LibreDrive for Pioneer drives
No. It has to be flashed to be UHD compatible. Contact Billy.
Not for UHD discsloopydoodle wrote: ↑Thu Oct 05, 2023 6:52 pmThank you. So without flashing your firmware, the drive will not be supported "out of the box"?Billycar11 wrote: ↑Wed Oct 04, 2023 10:12 pmIf the fw is from before 12/22 email me your makemkv drive info section and I will make a flasher for you see below for contact info.loopydoodle wrote: ↑Wed Oct 04, 2023 8:23 pmIs the Pioneer BDR-XD07TS supported? I see a BDR-XD07 in the list, is it the same model?
loopydoodle
Ah okay, much clearer. Don't have any of those. Thanks.
Adorama doesn't have any more 1.02 - Just got mine and it's 1.03...
Guess I'll just hang on to this and hope for an update soon. (I still have a B0UN LibreDrive)
hi All,
I just purchased the pioneer BDR-XD07UHD. From what i read this drive cannot be flashed? This drive was on the list of supported external drives. Any feedback would be much appreciated.
Thank you!
OS device name: I:
Manufacturer: PIONEER
Product: BD-RW BDR-XD07U
Revision: 1.05
Serial number: ALDL011409UC
Firmware date: 2023-01-06
Bus encryption flags: 13
Highest AACS version: 77
Drive platform: Pioneer RS8D31
Firmware version: ID05
Thank you!
OS device name: I:
Revision: 1.05
No, cannot currently be flashed as it has the dredded firmware that is newer than Dec 2022.gh0stm4n wrote: ↑Sun Oct 15, 2023 9:52 pmhi All,
Thank you!
OS device name: I:
Revision: 1.05
I don't believe there are any external Pioneer drives available anywhere anymore that are UHD & libredrive compatible. It's now a waiting game.
We have plenty of drives on the correct firmware.MartyMcNuts wrote: ↑Sun Oct 15, 2023 11:08 pmNo, cannot currently be flashed as it has the dredded firmware that is newer than Dec 2022.gh0stm4n wrote: ↑Sun Oct 15, 2023 9:52 pmhi All,
Thank you!
OS device name: I:
Revision: 1.05
Asmcom
Hi, is it correct that this drive can get LibreDrive support via an sdf.bin update?
Also would there be any reason to update to a newer firmware (pre-December 2022, of course)?
Product: BD-ROM BDCUD03AS
Revision: 1.00
Serial number: NHDL000680WL
Firmware date: 2014-04-01
Highest AACS version: 23
Drive platform: Pioneer RS8590
Firmware version: ID23
It says BDR-UD03ASC on the label.
Let me know if you need any further details about this drive.
Revision: 1.00
It may be possible to flash to ud04 and do uhdneon-dev wrote: ↑Mon Oct 16, 2023 3:37 pmHi, is it correct that this drive can get LibreDrive support via an sdf.bin update?
Revision: 1.00
It's says BDR-UD03ASC on the label.
Email me for a $25 flasher if you want to try.
Thank you for your quick response, Billy.
I've looked into your flashing guide and it says Pioneer drives can't be flashed. Is that info outdated?
It doesn't look like older Pioneer firmwares are publicly avaiable.
This drive can be flashed and Billy can do it for you. I verify this drive can be flashed.
Asmcom
Sounds really cool, thanks for the clarification.
Unfortunately I don't own a single UHD disc, so I'm not interested in buying Billy's flasher (sorry).
What about my question whether this drive can get LibreDrive support on standard firmware?
mike admin wrote:If youre drive is listed above but is not supported, it means that it is not yet added to SDF.bin . Please post the drive model here.
You just have to submit your drive info to Mike and he can support it then.neon-dev wrote: ↑Mon Oct 16, 2023 11:26 pmSounds really cool, thanks for the clarification.
What about my question whether this drive can get LibreDrive support on standard firmware?mike admin wrote:If youre drive is listed above but is not supported, it means that it is not yet added to SDF.bin . Please post the drive model here.
But there is very little benefit to it without the UHD part
Just came here to say this. The comments all said it was 1.02. I just got mine and it is showing 1.03.
Product: BD-RW BDR-XS07U
Revision: 1.03
Serial number:
Highest AACS version: 61
I'm planning to return and buy a pre-flashed drive now. I was hoping to get a quality Pioneer drive.
Hey,
I've just brought the following device:
OS device name: /dev/sr0
Revision: 1.03
Serial number: BBDL015307WL
Firmware date: 2020-08-20
Highest AACS version: 78
as fare as I read it shoult be flashable the use it the UHD BluRays. But I can't find the software or firmware anywere.
here viewtopic.php?f=16&t=19634 are ony firmware for LG and ASUS devices.
Where can I gte UHD friendly firmware?
regards
Christian
Revision: 1.03
regards
Christian
