1.16.5 is over two years old; what do you get when you try the more modern version?
markjames81
#3 Post by markjames81 » Sun Nov 05, 2023 9:58 am
If updated the latest version and still the same. Ive also checked within preferences to ensure that the internet access tab was checked and it is
#4 Post by Woodstock » Sun Nov 05, 2023 2:19 pm
This time, did the system say whether or not it was able to download the most recent key archive? In 1.17.x, that's usually reported whenever it tries to access the archive, unless it's disabled in the configuration. A lot of people leave that turned off for security reasons, because it's hosted in Russia.
markjames81
#5 Post by markjames81 » Mon Nov 06, 2023 6:37 am
Sorry…where do I turn that on?
It just says it exactly the same as last time. I’m wondering if it exists yet as this is the uk release of the 4K which has just come out, but the availability isn’t usually this slow.
#6 Post by Woodstock » Mon Nov 06, 2023 1:21 pm
First Preferences page, "General", "Enable Internet access". If it's checked, it will attempt to access the key server when it needs to, often at the same time it checks for a new version.
Some systems block that access, but it will log the attempt, at least. There are ways to allow access, if necessary.
markjames81
#7 Post by markjames81 » Mon Nov 06, 2023 6:26 pm
Hi again
Yes this is something that I checked and it has been ticked so was always enabled. Im guessing it is that the volume has just not been generated yet!
Chris01992
#8 Post by Chris01992 » Thu Nov 16, 2023 11:35 am
Anyone managed to rip this one yet?
Sent in the AACS dump file last week: MKB20_v77_M3GAN_AF42.tgz
Maybe Mike's away?
RichL101
#9 Post by RichL101 » Fri Dec 01, 2023 11:52 am
I’ve also just submitted the UK version dump MKB20_v77_M3GAN_AF42.tgz as I am still getting "The volume key is unknown for this disc - video can't be decrypted" message
RichL101
#10 Post by RichL101 » Fri Dec 08, 2023 2:44 pm
If it helps I used AnyDVD in the end to get this 4k version ripped.
geogan
#11 Post by geogan » Tue Sep 24, 2024 1:17 pm
Also trying the UK version (MKB20_v77_M3GAN_AF42.tgz) and still getting "The volume key is unknown for this disc - video can't be decrypted" now in middle of 2024!
MrPenguin
#12 Post by MrPenguin » Tue Sep 24, 2024 2:04 pm
geogan wrote: Tue Sep 24, 2024 1:17 pm Also trying the UK version (MKB20_v77_M3GAN_AF42.tgz) and still getting "The volume key is unknown for this disc - video can't be decrypted" now in middle of 2024!
The latest KEYDB.cfg file contains several entries for this title. Does copying this file into MakeMKV's data directory (i.e. where MakeMKV also writes its TGZ dump files) and restarting MakeMKV help?
geogan
#13 Post by geogan » Tue Sep 24, 2024 4:45 pm
I copied that CFG file into the C:\Users\xxx\.MakeMKV folder and retried the disc and this time it worked!
I'm not sure how MakeMKV is picking up a file in that folder that was never there before? Why does it read that file at all?
Also I did send the TGZ file to the makemkv email address a few hours ago so its also possible it was added to the main download list already?
MrPenguin
#14 Post by MrPenguin » Thu Sep 26, 2024 1:56 pm
geogan wrote: Tue Sep 24, 2024 4:45 pm I copied that CFG file into the C:\Users\xxx\.MakeMKV folder and retried the disc and this time it worked!
The AF42 variant of M3GAN must exist in the KEYDB.cfg file, although apparently is still missing from MakeMKV's hashed keys.
