Pioneer Drive Bd-RW BDR-XSO7U will not rip
goodavis
Post by goodavis »
I just purchased this unit on the recommendation of a youtube video. I keep getting errors on 4k movies(Saving Private Ryan 4k) (Ready Player One 4k) ultimately saying failed to open disc or back up failed. I tried (I-Robot) bluray, it ripped but the sound was horrible on it. Am I doing something wrong or do it need to send the unit back?
Manufacturer: PIONEER
Product: BD-RW BDR-XS07U
Revision: 1.02
Serial number: CBDL010426UC
Firmware date: 2022-10-24
Bus encryption flags: 13
Highest AACS version: 71
Drive platform: RS8E21
Firmware version: 1.02/ID05
Thanks in Advance
Re: Pioneer Drive Bd-RW BDR-XSO7U will not rip
the sound being horrible is likly a play back problem not a ripping problem.
are these discs in perfect condition?
it would be strange for a pioneer to be bad i have had less that a 1% fail rate on mine.
asmcom
Post by asmcom »
goodavis wrote: Sun May 14, 2023 11:14 pm I just purchased this unit on the recommendation of a youtube video. I keep getting errors on 4k movies(Saving Private Ryan 4k) (Ready Player One 4k) ultimately saying failed to open disc or back up failed. I tried (I-Robot) bluray, it ripped but the sound was horrible on it. Am I doing something wrong or do it need to send the unit back?
Revision: 1.02
Thanks in Advance
Did you follow the cleaning recommendations for Blu-ray discs listed on the forum? It is very important to clean the discs every time you insert a disc in the drive.
Asmcom :mrgreen:
