Update no worky
Jman5150
Update no worky
#1 Post by Jman5150 » Mon Jun 12, 2023 12:02 pm
I just updated and nothing is working. I tried to reinstall the older. Build but dont see older builds. Does the site have them? Literally isnt working at all
Re: Update no worky
#2 Post by Woodstock » Mon Jun 12, 2023 12:23 pm
http://makemkv.com/download/old/
But there is likely a different reason for "no worky". Like the Windows "don't let unregistered programs run!" feature.
Jman5150
Re: Update no worky
#3 Post by Jman5150 » Thu Jul 20, 2023 7:45 am
I got it working since but it’s had weird stalls for the last month takes like a half an hour to get the program to mount. It tried to reset my ver and over or takes forever in the first screen loading.
asmcom
Re: Update no worky
#4 Post by asmcom » Thu Jul 20, 2023 9:07 am
Jman5150 wrote: Thu Jul 20, 2023 7:45 am I got it working since but it’s had weird stalls for the last month takes like a half an hour to get the program to mount. It tried to reset my ver and over or takes forever in the first screen loading.
Try just one drive and disconnect the other. Untick the multi drive option and see if you still get the stalling.
Asmcom :mrgreen:
Jman5150
Re: Update no worky
#5 Post by Jman5150 » Thu Jul 20, 2023 10:54 am
Ironic I was just reporting back, one drive died on me so I think it was messing with the others. I’ve been rotating around 5 different ones and till now its inconsistency made it hard to isolate. So problem fixed…
asmcom
Re: Update no worky
#6 Post by asmcom » Thu Jul 20, 2023 11:12 am
Jman5150 wrote: Thu Jul 20, 2023 10:54 am Ironic I was just reporting back, one drive died on me so I think it was messing with the others. I’ve been rotating around 5 different ones and till now its inconsistency made it hard to isolate. So problem fixed…
Good to hear :mrgreen:
