LibreDrive for Pioneer drives
CpktMpkt wrote:
Sun Oct 22, 2023 8:37 am
Hey,
I've just brought the following device:
OS device name: /dev/sr0
Manufacturer: PIONEER
Product: BD-RW BDR-XD07
Revision: 1.03
Serial number: BBDL015307WL
Firmware date: 2020-08-20
Bus encryption flags: 13
Highest AACS version: 78
as fare as I read it shoult be flashable the use it the UHD BluRays. But I can't find the software or firmware anywere.
here viewtopic.php?f=16&t=19634 are ony firmware for LG and ASUS devices.
Where can I gte UHD friendly firmware?
regards
Christian
sadly the pioneer firmware is not public and cant be flashed on linux
i do have a flasher for it if your on windows
mikeman
Post by mikeman »
Hi there,
Is it possible to enable this drive?
OS device name: /dev/rdisk4
Product: BD-RW BDR-XS08U
Revision: 1.01
Serial number: CEDLxxxxxxJP
Firmware date: 2022-12-27
Highest AACS version: 21
Drive platform: Pioneer RS9621
Firmware version: ID69
Cheers,
Mike
mikeman wrote:
Sun Oct 22, 2023 2:23 pm
Hi there,
Revision: 1.01
Cheers,
Mike
No
mikeman
Post by mikeman »
And any chance that a workaround will be found for the December 2022 firmware in future?
I'm very patient :)
mikeman wrote:
Sun Oct 22, 2023 7:50 pm
I'm very patient :)
Most likely yes we are unsure if it will require firmware flashing or just a libredrive update
mikeman
Post by mikeman »
Cool - thanks! Will continue to monitor news here then :mrgreen:
MrPenguin
Post by MrPenguin »
Billycar11 wrote:
Sun Oct 22, 2023 6:55 pm
Revision: 1.01
Just for interest, does anyone know how that Pioneer drive differs functionally from this one please?
OS device name: /dev/sr1
Product: BD-RW BDR-XD08U
Revision: 1.02
Serial number: <etc>
Highest AACS version: 76
Drive platform: Pioneer RS9331
Firmware version: ID05
I don't know what the "Drive platform" "RS9621" vs "RS9331" signifies, nor "ID69" vs "ID05", especially since my drive has a later "revision" than that one.
Thanks for any input here.
mikeman
Post by mikeman »
MrPenguin wrote:
Sun Oct 22, 2023 9:11 pm
Revision: 1.01
Revision: 1.02
The XS08U drive is a slot-loader (and a very nice one too), that’s all I can tell you - hope it helps.
MrPenguin
Post by MrPenguin »
Yes, and I believe the "U" signifies "UHD-capable". My "XD08U" has a "liftable lid", which is presumably what the "D" means too. But "slot-loader vs liftable-ld" is just the drive's "form-factor". I would (naively) have expected our two drives to be more similar at the firmware level :?.
BluesRay
Post by BluesRay »
Hello
I found this drive.
OS device name: F:
Product: BD-RW BDR-S12
Revision : 1.04
Serial number: ALDxxxxxxxWL
Firmware date: 2022-12-20
Firmware version: ID45
No disc
Is it possible to make UHD friendly with this Pioneer ?
Where can I get UHD friendly firmware?
I read 1.04 might be a problem with this drive.
Many thanks for your help
Best Regards
Peter
No. Until there is a Libredrive 2.0. No ETA.
BluesRay
Post by BluesRay »
Coopervid wrote:
Tue Oct 24, 2023 8:37 pm
Thank You Coopervid for your answer.
I have to be patient :)
I'm not good at this !
No one is...
simon0374
Post by simon0374 »
Hi there guys, new to this so bear with me lol, I'm looking to do 4K rip's on my pioneer (bought it before i realised they put fw on there to stop that) if i can flash it that be great, any help would be appreciated
simon0374
Post by simon0374 »
right, 2nd attempt at this, just got a pioneer and it doesn't work with 4k, I think it can with the right flash tho, here's the info sheet
Revision: 1.03
Serial number: BBDL015868WL
Highest AACS version: 46
Drive platform: RS8D30
Firmware version: 1.03
please let me know if it's possible, based on the info on this thread i think it is, any help is very much appreciated
