LibreDrive for Pioneer drives
#721 Post by Coopervid » Thu Oct 05, 2023 8:28 pm
No. It has to be flashed to be UHD compatible. Contact Billy.
#722 Post by Billycar11 » Thu Oct 05, 2023 9:46 pm
loopydoodle wrote:
Thu Oct 05, 2023 6:52 pm
Billycar11 wrote:
Wed Oct 04, 2023 10:12 pm
loopydoodle wrote:
Wed Oct 04, 2023 8:23 pm
Is the Pioneer BDR-XD07TS supported? I see a BDR-XD07 in the list, is it the same model?
If the fw is from before 12/22 email me your makemkv drive info section and I will make a flasher for you see below for contact info.
Thank you. So without flashing your firmware, the drive will not be supported "out of the box"?
Not for UHD discs
loopydoodle
#723 Post by loopydoodle » Fri Oct 06, 2023 2:21 pm
Not for UHD discs
Ah okay, much clearer. Don't have any of those. Thanks.
RadicalR
#724 Post by RadicalR » Thu Oct 12, 2023 11:41 pm
Gmangt34 wrote:
Wed Sep 27, 2023 11:03 pm
I grabbed a Pioneer BDR-XS07UHD from Adorama per the previous two posts. Crossing my fingers for a 3/3 success rate since it was the last one in stock! :D
Adorama doesn't have any more 1.02 - Just got mine and it's 1.03...
Guess I'll just hang on to this and hope for an update soon. (I still have a B0UN LibreDrive)
gh0stm4n
#725 Post by gh0stm4n » Sun Oct 15, 2023 9:52 pm
hi All,
I just purchased the pioneer BDR-XD07UHD. From what i read this drive cannot be flashed? This drive was on the list of supported external drives. Any feedback would be much appreciated.
Thank you!
OS device name: I:
Manufacturer: PIONEER
Product: BD-RW BDR-XD07U
Revision: 1.05
Serial number: ALDL011409UC
Firmware date: 2023-01-06
Bus encryption flags: 13
Highest AACS version: 77
Drive platform: Pioneer RS8D31
Firmware version: ID05
#726 Post by MartyMcNuts » Sun Oct 15, 2023 11:08 pm
hi All,
Thank you!
OS device name: I:
Revision: 1.05
No, cannot currently be flashed as it has the dredded firmware that is newer than Dec 2022.
I don't believe there are any external Pioneer drives available anywhere anymore that are UHD & libredrive compatible. It's now a waiting game.
asmcom
#727 Post by asmcom » Sun Oct 15, 2023 11:20 pm
hi All,
Thank you!
OS device name: I:
Revision: 1.05
We have plenty of drives on the correct firmware.
Asmcom
neon-dev
#728 Post by neon-dev » Mon Oct 16, 2023 3:37 pm
Hi, is it correct that this drive can get LibreDrive support via an sdf.bin update?
Also would there be any reason to update to a newer firmware (pre-December 2022, of course)?
Product: BD-ROM BDCUD03AS
Revision: 1.00
Serial number: NHDL000680WL
Firmware date: 2014-04-01
Highest AACS version: 23
Drive platform: Pioneer RS8590
Firmware version: ID23
It says BDR-UD03ASC on the label.
Let me know if you need any further details about this drive.
#729 Post by Billycar11 » Mon Oct 16, 2023 8:50 pm
Revision: 1.00
It's says BDR-UD03ASC on the label.
It may be possible to flash to ud04 and do uhd
Email me for a $25 flasher if you want to try.
neon-dev
#730 Post by neon-dev » Mon Oct 16, 2023 9:15 pm
Thank you for your quick response, Billy.
I've looked into your flashing guide and it says Pioneer drives can't be flashed. Is that info outdated?
It doesn't look like older Pioneer firmwares are publicly avaiable.
asmcom
#731 Post by asmcom » Mon Oct 16, 2023 10:54 pm
:cry:
This drive can be flashed and Billy can do it for you. I verify this drive can be flashed.
Asmcom :mrgreen:
neon-dev
#732 Post by neon-dev » Mon Oct 16, 2023 11:26 pm
Sounds really cool, thanks for the clarification.
Unfortunately I don't own a single UHD disc, so I'm not interested in buying Billy's flasher (sorry).
What about my question whether this drive can get LibreDrive support on standard firmware?
mike admin wrote:If youre drive is listed above but is not supported, it means that it is not yet added to SDF.bin . Please post the drive model here.
#733 Post by Billycar11 » Mon Oct 16, 2023 11:42 pm
You just have to submit your drive info to Mike and he can support it then.
But there is very little benefit to it without the UHD part
Red24
#734 Post by Red24 » Thu Oct 19, 2023 3:29 am
Just came here to say this. The comments all said it was 1.02. I just got mine and it is showing 1.03.
Product: BD-RW BDR-XS07U
Revision: 1.03
Serial number:
Highest AACS version: 61
I'm planning to return and buy a pre-flashed drive now. I was hoping to get a quality Pioneer drive.
CpktMpkt
#735 Post by CpktMpkt » Sun Oct 22, 2023 8:37 am
Hey,
I've just brought the following device:
OS device name: /dev/sr0
Revision: 1.03
Serial number: BBDL015307WL
Firmware date: 2020-08-20
Highest AACS version: 78
as fare as I read it shoult be flashable the use it the UHD BluRays. But I can't find the software or firmware anywere.
here viewtopic.php?f=16&t=19634 are ony firmware for LG and ASUS devices.
Where can I gte UHD friendly firmware?
regards
Christian
