Pioneer BDR-XD07UHD 1.05 firmware
I recently purchased the pioneer drive BDR-XD07UHD from Amazon. It current firmware version is 1.05. I installed makemkv but it says libredrive is not installed. Hence checking with the forum here to see of there is anyway to get the libredrive enabled
Re: Pioneer BDR-XD07UHD 1.05 firmware
nope your out of luck it will be supported eventually but not now.
return it and buy a pioneer from a seller in your region
the pioneers really are better drives
We have plenty of stock on firmware 1-04
Super deal!!! 10% discount at present
viewtopic.php?t=19387
Asmcom
mmandersonii
I too have a Pioneer BDR-XD07UHD on 1.05 (stupid me upgraded it since I had a disk that was having read problems). Is there any way to downgrade the bios to a working version?
Nommandersonii wrote: ↑Sun Sep 17, 2023 4:07 amI too have a Pioneer BDR-XD07UHD on 1.05 (stupid me upgraded it since I had a disk that was having read problems). Is there any way to downgrade the bios to a working version?
