asmcom
Re: MK vs DE?
#1861 Post by asmcom » Thu Jun 29, 2023 2:22 pm
KidJoe wrote: Thu Jun 29, 2023 1:51 pm Unfortunately with 1.02MK, Passkey complains that the drive isn't compatible. Searching, it appears 1.00DE would work for both MakeMKV and Passkey.
What are the differences between 1.00DE and 1.02MK? Should I be concerned about read errors happening again if I flash to 1.00DE?
Here is why I ask:
I have a WH16NS40 (NS50 label) that I had flashed long ago when a plain SATA (Non-AHCI) controller was needed. I don't recall what firmware that was. BUT the drive worked with both MakeMKV and DVDFab Passkey.
Trying to rip with MakeMKV, I had re-errors once in a while in the past. Passkey was worse with lots of retries but eventually read the discs. The latest issue was with brand new Avatar Way of Water 4K disc, there were 3 .m2ts files MakeMKV reported errors with which caused the rip to fail. So I decided to flash to the 1.02MK firmware to see if that helps. It did. With 1.02MK MakeMKV ripped the entire movie. The 3 .m2ts that errored with the older firmware read just fine with MakeMKV and the newly flashed 1.02MK firmware. The resulting MKV plays fine.
Since flashing to 1.02MK, I have tried re-ripping several times, and it continues to work without error. So it does appear that 1.02MK helped.
Prior to flashing 1.02MK, I did try cleaning the disc with soapy water and microfiber cloth. Powering the PC off, waiting a little then turning it on. Ejecting and re-inserting, etc.
Firmware 1-02mk is better than 1-00DE in the number of discs that will rip without issues. Testing over the years, we have found a 10% failure rate with the WH16NS60 on BD100 titles. The Pioneer drives, on the other hand, will back up 100% of any discs we have tried. When you flash back to 1-00DE, you will find that the drive is more selective on what it backups.
Asmcom
viewtopic.php?f=20&t=19387
asmcom
Re: Ultimate UHD Drives Guide Updated 2019
#1862 Post by asmcom » Thu Jun 29, 2023 3:32 pm
ddeconin@gmail.com wrote: Sun Jun 02, 2019 9:15 am Is there an external USB enclosure that supports flashing and that is easily obtainable in europe?
Yes the Vantec NST-540S3-BK DX2, Vantec NST-536S3-BK, Vantec NST-510S3-BK or OWC Mercury Pro.
We are the European distributer for Vantec so we have plenty of stock of any of the above enclosures. OWC also available.
If you want a quotation please email us.
See our seller page URL below.
Asmcom :mrgreen:
asmcom
#1863 Post by asmcom » Thu Jun 29, 2023 3:33 pm
TheShoe wrote: Sun Jun 02, 2019 12:56 pm Yep - it is strange.
I have 4 drives now - two Asus and one LG that are BDXL compatible and then the LG NS60, which is official. I had one of the original NS60 with Firmware 1.00. I don't suppose the latest will work without a firmware patch/downgrade.
The least amount of issues I have ever had are with the official drive.
One difference is that my NS60 is on the SATA bus while the ASUS drive is on the USB 3 bus.
In any case, I like to spread the backup duties around so no single drive does all the work.
Good idea.
Asmcom :mrgreen:
tomasme
#1864 Post by tomasme » Sat Jul 01, 2023 5:54 pm
I had no idea about this....I figured all Blu-Ray drives would play 4K Blu-Ray discs. You guys saved me big time. I used Marty's flasher and it worked perfectly. Thanks!!
glc650
#1865 Post by glc650 » Mon Jul 03, 2023 2:36 am
tomasme wrote: Sat Jul 01, 2023 5:54 pm I figured all Blu-Ray drives would play 4K Blu-Ray discs.
It's no different than BR players. You need a 4K BR player in order to play 4K movies.
Dino-Killer 912
#1866 Post by Dino-Killer 912 » Fri Jul 07, 2023 10:45 am
I saw there is a 1.04 firmware for BU40N in the ‘BU40N-N-Main’ folder within the MK firmwares, is it different from the recommended 1.03? How do I tell if my drive is the “BU40N-N-Main” model?
#1867 Post by MartyMcNuts » Sat Jul 08, 2023 2:59 am
Dino-Killer 912 wrote: Fri Jul 07, 2023 10:45 am I saw there is a 1.04 firmware for BU40N in the ‘BU40N-N-Main’ folder within the MK firmwares, is it different from the recommended 1.03? How do I tell if my drive is the “BU40N-N-Main” model?
1.04 is sh!t. Stick with 1.03.
patricia-p
#1868 Post by patricia-p » Sat Jul 08, 2023 5:28 am
Billycar11 wrote: Tue Jun 27, 2023 7:54 pm It's possible to recover if you can find bu20 fw and can use dos flash on your pc
Can you help me find bu20 firmware please? I looked for HP and the original hardware it was on LG but it may never have been updated hence not available as a download.
Do I need a specific version of dos flash?
BU20N (SO5JH) FW BU24 HW: A
KCC-REM-HLD-BU10N
2016 07 10
CT: 7EEPQDAGY343YL
HP PN: 762434-800
Spares PN: 781417-001
I am unable to add any more images as I have reached the limit.
#1869 Post by Billycar11 » Sat Jul 08, 2023 5:45 am
patricia-p wrote: Sat Jul 08, 2023 5:28 am Image
KCC-REM-HLD-BU10N
2016 07 10
CT: 7EEPQDAGY343YL
HP PN: 762434-800
can you pc use dosflash like it has ide mode in the bios not only ahci?
if you dont have ide mode just give up
patricia-p
#1870 Post by patricia-p » Sat Jul 08, 2023 12:14 pm
It's possible to recover if you can find bu20 fw and can use dos flash on your pc.
I don’t have IDE and it’s time to accept that I borked the drive beyond recovery. Thanks for your help.
troyUHD
#1871 Post by troyUHD » Sun Jul 09, 2023 3:42 pm
Hi Everyone,
Wanted to say thank you to everyone who helped make drive flashing possible!
Purchased an LG WH16NS40 from Amazon and hooked it up to my Linux Mint Debian Edition tower to SATA port #3.
Ryzen 7 3700x processor. Gigabyte motherboard.
Downloaded the appropriate files from this post:
viewtopic.php?f=16&t=19634&sid=d91ceafd ... ba44f04854
Worked find with the “enc” flag. Here is the command I typed in the terminal if it might help anyone else. The files I downloaded where in the Downloads directory in the folder called Drive_Flashing.
./makemkvcon f -d 'dev_21:0' -f /home/troy/Downloads/Drive_Flashing/sdf.bin rawflash enc -i /home/troy/Downloads/Drive_Flashing/HL-DT-ST-BD-RE_WH16NS60-1.02-NM00100-211810291936.bin
Thank you so very much for this help! Super job!
Troy
Drive info if anyone is curious:
OS device name: /dev/sr0
Product: BD-RE WH16NS60
Revision: 1.02
Serial number: <snip>
Highest AACS version: 61
Firmware version: 1.02
Disc Information
Label: TERMINATOR 2
Timestamp: 2017-09-08 18:13:46
Protection: AACS2.0/C v61
Data capacity: 58.95 Gb
Disc type: BD-ROM UHD
Number of layers: 2
Bus encryption flags: 80
Johnqmalapert
#1872 Post by Johnqmalapert » Mon Jul 17, 2023 2:22 pm
Hi all, which ones of these 3 is the best for ripping UHD discs?
Buffalo BRUHD-PU3-BK
ASUS BW-16D1HT
LG BP60NB10
#1873 Post by Billycar11 » Mon Jul 17, 2023 9:49 pm
Johnqmalapert wrote: Mon Jul 17, 2023 2:22 pm Hi all, which ones of these 3 is the best for ripping UHD discs?
ASUS BW-16D1HT
LG BP60NB10
Out of those probably the bp60
But a pioneer is way better email me about a pioneer if you want one
#1874 Post by Coopervid » Mon Jul 17, 2023 10:14 pm
Get a Pioneer. Best drive.
Starkiller-1994
#1875 Post by Starkiller-1994 » Tue Jul 18, 2023 12:14 am
I am trying to do this process for BP50NB40. In the section it mean BP50NB40 to > BP50NB40-NB50-1.03MK and ...> BP50NB40-NB50-1.03MK with enc. Where do i find the with enc and the BP50NB40-NB50-1.03MK with bootloader/full flash as well.
