baneling wrote: Sat Apr 22, 2023 10:12 pm
I only see him under the pre-flashed drives heading. I don't see any flashed drives heading.
pre flashed is flashed.
he preflashes them before sending it
Arp137
Post by Arp137 »
So, I got my BW-16D1HT.
makemkv says it has 3.10 on it. In the guide on the first page it says that 3.11 is an encrypted firmware. Does that mean that 3.10 not encrypted, so I don't use "enc" in the flash command?
Never mind. Found an older thread with the same question. Works. Thank you!
digitalMedic
Post by digitalMedic »
Hello all,
Today I realized I never flashed my LG WH16NS40 from its original firmware 1.05 to the LG WH16NS60 1.02 firmware. I was able to rip some of my 4K discs, but others had errors. After flashing, I am getting a read rate of 3.6x-5.4x. How do I get 8x speeds? I used the SDFTool Flasher and it said it was successful. Any insight?
Read rate depends on the disk, actually. The longer the read, the more the speed will rise, on most disks.
digitalMedic wrote: Wed Apr 26, 2023 12:10 am Hello all,
You won't get constant spped that high. It may reach 8x speed occasionally but for a lot of the rip, it's between 4x-6x.
Koubafire
Post by Koubafire »
can someone upload ASUS 16D1HT FIRMWARE 3.11? I cant find it there.
Koubafire wrote: Wed Apr 26, 2023 10:33 am Hello,
3.11 is encrypted follow the standard instructions and add enc
I will update the list soon
Koubafire
Post by Koubafire »
Billycar11 wrote: Wed Apr 26, 2023 10:36 am
what is add enc? I am using SDF tool
Whas is the best FW for 16D1HT . I read somewhere its WH16NS60 firmware is it right? With 3.10 MK or 3.01 fw I have problem wirg birnungs verbatim 50gb disc - always fails
I have icy box ib-550stu3s+ External Box
user31415
Post by user31415 »
Hi, i'm new here, there are many drives to choose from and I don't really know which one to get.
I have some Bluray movies that I want to store on my PC.
Also the list says UHD friendly and UHD official ... what is the difference?
Like do I need a specific drive for Dolby Atmos movies or how does that work?
user31415 wrote: Wed Apr 26, 2023 7:35 pm Hi, i'm new here, there are many drives to choose from and I don't really know which one to get.
A UHD official drive has the necessary hardware to play a UHD disc with official UHD playback software on the very narrow set of hardware and OS versions that allow for that. UHD friendly means it can rip UHD discs but not play them back with official software on supported hardware. If you're intending to use it on Linux, it doesn't matter. There's no official UHD support there. A drive of either variety will work the same for you.
user31415 wrote: Wed Apr 26, 2023 7:35 pm Like do I need a specific drive for Dolby Atmos movies or how does that work?
No. If the drive can rip the disc, (you need a UHD capable drive to rip UHD discs), you get all the contents on it.
user31415
Post by user31415 »
dcoke22 wrote: Wed Apr 26, 2023 11:01 pm
Thanks for explaining, I ordered the LG BU40N, does it work out of the box or what do I need to do?
user31415 wrote: Thu Apr 27, 2023 11:26 am Thanks for explaining, I ordered the LG BU40N, does it work out of the box or what do I need to do?
The first post in this thread is maintained and contains instructions on how to flash your drive and which firmware to flash your drive to.
Edu02
Post by Edu02 »
Hi guys,
Which the best UHD drive to rip my DVD and Bluray collection (I want keep as is with menu) you recommend me to buy?
I want to best one
Thank you !!!
BailMe
Post by BailMe »
Billycar11 wrote: Mon May 27, 2019 5:20 am Recommended Firmware to flash for MakeMKV:
BP50NB40 to > BP50NB40-NB50-1.03MK then to > BP60NB10 1.02MK or 1.00MK
NB52 to > BP50NB40-NB50-1.03MK with enc > BP50NB40-NB50-1.03MK with bootloader/full flash > BP60NB10 1.00_HBD from Marty download/file.php?id=2143
if using command line add "full" after rawflash
"Nature will always make a better idiot": and thats me!
I have a drive with BP50NB40 and I dont really understand what this is telling me to do so im kind of stuck.
can anyone maybe more elaborately or descriptively explain what i need to do with this command line, or can reference a video or photos of flashing specifically a drive with "BP50NB40" so im not messing up anything?
BailMe wrote: Sun Apr 30, 2023 1:50 am
Use SDFtool flasher. Read this post: viewtopic.php?p=94848#p94848
