Pioneer BDR-XD07UHD 1.05 firmware
dranga75
#1 Post by dranga75 » Tue Aug 15, 2023 4:27 am
I recently purchased the pioneer drive BDR-XD07UHD from Amazon. It current firmware version is 1.05. I installed makemkv but it says libredrive is not installed. Hence checking with the forum here to see of there is anyway to get the libredrive enabled
Re: Pioneer BDR-XD07UHD 1.05 firmware
#2 Post by Billycar11 » Tue Aug 15, 2023 7:09 am
dranga75 wrote: Tue Aug 15, 2023 4:27 am I recently purchased the pioneer drive BDR-XD07UHD from Amazon. It current firmware version is 1.05. I installed makemkv but it says libredrive is not installed. Hence checking with the forum here to see of there is anyway to get the libredrive enabled
nope your out of luck it will be supported eventually but not now.
return it and buy a pioneer from a seller in your region
the pioneers really are better drives
asmcom
#3 Post by asmcom » Thu Aug 24, 2023 8:42 pm
We have plenty of stock on firmware 1-04
Super deal!!! 10% discount at present
viewtopic.php?t=19387
Asmcom :mrgreen:
mmandersonii
#4 Post by mmandersonii » Sun Sep 17, 2023 4:07 am
I too have a Pioneer BDR-XD07UHD on 1.05 (stupid me upgraded it since I had a disk that was having read problems). Is there any way to downgrade the bios to a working version?
#5 Post by MartyMcNuts » Sun Oct 15, 2023 9:59 pm
mmandersonii wrote: Sun Sep 17, 2023 4:07 am I too have a Pioneer BDR-XD07UHD on 1.05 (stupid me upgraded it since I had a disk that was having read problems). Is there any way to downgrade the bios to a working version?
No
