#541
Post
by d00zah » Fri Apr 07, 2023 4:59 pm
Verbatin wrote: Fri Apr 07, 2023 4:27 pm
La clave de volumen de este disco es desconocida. No se puede desencriptar el video
DEBUG: Code 0 at w)Z`79F^=U%?OtE`:121264372
DEBUG: Code 0 at bYpr+4+pfiV](|$GE@ :121273319
DEBUG: Code 0 at Y76FQ!aYzx)1n73J0s#w:121265338
Fallo al realizar el backup
You need to email the generated dumpfile to
svq@makemkv.com .
Suggested reading...
UHD FAQ
Fixing Volume Key is Unknown
betali
#542
Post
by betali » Wed Apr 19, 2023 4:15 am
Hello
How do I enable lilbredrive?
Below is the drive information:
OS device name: J:
Manufacturer: PIONEER
Product: BD-RW BDR-213U
Revision: 1.03
Serial number: BBDL000000WL
Firmware date: 2022-07-26
Highest AACS version: 76
Firmware version: ID58
Leszekm
#543
Post
by Leszekm » Wed Apr 19, 2023 3:42 pm
Hello
I have a Pioneer BD-RW BDR-XD07. It does not see the UHD disc.
Enable internet access.
Product: BD-RW BDR-XD07
Revision: 1.03
Serial number: BBDL015932WL
Firmware date: 2020-08-20
Bus encryption flags: 13
Highest AACS version: 66
Drive platform: RS8D30
Firmware version: 1.03
#544
Post
by Coopervid » Wed Apr 19, 2023 5:17 pm
@betali: It should work if you use the newest version of Makemkv and you have Internet access enabled.
#545
Post
by Billycar11 » Wed Apr 19, 2023 6:39 pm
Leszekm wrote: Wed Apr 19, 2023 3:42 pm
Hello
Revision: 1.03
That's not a uhd pioneer it won't work until cross flashing comes out if it comes out
asmcom
#546
Post
by asmcom » Wed Apr 19, 2023 10:10 pm
Coopervid wrote: Wed Apr 19, 2023 5:17 pm
This drive will not read UHD discs as you require model number BDR-XD07TUHD. It might be possible at some stage in the future to flash this model to read UHD discs.
Asmcom.
b***t (
Fantastic service, comms and item.
Best ebay experience ever)
h***i (49)
Best communication ever,
extremely fast shipping,
excellent seller!
Dazza1980
#547
Post
by Dazza1980 » Thu Apr 20, 2023 4:55 am
Hi all I have a bdr-x12ebk is it possible for it to be cross flashed ?.
The firmware revision is 1.06
Regards darren.
betali
#548
Post
by betali » Thu Apr 20, 2023 6:18 pm
My drive information are as follows:
OS device name: J:
Revision: 1.03
#549
Post
by Coopervid » Thu Apr 20, 2023 8:42 pm
I replied already to your other post.Make sure you have the newest Makemkv installed and Internet access enabled.
Quicksilver
#550
Post
by Quicksilver » Tue May 02, 2023 12:56 am
As far as I can see, nobody on the forum has mentioned the Pioneer BDR-XS07B-UHD drive (Japan only?) It is black, so perhaps the B simply refers to that (I've read that the silver Pioneer doesn't play friendly with MakeMKV). It works smoothly with BDs but I always get "LibreDrive compatible drive is required to open this disc - video can't be decrypted" when I try a 4K disc.
OS device name: J:
Product: BD-RW BDR-XS07U {Why U and not B?}
Revision: 1.00
Serial number: [redacted]
Firmware date: 2019-01-07
Highest AACS version: 35
Firmware version: ID69
I have downloaded all the firmware (1.01, 1.02, 1.03) but am not keen to use any of them yet, especially if the latest may disable LibreDrive and ruin my chances of using UHD discs. Any advice would be very welcome. (I'm new to MakeMKV)
#551
Post
by dcoke22 » Tue May 02, 2023 2:01 am
Quicksilver wrote: Tue May 02, 2023 12:56 am
OS device name: J:
Revision: 1.00
See this post:
viewtopic.php?p=129189#p129189
Did you see that message? Do you have a firmware dump in your data directory?
Your drive platform is listed as Pioneer RS8E21. According to the
first post on this thread, the RS8XXX drive platform should be supported. However, I have not seen anyone post that their drive platform is RS8EXX. I've seen RS8FXX and RS8DXX and RS8600, among others.
Also, it is probably best to NOT update the firmware on your drive.
#552
Post
by dcoke22 » Tue May 02, 2023 2:17 am
I spoke too soon. Here are some people with a RS8E20 drive platform:
viewtopic.php?p=133825#p133825
Quicksilver
#553
Post
by Quicksilver » Tue May 02, 2023 6:22 am
Thanks, dcoke22. With your reminder, I have now sent the dump file to
support@makemkv.com. As for the platform, mine is identical to the one being used on this YouTube video:
https://youtu.be/6JoJB3rt8kQ?list=TLPQM ... E-uw&t=508. They appear to have no problems with 4K discs. The only difference is that they have firmware 1.01 (which I have already obtained from a French archival site). So I was kind of hoping that an update to 1.01 (or even 1.02) would enable LibreDrive, especially as the SDF.bin seems to include my drive (as of 11 Feb 2022):
PIONEER-BD-RW__BDR-XS07U-1.00-D1E5568A-8E21ID05-20190107
PIONEER-BD-RW__BDR-XS07U-1.01-1534D764-8E21ID05-20200903
PIONEER-BD-RW__BDR-XS07U-1.01-32129473-8E21ID69-20200903
But no reference here to platform, I guess. So I will be patient.
#554
Post
by Billycar11 » Tue May 02, 2023 9:33 am
Quicksilver wrote: Tue May 02, 2023 6:22 am
im sure support will be added as its older.
but you could always update to 1.01 if you don't want to wait but waiting is alot less risky
executor999
#555
Post
by executor999 » Tue May 02, 2023 10:01 pm
OS device name: E:
Product: BD-RW BDR-S13U
Revision: 1.04
Serial number:
Firmware date: 2022-12-12
Highest AACS version: 77
Firmware version: ID43
