Update no worky
Jman5150
Update no worky
I just updated and nothing is working. I tried to reinstall the older. Build but dont see older builds. Does the site have them? Literally isnt working at all
Re: Update no worky
http://makemkv.com/download/old/
But there is likely a different reason for "no worky". Like the Windows "don't let unregistered programs run!" feature.
Jman5150
Re: Update no worky
I got it working since but it’s had weird stalls for the last month takes like a half an hour to get the program to mount. It tried to reset my ver and over or takes forever in the first screen loading.
asmcom
Re: Update no worky
Try just one drive and disconnect the other. Untick the multi drive option and see if you still get the stalling.Jman5150 wrote: Thu Jul 20, 2023 7:45 am I got it working since but it’s had weird stalls for the last month takes like a half an hour to get the program to mount. It tried to reset my ver and over or takes forever in the first screen loading.
Asmcom
Jman5150
Re: Update no worky
Ironic I was just reporting back, one drive died on me so I think it was messing with the others. I’ve been rotating around 5 different ones and till now its inconsistency made it hard to isolate. So problem fixed…
asmcom
Re: Update no worky
Good to hearJman5150 wrote: Thu Jul 20, 2023 10:54 am Ironic I was just reporting back, one drive died on me so I think it was messing with the others. I’ve been rotating around 5 different ones and till now its inconsistency made it hard to isolate. So problem fixed…
