Ultimate UHD Drives Flashing Guide Updated 2025
sacdman
#1951 Post by sacdman » Thu Sep 07, 2023 4:33 pm
Hi folks... just got another Asus BW-16D1HT.. having trouble flashing this drive. Need some help, plesase. The drive is new and made in 2023. Had some issues with this drive as I had bought one before, but I would get that previous drive freezing or it would pause momentarily while watching a movie.
I would like to be more careful with flashing this one and do it correctly. I am attempting to flash this one but I am getting a message "checksum is mismatched. drive will go to boot mode please try again". Any help with those who are more experience here would be greatly appreciated. Thanks for any and all help and assistance. :)
Since posting, I have been able to update the firmware to 3.10 with the SDFtool Flasher and all I neede to do was set it "administrator mode" and it worked just fine. This is a new Asus drive and I am still getting freezing and/or pauses when playing a 4K UHD disc. Just now it happened again watching Touch of Evil. I am still trying to troubleshoot the problem and have been going all over the web for solutions. I have also got a good clean microfibre cloth to wipe the disc and still getting random freezes. I am going to see if my firewall is getting in the way and I will be back later to see if anyone else has had this issue with the Asus. Thanking you ahead of time for any all help or suggestions.
#1952 Post by Coopervid » Tue Sep 12, 2023 10:11 am
You should rip to hard drive / SSD either as folder or mkv and then play from that.
#1953 Post by MartyMcNuts » Tue Sep 12, 2023 10:50 am
Forget about direct disc playback. The idea is to rip them then you can play the backup.
asmcom
#1954 Post by asmcom » Wed Sep 13, 2023 5:44 pm
Well said, this is the best solution.
Asmcom :mrgreen:
joelishness
#1955 Post by joelishness » Sun Sep 17, 2023 8:59 pm
Hello, just got an LG BU40N and wanted to share a couple things...
First, this can be added to the list of known encrypted firmware:
HL-DT-ST_BD-RE_BU40N_1.02_212012011716_MO5M5VE4938
(maybe it is already know that the ending alphanumeric string doesn't have to match exactly, if so this wasn't clear to me)
I found it it was encrypted by guess & check.
First I flashed with the unencrypted command, and it reported 100% finished and done successful, but then re-check still indicated the original firmware.
So then I just tried again with the encrypted command. Same 100% finished and done successful, and this time re-check indicated the new firmware.
Also, just wanted to share some info for my situation since it needed a few modifications, in case it is helpful for anyone else.
Situation:
- Linux (headless)
- Automatic Ripping Machine docker
- LG BU40N
Here is how to from my notes:
# From client (desktop linux PC), copy downloaded files to target machine
# Update for target user@hostname
scp -p HL-DT-ST-BD-RE_BU40N-1.03-NM00000-211810241934.bin arm@arm-optiplex-9020:~/.
scp -p sdf.bin arm@arm-optiplex-9020:~/.
# From target machine, copy files to docker container
docker cp HL-DT-ST-BD-RE_BU40N-1.03-NM00000-211810241934.bin  arm-rippers:/tmp/.
docker cp sdf.bin  arm-rippers:/tmp/.
# Enter container shell
docker exec -it arm-rippers bash
# Query drives
/usr/local/bin/makemkvcon f -l
Found 1 drives(s)
00: dev_21:1, /dev/sr0, /dev/sr0
# Query drive info
/usr/local/bin/makemkvcon f -d /dev/sr0 -f /tmp/sdf.bin --info
SDF.bin version: 0x0098
Drive Tool SDF present
Drive Specific SDF present
[Drive Specific SDF] Embedded Info Strings:
8000:LibreDrive Information
8013:Status
8109:Possible (with patched firmware)
8001:Drive platform
:MT1959
8010:Harware support
8100:Yes
8011:Firmware support
8101:No
8002:Firmware type
8108:Original (patched version available)
8003:Firmware version
:1.02
8005:DVD all regions
8006:BD raw data read
8007:BD raw metadata read
8009:Unrestricted read speed
[Drive Specific SDF] Embedded Status Message:
8096:LibreDrive mode for this drive is only possible with firmware upgrade (id=%1)
:BA3AA52BF4C5
Identification SDF present
8013:Status
8001:Drive platform
:MT1959
mtk:19:59:BU5 :HL-DT-ST:BD-RE BU40N 1.02:R000200:-
# Re-flash firmware (encrypted version)
/usr/local/bin/makemkvcon f -d /dev/sr0 -f /tmp/sdf.bin rawflash enc -i /tmp/HL-DT-ST-BD-RE_BU40N-1.03-NM00000-211810241934.bin
# Recheck firmware
Found 1 drives(s)
HL-DT-ST_BD-RE_BU40N_1.03_211810241934_MO5M5VE4938
# Recheck info
8013:Status
8105:Enabled
8001:Drive platform
:MT1959
8002:Firmware type
8107:Patched (microcode access re-enabled)
:1.03
8100:Yes
8100:Yes
8100:Yes
8100:Yes
8099:Using LibreDrive mode (v%1 id=%2)
:06.3
:866A98CB9C4E
8013:Status
8001:Drive platform
:MT1959
mtk:19:59:BU5 :HL-DT-ST:BD-RE BU40N 1.03:NM00000:-
Thanks so much!
Tyler94
#1956 Post by Tyler94 » Thu Sep 28, 2023 1:25 am
I don't get this. Where is the firmware for WH16NS60 1.02MK. I have a WH16NS40-NS50 on version 1.05 and I'm under the impression that I can not use SDF tool to flash it. Tried it and it didn't work. I'm so lost and a lot of this info in not up to date and scattered about. What do I do?
sizzleweet
#1957 Post by sizzleweet » Sat Sep 30, 2023 1:54 pm
Hey all,
So I successfully patched my drive BP60NB10, but I'm still only getting 2x maybe a bit higher but never close to 6x read speeds... I've made the change in the conf file on linux and tried it with the registry changes on windows. Is that normal? It's like it's locked at the 2x.
For reference these are just standard blu-rays I'm working with, not UHD discs.
#1958 Post by dcoke22 » Mon Oct 02, 2023 1:58 pm
The very first post in this thread is kept up to date. viewtopic.php?f=16&t=19634
There's a link there to the 'all you need' firmware zip file and if you're on Windows, you should use the SDF GUI tool, which you can also find a link to.
ActorCam
#1959 Post by ActorCam » Thu Oct 05, 2023 4:32 pm
I hope someone can help. I'm stuck on step 5: In terminal change directory "cd /Applications/MakeMKV.app/Contents/MacOS"
When I type that into Terminal, I get a "No such file or directory" message. Up until then everything seemed good and I was able to move my flash files to the /tmp directory. Anyone know how to resolve this?
Thanks in advance!
#1960 Post by Billycar11 » Thu Oct 05, 2023 9:47 pm
Thanks in advance!
Do you have makemkv installed?
erzengel1
#1961 Post by erzengel1 » Tue Oct 10, 2023 7:12 am
I am locking for a drive to rip my collection.
I was locking now for the BH16NS55 but this is only available from Hitachi-LG BH16NS55 and it looks different from the outside as well, does it matter? Is the Hitachi-Lg the same?
If this is not working I would go for the LG Electronics WH16NS40, because the firmware for flashing is availabale her.
Does I need to run the drive external over USB (OWC Mercury Pro 5.25) or can I install it internal in my PC as well? or is the flashing than not working?
Is this ok or is there a more recommended drive?
Thank you for your feedback
regards
Matthias
#1962 Post by Billycar11 » Tue Oct 10, 2023 2:10 pm
regards
Matthias
Should work on any of those drives and any case that supports optical drives flashing should work.
erzengel1
#1963 Post by erzengel1 » Fri Oct 13, 2023 9:12 am
Zumindest zappiti ist schon mal raus die stellen ihren Dienst ein
https://zappiti-deutschland.de/pressemi ... _reroute=1
Da ich gerne 2 hdmi Ausgänge hätte bleibt für mich die Frage des Dune HD Pro Vision 4K Solo oder Zidoo PC PNI Zidoo UHD2600
Lance274
#1964 Post by Lance274 » Fri Oct 13, 2023 8:42 pm
I have a WP50NB40 Drive SVC code NB50. I have tried flashing and cross-flashing but nothing works. Either no disk is seen of with cross flashing read errors.
What should I be doing in order to Rip the 4k Discs I have?
I have purchased MakeMVK
pinbot
#1965 Post by pinbot » Sat Oct 14, 2023 5:42 pm
Apparently, with all I have seen I need to downgrade my firmware to the LG WH16NS60 1.02mk.
Though I can't seem to find that firmware anywhere.
Does any one know where I can find it or have it to share?
