#1966 Post by Coopervid » Sun Oct 15, 2023 7:29 pm
alericcio66 wrote: Sun Oct 15, 2023 4:05 pm Hello everyone, I am new to the forum, but have been using MakeMKV for many years with my Pioneer BDR-UD03 1.05.
I would like to upgrade now to an external UHD player/master always slim to connect to my 2018 Mac Mini with Monterey 12.6.4 to read, rip and burn BD UHD.
What do you recommend me to buy to be problem free and start immediately?
Thank you.
Kind regards.
Send me a PM. Most guys just disappear. Therefore I want you to take the lead in this conversation.
asmcom
#1967 Post by asmcom » Sun Oct 15, 2023 9:37 pm
Thank you.
Kind regards.
Please see our seller page below we have a large choice of drives for you to choose from. Some special deals available to.
viewtopic.php?t=19387
Hayley :mrgreen:
alericcio66
#1968 Post by alericcio66 » Mon Oct 16, 2023 4:15 pm
Thank you, I have seen it, a very large amount of drives! I'll buy it one in the next few days. Thank you again.
ndgame
#1969 Post by ndgame » Mon Oct 16, 2023 4:51 pm
I upgraded my PC to a Mac and I am looking at the Pioneer BDR-XS07TUHD. I did all my own flashing on my Asus internal on my desktop and been using it for years.
The very first post on this thread is a little confusing on the Pioneer drives. If I pick up a Pioneer BDR-XS07TUHD will it work out of the box or do I need to find one with a manufacturing date older than 2023?
Thanks for your help with this.
#1970 Post by MartyMcNuts » Tue Oct 17, 2023 9:22 pm
ndgame wrote: Mon Oct 16, 2023 4:51 pm I upgraded my PC to a Mac and I am looking at the Pioneer BDR-XS07TUHD. I did all my own flashing on my Asus internal on my desktop and been using it for years.
Date must be older than December 2022. Good luck trying to find one!!
#1971 Post by Coopervid » Tue Oct 17, 2023 9:26 pm
Let me know what your country of residence is.
asmcom
#1972 Post by asmcom » Tue Oct 17, 2023 11:57 pm
MartyMcNuts wrote: Tue Oct 17, 2023 9:22 pm
We have plenty of these drives with firmware 1-02.
Hayley
UHD Friendly Drive Team
ndgame
#1973 Post by ndgame » Thu Oct 19, 2023 7:11 pm
So I got a Pioneer BD-RW- BDR-Xd07U
and it has revision 1.01 and the firmware date is fro 12-03-2018.
Should I upgrade it to 1.05 or leave it be?
#1974 Post by d00zah » Fri Oct 20, 2023 12:08 am
ndgame wrote: Thu Oct 19, 2023 7:11 pm So I got a Pioneer BD-RW- BDR-Xd07U
IF IT WORKS, LEAVE IT ALONE!!!
#1975 Post by Billycar11 » Fri Oct 20, 2023 12:09 am
Leave it unless you want to ruin it
ndgame
#1976 Post by ndgame » Fri Oct 20, 2023 12:38 am
So does anyone know how to make this his work with DVDFab? I use that to make ISO’s.
#1977 Post by Billycar11 » Fri Oct 20, 2023 1:46 pm
ndgame wrote: Fri Oct 20, 2023 12:38 am So does anyone know how to make this his work with DVDFab? I use that to make ISO’s.
Depends on the drive
But usually one of the de firmware from my pack
kululu
#1978 Post by kululu » Sun Oct 22, 2023 6:29 am
Hello
Anyone can use Pioneer BDR-X13J-S in MKVmaker?Change Rom after can’t use it to rip 4K UHD, Thanks
OS device name: E:
Manufacturer: PIONEER
Product: BD-RW BDR -X13U
Revision: 1.03
Firmware date: 2022-12-12
Bus encryption flags: 18
Highest AACS version: 78
Status: Possible, not yet enabled Drive platform: Pioneer RS9401
Firmware version: ID43
#1979 Post by dcoke22 » Mon Oct 23, 2023 5:39 pm
kululu wrote: Sun Oct 22, 2023 6:29 am Hello
OS device name: E:
Revision: 1.03
There's a whole thread about recent Pioneer firmware specifically disabling MakeMKV support. At the moment, once a Pioneer drive gets on the recent firmware, you're stuck.
viewtopic.php?f=19&t=30383
trleith
Get Platform Information
#1980 Post by trleith » Tue Oct 24, 2023 7:42 pm
STOP READ BEFORE FLASHING
IMPORTANT Before you flash:
  • 1. Make sure your Drive was built after 2016 on label or late 2015 if you want to risk it.
    2. Drive Platform MT1959<Most important in makemkv
    3. SVC NS50+ LG only on label for NB drives NB50+
    4. Just because your drive is the same model number does not mean it will work, if you are unsure ask me i offer remote flashing and check everything before i flash.
    5. Dont flash your dive if it does not meet these requirements if you do you will be unable to read all disks and unable to restore without dosflash that does not work on most modern computers
Alrighty then. (tiny bit of reformatting for readability) On Linux (inside Docker)
Note I'm using sdfTool because that's what was already in the Docker image with MakeMKV
It would be possible to put sdf.bin in there. Is it necessary?
root@176acc477e6a:/usr/local/bin# ./sdftool --version
LibDriveIo/SdfTool version: 2.6
root@176acc477e6a:/usr/local/bin# ./sdftool  --drive=dev_21:2 --info
SDF.bin version: 0x0097
Drive Tool SDF present
Drive Specific SDF present
[Drive Specific SDF] Embedded Info Strings:
8000:LibreDrive Information
8013:Status
8109:Possible (with patched firmware)
[b][i]8001:Drive platform :MT1959[/i][/b]
8010:Harware support
8100:Yes
8011:Firmware support
8101:No
8002:Firmware type
8108:Original (patched version available)
8003:Firmware version:1.05
8005:DVD all regions
8006:BD raw data read
8007:BD raw metadata read
8009:Unrestricted read speed
[Drive Specific SDF] Embedded Status Message:
8096:LibreDrive mode for this drive is only possible with firmware upgrade (id=%1):36338EC9581D
Identification SDF present
8013:Status
[Identification SDF] Drive autodetect string:mtk:[b][i]19:59[/i][/b]:JB8 :HL-DT-ST:BD-RE  WH16NS40 1.05:N000900:-
WH16NS40 on any Firmware directly to > WH16NS60 1.02MK
So, apparently I can do a flash to enable LibreDrive, and even though the WH16NS40 is a BDXL drive, doing this will fix the Sleep Bug because WH16NS60 is a UHD "official" drive.
First, save the existing firmware
./sdftool f --device=dev_21:2 dump --out=./HL-DT-ST-BD-RE _WH16NS40-1.05-N000900.bin
Then flash the drive
./sdftool f --device=dev_21:2 [b]enc[/b] --in=./HL-DT-ST-BD-RE_WH16NS60-1.03-NM00600-212005081010.bin <<== from the mk-firmware-pack-20200720
The command "enc" I am guessing at from examples. Neither is mentioned in sdftool --help
Have I got all this correct?
Thanks,
t
