Which firmware version should i flash on to the LG BH16NS40 drive to make it LibreDrive compatible?
computerfreak
Post by computerfreak »
My drive is the BH16NS40 which is on the UHD friendly list.
It came with the firmware version 1.05 and was manufactured in March 2023.
MakeMKV is showing the following firmware date: 2120-05-06 13:31
The drive platform is: MT1959
The service code is (If that is of any interest): NS51
Re: Which firmware version should i flash on to the LG BH16NS40 drive to make it LibreDrive compatible?
Flash BH16NS60 1.02 as outlined in the guide.
asmcom
Post by asmcom »
computerfreak wrote: Thu Jun 29, 2023 8:29 pm My drive is the BH16NS40 which is on the UHD friendly list.
Use the SDF Flasher that Martymcnuts wrote. Version 1.05 is encrypted firmware so make sure the enc box is ticked.
viewtopic.php?t=22896
WH16NS60 1.02mk is good firmware for this drive. This file is located in the latest MK file directory in old files directory. As Coopervid said BH16NS60 1-02 could also be used.
https://www.makemkv.com/download/mk-fir ... 200720.zip
HL-DT-ST-BD-RE_WH16NS60-1.02-NM00100-211810291936.bin
This information will also be in Billycar11 excellent guide.
Asmcom
computerfreak
Can i flash that version directly or do I need to flash another version beforehand?
computerfreak
Thank you for you're help
That was pretty easy, MakeMKV is now showing, that LibreDrive is enabled with firmware version 1.02
asmcom
Post by asmcom »
computerfreak wrote: Thu Jun 29, 2023 10:57 pm Thank you for you're help
I am glad I could help you out. Please see products that are available on our MakeMKV Seller Page.
viewtopic.php?t=19387
Asmcom :mrgreen:
