LibreDrive for Pioneer drives
Billycar11 wrote: Sun Mar 19, 2023 10:40 pm there is still a lot to learn about crossflashing pioneers i have a pioneer 208 dbk form 2013 and it can read UHD after flashing
only 2 people in the world probably know the full list of drives that its possible on but the gist of it for now is if the drive platform is 8301+ it probably can see UHD when flashed.
but that does not mean it will be problem free some have lower quality picks ups and they wont rip BD100s or even BD66 marty found this out first hand so even if your drive can see a UHD does not mean it is useful for UHD.
Exactly.... That's why I did say his XD05S may possibly be to old.
Yep, the BDR-212DBK when cross-flashed to BDR-S12UHT could not successfully rip any BD100 discs I tried. It could rip BD66 but wasn't successful every time either.
Honestly, I wouldn't even attempt to use a 9+ year old drive for UHD, even if it did end up being capable. Far better off getting a new drive for UHD.
CNCisRobot
Post by CNCisRobot »
Please can someone help me I have posted 2 posts and no one has responded with help. I bought a Pioneer 4k drive BDR-UD04 with firmware 1.2 and it does not read to copy or play discs. I have seen on ebay someone selling this drive with firmware 1.14 is there a brute force flasher and bin for this version that I can flash to this drive? Otherwise it is just a slim paper weight!
Darren.
CNCisRobot wrote: Mon Mar 20, 2023 2:13 pm Please can someone help me I have posted 2 posts and no one has responded with help. I bought a Pioneer 4k drive BDR-UD04 with firmware 1.2 and it does not read to copy or play discs. I have seen on ebay someone selling this drive with firmware 1.14 is there a brute force flasher and bin for this version that I can flash to this drive? Otherwise it is just a slim paper weight!
Darren.
Read this:
index.php?sid=7b97319c27916c8bceac08952c8792f6
MartyMcNuts wrote: Sun Mar 19, 2023 11:16 pm
If only ripping of UHDs (<=50GB) is concerned the 212DBK and the 209DBK just work fine when cross-flashed.
asmcom
Post by asmcom »
Darren.
Please post a screenshot of MakeMKV when you 1st open. What country are you located in?
Asmcom :mrgreen:
Coopervid wrote: Mon Mar 20, 2023 8:51 pm
True but there aren't many UHD discs under 50GB!!
troyanz
Post by troyanz »
Hi.
My drive in list but is not working. :(
What's wrong?
OS device name: G:
Manufacturer: ASUS
Product: SBW-06D2X-U
Revision: 1.10
Serial number: SHDL137196WL
Firmware date: 2017-04-18
Firmware version: ID22
Debug log started at Tue Mar 21 18:16:21 2023 , written by MakeMKV v1.17.3 win(x64-release)
001005:0000 MakeMKV v1.17.3 win(x64-release) started
001004:0000 Debug logging enabled, log will be saved as file://C:\Users\pppp/MakeMKV_log.txt
No  SDF v098: ASUS_SBW-06D2X-U_1.10_SHDL137196WL
DEBUG: Code 3 at 'W5#or0UspRy]J7I('S_3yx3:29395310
SDF id v098: ASUS_SBW-06D2X-U_1.10_SHDL137196WL
Application exited at Tue Mar 21 18:16:35 2023
troyanz wrote: Tue Mar 21, 2023 6:25 pm Hi.
What's wrong?
OS device name: G:
Manufacturer: ASUS
Revision: 1.10
Seems you have a weird firmware version.
mike_admin described the process for adding firmware support on page 24 of this thread. See below:
Here is the process for adding LibreDrive support.
First time MakeMKV sees a new LibreDrive-capable drive, it would produce a firmware dump file (named something like dump_FW_8D764A026549A275718D.tgz ) and would say something like "Please send this file to support@makemkv.com". The dump will be saved in the MakeMKV data directory (can be looked up in preferences). This happens once per drive/firmware, and MakeMKV won't be nagging you anymore.
For some (really old) drives the dump will be a big (few megabytes) file, containing the entire firmware - in this case just this dump is enough.
For most drives the dump file will be very small, few hundred bytes. The process to get a full dump is different per drive and tends to become easier, but to begin with I do need a small dump first. Without a small dump I might have no clue that this drive or firmware even exist.
troyanz
Post by troyanz »
When I run the program, it doesn't offer anything. Only _private_data.tar is downloaded to the working directory and that's it, nothing else is there.
Drive inside ASUS SBW-06D2X-U is Pioneer BDR-UD03ASW HW1.00 FW1.00 Mfg Date 2019-08-28
OS device name: G:
Manufacturer: ASUS
Revision: 1.10
CNCisRobot
asmcom wrote: Mon Mar 20, 2023 11:28 pm
Darren.
Asmcom :mrgreen:
I am in the UK,
Here is the screen shot you asked for, and I have dissambled the drive and it had 2 strange labels with not much information on. I pulled them off to reveal the real label and drive details. It actually states PIONEEER BDR-UD04TBD.
I was supprised at the date of manufacture 2017 considering I just purchased this drive. But I did get it from Aliexpress.....
Darren.
Real Label.PNG (1.53 MiB) Viewed 27797 times
CNCisRobot wrote: Wed Mar 22, 2023 11:33 am
Darren.
Asmcom :mrgreen:
I am in the UK,
Darren.
Somebody must have flashed it to the newest firmware. Either return it or wait patiently for a fix for the newest firmwares.
CNCisRobot
I bought it from Aliexpress so no option to return. I can wait for a fix as otherwise it is just no good for 4K.
asmcom
Post by asmcom »
Darren.
Asmcom :mrgreen:
I am in the UK,
Darren.
Send it back, I feel very sorry you have been scammed and probably sold an old drive that has been flashed with the latest firmware. As a gesture of goodwill and feeling sorry for you, I will sell you a drive for £70.00, most recent model either 2022 or 2023 model in an enclosure.
I normally sell these at £119.99 on ebay. Another lesson learned, cheap is not always better.
viewtopic.php?t=19387
Asmcom
asmcom
Post by asmcom »
Darren.
Asmcom :mrgreen:
I am in the UK,
Darren.
Send it back, I feel very sorry you have been scanned and probably sold an old drive that has been flashed with the latest firmware. As a gesture of goodwill and feeling sorry for you, I will sell you a drive for £70.00, most recent model either 2022 or 2023 model in an enclosure.
I normally sell these at £119.99 on ebay. Another lesson cheap is not always better.
Asmcom
asmcom
Post by asmcom »
The BDR-212-DBK has a plastic lens, and we have stress tested this model. This is the reason we do not sell these models. The failure rate is 12% on BD100 discs, whereas the S12-XLT with a glass lens has less than a 1% failure rate.
Asmcom
