#16
Post
by dcoke22 » Wed Sep 13, 2023 10:57 pm
chronomac wrote: Wed Sep 13, 2023 9:39 pm
How can you tell if a new HK file is available?
MakeMKV will try to download new hashed keys if you stick a UHD in your drive and MakeMKV determines it doesn't already have the necessary key. If you have a UHD that MakeMKV can't decrypt and the dump for the disc has been submitted, every few days, stick it in your drive and attempt to rip it with MakeMKV. Eventually, MakeMKV will download new hashed keys (assuming you don't have some network thing that's keeping you from downloading keys).
UHD FAQ
#17
Post
by Billycar11 » Wed Sep 13, 2023 11:16 pm
dcoke22 wrote: Wed Sep 13, 2023 10:57 pm
UHD FAQ
or rip it to an encrypted backup to put less wear on your drive and then try the backup every few days
chronomac
#18
Post
by chronomac » Thu Sep 14, 2023 12:43 am
dcoke22 wrote: Wed Sep 13, 2023 10:57 pmMakeMKV will try to download new hashed keys if you stick a UHD in your drive and MakeMKV determines it doesn't already have the necessary key. If you have a UHD that MakeMKV can't decrypt and the dump for the disc has been submitted, every few days, stick it in your drive and attempt to rip it with MakeMKV. Eventually, MakeMKV will download new hashed keys (assuming you don't have some network thing that's keeping you from downloading keys).
Makes sense. I just didn’t know if there was a visual indicator in the log that says an attempt was made. Thanks for the info.
Billycar11 wrote: Wed Sep 13, 2023 11:16 pmor rip it to an encrypted backup to put less wear on your drive and then try the backup every few days
That’s a good tip.
Ballesteros
#19
Post
by Ballesteros » Fri Sep 15, 2023 8:31 pm
ictbydesign wrote: Mon Sep 04, 2023 3:45 pm
My UK HMV version arrived today. No key yet.
Submitted MKB20_v77_FAST_X_E862.tgz
Thanks for submitting it - I've been trying each day this week but there was still no key, until today when it has started working.
ictbydesign
#20
Post
by ictbydesign » Sun Sep 24, 2023 2:40 pm
Working for this version now.
thekenster
#21
Post
by thekenster » Fri Jan 12, 2024 10:16 pm
Submitted MKB20_v77_Fast_X_A058.tgz
Shows no key yet for 4K
ishimuro
#22
Post
by ishimuro » Sat May 10, 2025 4:49 pm
Maybe Kind of a Necro here, but just got my Fast and Furious 10 Movie 4K Collection and all ripped perfectly fine except Fast X xD How likely is it, that there has not yet been a key generated for this, after years?
Ofcourse I did sent the Dump to the Mail adress.
MrPenguin
#23
Post
by MrPenguin » Sat May 10, 2025 10:07 pm
ishimuro wrote: Sat May 10, 2025 4:49 pm
Have you tried downloading the latest
KEYDB.cfg file, copying it into MakeMKV's data directory (i.e. where MakeMKV also writes its TGZ dump files) and restarting MakeMKV?
And if that doesn't work, maybe also provide your TGZ dump file here - either as an attachment or via a download link - so that The Powers That KEYDB may examine it please?
ishimuro
#24
Post
by ishimuro » Sat May 10, 2025 10:16 pm
No, I thought MakeMKV downloads everything it needs :S Will try Again!
This is the latest Dump TGZ.
MrPenguin
#25
Post
by MrPenguin » Sat May 10, 2025 10:34 pm
ishimuro wrote: Sat May 10, 2025 10:16 pm
MakeMKV
does automatically download its latest keys. The KEYDB.cfg file is an
optional alternative database that MakeMKV can fall back on, should it be available.
BTW can you also provide a ZIP file containing the
AACS/MKB_RO.inf file from your physical UHD disk please? The copy of this file inside your TGZ dump file has been truncated to only 56 bytes, which makes it unusable to anyone except MakeMKV itself
Also, you appear to have created this TGZ dump file using a Verbatim 43888. Is this your only UHD drive please?
ishimuro
#26
Post
by ishimuro » Mon May 12, 2025 10:20 am
MrPenguin wrote: Sat May 10, 2025 10:34 pm
Ah I see! Yes this is my only Drive, here is the MKB_RO.inf file directly from the Disc. Sorry, this is my first time encountering obstacles
MrPenguin
#27
Post
by MrPenguin » Mon May 12, 2025 3:20 pm
ishimuro wrote: Mon May 12, 2025 10:20 am
Thanks, this provides one the of missing pieces of information that The Powers That KEYDB need from your disk. Unfortunately, the other pieces cannot be obtained from a Verbatim 43888, which means that KEYDB cannot (yet) calculate your disk's Volume Unique Key (VUK)
However, KEYDB.cfg
does already contain a Unit Key for your disk. And you are also running Windows. This means that you could install
Xreveal, and then MakeMKV could use Xreveal to decrypt your disk.
Alternatively, you could wait for The Powers That MakeMKV to process your TGZ dump file instead.
ishimuro
#28
Post
by ishimuro » Sun May 18, 2025 6:55 am
MrPenguin wrote: Mon May 12, 2025 3:20 pm
However, KEYDB.cfg
Thank you! This worked like a charm for me. Have a great Day and I hope one Day my Dumpfile helps someone else <3
Phil256
#29
Post
by Phil256 » Fri Oct 16, 2026 6:48 pm
Hey guys!
I have the same issues with the german Fast X UHD...
i tested so many things and nothing of it works..
I installed Xreveal and it kills the copy protection. But if i start makeMKV there comes an alert that I use another program to kill the copy protection. I can choose YES i want to ripp the Disc, but in about sec MakeMKV freezes...
I've ripped over 800 Blu-rays and UHDs for my NAS and had never such a trouble?! Wtf is this with this movie?!
