Crap, I didn't know that. ThanksBillycar11 wrote: ↑Sat Jun 24, 2023 1:56 amripping used discs that are damaged is a no no.baneling wrote: ↑Sat Jun 24, 2023 12:34 amIt's from the libraryMartyMcNuts wrote: ↑Fri Jun 23, 2023 11:13 pm
If it is a new disc, can you return it for a replacement? Just tell them it is defective as it is slightly warped causing scraping noises during playback.
warped, stickers that unbalance it, scratches its a good way to kill a drive.
Ultimate UHD Drives Flashing Guide Updated 2025
@Billycar11
just want to let you know that the ICY Box IB-525-U3 case for 5,25" optical drives works for flashing....
i flashed my LG BH16NS55 Revision: 1.02 from Oktober 2016 with the WH16NS60 1.02MK firmware.
Thank you for your work!!
What if the disc is not warped at all, just has some little scratches on it and the optical drive has issues reading it. Can that still affect the drive?Billycar11 wrote: ↑Sat Jun 24, 2023 1:56 amripping used discs that are damaged is a no no.baneling wrote: ↑Sat Jun 24, 2023 12:34 amIt's from the libraryMartyMcNuts wrote: ↑Fri Jun 23, 2023 11:13 pm
yes some drives do dumb thing like move the read head closer and closer and then it hits the disc ruining the disc and drive as the lens on the lg/asus is plastic so plastic on plastic scratches and both a ruined.baneling wrote: ↑Sat Jun 24, 2023 11:50 pmWhat if the disc is not warped at all, just has some little scratches on it and the optical drive has issues reading it. Can that still affect the drive?Billycar11 wrote: ↑Sat Jun 24, 2023 1:56 amripping used discs that are damaged is a no no.
[/quote]
[/quote]
and this can happen cause of scratches on the disc?
[/quote]
yes and also if the drive is not getting enough power
it is very rare though
my friends, all right, hugs from brazil, I need to try with my drive, it is mt 1939 firmware 1.03 whs40 lg, is there a way to read uhd?
paulao lobao, the brazilian man. hacker of bluray and DVD.
I purchased a secondhand BU20N drive which was on fw BU24 and I flashed HL-DT-ST-BD-RE_BU40N-1.03-NM00000-211810241934
This was because I thought it was a BU40N, so now it is not loaded and isnt operating.
Is it possible to recover it when the manufacturer doesn't have a firmware on the website?
Before flash
Manufacturer: hp
Product: BD-RE BU20N
Revision: BU24
Serial number:
Firmware date: 2115-04-22 13:44
Bus encryption flags: 1F
Firmware version: 0.BU24P
After flash
Product: BD-RE BU40N
Revision: 1.03
Serial number:
Firmware version: 1.03
My laptop
Processor Intel(R) Core(TM) i5-5200U CPU @ 2.20GHz, 2195 Mhz, 2 Core(s), 4 Logical Processor(s)
BIOS Version/Date LENOVO J5ET64WW (1.35 ), 31/10/2019
System SKU LENOVO_MT_20DF_BU_Think_FM_ThinkPad E550
PNP Device ID SCSI\CDROM&VEN_HL-DT-ST&PROD_BD-RE_BU40N\4&6C073B4&0&010000
Name HL-DT-ST BD-RE BU40N
Before flash
Manufacturer: hp
Revision: BU24
Serial number:
After flash
Revision: 1.03
Serial number:
My laptop
It's possible to recover if you can find bu20 fw and can use dos flash on your pc
Thanks that gives me hope it's worth trying.Billycar11 wrote: ↑Tue Jun 27, 2023 7:54 pmIt's possible to recover if you can find bu20 fw and can use dos flash on your pc
I found firmware CDROM.inf.amd64 for bu20n but win10 device manager rejected it.
Is dos flash the same as command prompt? Or is it 3rd party program?
Well, after several years of faithful service, I finally managed to kill my MSI UHD drive today. So, which drive is currently the easiest to obtain and easiest to flash for UHD compatibility?
easiest is to buy a Pioneer flashed from one of us
other wise any of the lg /asus drives in the guide is the same difficulty to flash
Hi Chipless,
Please see our MakeMKV sellers page with a list of drives and our email address.
viewtopic.php?f=20&t=19387
Asmcom
Click Here! viewtopic.php?f=20&t=19387
We are supplying every day from our seller page on MakeMKV.SH0D4N wrote: ↑Sun May 21, 2023 5:49 pmI wanted to buy drive(s) from you, sadly your shop is not active.asmcom wrote: ↑Sun May 21, 2023 4:33 pmWell said Billycar11 and you are on the button.Billycar11 wrote: ↑Sun May 21, 2023 11:03 am
i mean my opinion is avoid all LG/Asus 5.25 desktop drives my fail rate was so high on those i had to stop selling them.
the pioneers are the best by far
the BU40N BP50/60 are not bad they are also faster than the pioneers.
but if your buying from a seller they are cherry picking the drive for as it will be tested so buy whatever you want then.
Asmcom![]()
However I found used ASUS BW-16D1HT with OWC Mercury Pro enclosure nearby for 125€ incl. shipping. "FW 3.10, bought on Christmas 2021 and selling it because after 5 rips I had no use for it and it was catching dust".
Or another drive I found is Hitachi BH16NS55 for 45€ (without enclosure) with not as much info about it as the aforementioned ASUS.
However, is this true? -> viewtopic.php?f=16&t=27725&p=120319#:~: ... er%20break I was thinking of using BR or M-DISC as a cold storage for family photos and such.
If I get burned by the used ASUS I found nearby, I will most likely get the next one from you.
And even if it will work I'll probably stop by for 2nd drive.
Enjoy your vacation! (I presume, 'cuz summer)
PS: I didn't just ignore your heads-up Billycar11 about the fail rate. However I can't get my hands on BU40N BP50/60 and Pioneer is so much more expensive here.
viewtopic.php?t=19387
Asmcom
